Question about Xerox DocuColor 12 Color Copier
Dc 12 docucolor fery x12
Sir my machine is dc12 i bought from mumbai frist the print is very good after 100 oprints it comed down to light after that fading colors. after so many day we find the solution that is the toner are not going to developers that is solved and the zerox is ok. new problem arrise when we conneted to ferry x12 white print come no print blank page tst pages also blank. When this ferry is set to another my dc12 it is ok and that fierry to this printer same blank page pl... give me the solution outr engineer is saying withour seeing by hearing check back side of the printer board vsl cabe anls ttl cable pl.. given me full details about this
spectraa@yahoo.com
prasad
siva36 nickname
  • 12 more comments
  • siva36 Aug 25, 2008
    white blank page is comming test page, zerox is ok
    problem
  • siva36 Aug 27, 2008
    jaiko sir problem was solved i pressed the cable of nvm to printer board brom cable pressed. It was solved some engineer came and some code was removed then the machine is ok print is ok for calibration view he has removed my ferry calibration. Now it is okay any problem for deleting the calibration from ferry. What is the use of calibration in ferry.
  • siva36 Aug 30, 2008
    Sir
    I am not getting 12x18 print size on prinable area a3 i am geeting if a3 i am giving it is getting printing is not centering 12x18 print i am not getting ...........solution
  • siva36 Aug 31, 2008
    sir another problem when printer starts noise come 1 second thats common but from yesterday onwards full noise not stopping katakata sounds comming ...........solution.
  • siva36 Sep 01, 2008
    i am not getting 12 x 18 size print is comming a3 size print is cutting on all sides print area 12 x 18 i am not getting. NVM values suggest...............
  • Anonymous Sep 01, 2008
    one side light print
  • siva36 Sep 04, 2008
    dear sir i am not getting 12 x 18 size the print is cutting. give me the reasons
  • siva36 Sep 07, 2008
    dear sir,
    I have another new problem my fiery x12 problem hangindg showin messages of loading , so i contact our engineer in mumbai he told restore ok i resotred then he told me to cange the ip address i changed no test print is comming and in printer i am seeing a message of check network cable network printer error. I did not find the solution previous also i got blank plage on that day the printer is showning same message one engineer came and correted i didnot see the setting he told machine was locked . Now i am facing the same problem of network cable error and printer error something. No print is coming from ferry this ferry is connected to the other printer same proble showing on the printer no printer solve my problem dc 12 x12ferry
    nvm settings also i had corrected two sides ok then top i didnot find bottom i am edge cutting top down.
  • siva36 Sep 08, 2008
    sri for what purpose i had to use patch file and how to install patch what patch file i have to use pl...
    sir first i am not getting test page when i am pressing test pages the light is blinking on the fierry and print from printer. The message is showing on the printer is ... network controller error, check connection to the controller pl..
  • siva36 Sep 09, 2008
    dear jaiko sir, My problem was not solved, network controller error, check connections to the controller. My other machine ferry connected to this fierry ok. This ferry connected to the other machine the sam problem is comming. I had removed printer card and replaced again same probel. this was hapnning when I restoed the system afterword it is comming like that. solve my problem pl.. Previously i asked one question for 12 x 18 size i ma not getting the simple way is when we go to tools manus change to extend area option then i got it. ...
  • siva36 Sep 11, 2008
    my ip adress 192.168.0.20 what previous setrtings
  • starmedia123 Jan 07, 2009
    dear sir
    i have one problem in my dc 12. prints are comming grany & not even clear.
Dear jaiku zerox is commming why print from system is not comming
Posted on Aug 25, 2008
  • 79 Answers
Hi first u check the immage wher its missing? in drum, ibt belt and 2nt btr(paper)... if its not appear in drum pls check drum unit and ros assembly. if its not appear in ibt belt pls chck bios and tranfer rollers... all the best.
  • 9 more comments
  • jai kumar
    jai kumar Aug 27, 2008
    hi every fiery or machine have a default setting, if its changed we cant get good quality. in this time we doing calibration. its fixed in default setting in our machine..ok..
  • jai kumar
    jai kumar Aug 30, 2008
    hi siva may i knowhe what kind of software you using? i think its only setting problem. and mean time u will check bypass try paper gide setting. its A3 or 12x18.
  • jai kumar
    hi if prints only not coming u will check printer driver settings,cable connection,and network settings.
  • jai kumar
    jai kumar Sep 01, 2008
    hi i think waste toner box full.. and noise come from waste toner collecting gear.. chack that..
  • jai kumar
    hi check ur machine 1st tray.. ur machine nvm sheet is there. u chcek it that.
  • jai kumar
    jai kumar Sep 04, 2008
    hi pls check nvm settings, and tray settings. and also check ur system page setup settings. write now i dont have nvm settings. pls try this.
  • jai kumar
    jai kumar Sep 08, 2008
    hi pls install patch file to ur fiery.. it came with along ur cds.. u install fiery patch file and restart ur system and fiery.. than its working fine...
  • jai kumar
    hi its a printer driver software.. u go to commando workstation and right click top and import the patch file using ur patch file cd. thats all..
  • jai kumar
    hi just refix ur printer and fiery cables.. and restart ur printer and fiery.. than try..
  • jai kumar
    jai kumar Sep 10, 2008
    hi u check ur fiery ip address and all ur previes settings also.. then install patch file first.. than try it..
  • jai kumar
    jai kumar Sep 11, 2008
    if u have ur fiery previes configuration sheet check all setings to ur fiery to configuration sheet..
Printing to a Xerox DC12/DCS50
you can't print via serial to it. You will have to check the settings in your rip to see what the ip address is. Lights will blink all the time to indicate it is on a network, its just not talking to it. Then you go into your add printers section click the + sign and it should come up in there if the ip address is in line with your mac ip
Dec 16, 2008 | Xerox DocuColor 12 Printer
High Contrast in Printing Photographs from DC-12
sir
u do one thing press 0+ start & go to max setup
trc adjustment press start u can get a3 print
next trc toner concentration start
ofter u can get some defference
Dec 11, 2008 | Xerox DocuColor 12 Printer
Graininess on xerox dc12 print s
hi i think u took print in low resulution photo. pls check ur phot resulution.
Nov 21, 2008 | Xerox DocuColor 12 Printer
No oil shining on papers
hi check ur oil rollers , metering blade and upper fuser roller... than check upper roller life.. its life 60k to 80k.
Sep 12, 2008 | Xerox DocuColor 12 Printer
Printing problem
pls check ur fuser oil supply, and oil pump?
Aug 15, 2008 | Xerox DocuColor 12 Printer
Xerox docu color 12
u check drum,ibt belt,2nt btr roller and fuser life... then do full service, then calibrate ur fiery also.. first u check developer bios plate.. if its have more dust print comes like that.. all the best..
Aug 14, 2008 | Xerox DocuColor 12 Color Copier
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
Xerox DocuColor 12 Color Copier Logo
1,038 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
