Exploded diagram at the link below. Parts are in Italian but these can easily be translated on the web. ( translate.google.co.uk )
http://www.partsguru.com/user/AROMA%20SIN%20015%20Aroma%20MANUAL%20.pdf
Their should be an internal fuse located close to where the mains flex enters the unit.
If their doesn't appear to be one then the first item to check would be the main switch (Item 26 on Page 1).
You'll need either a multimeter to check that with the mains on, and the switch in the on position you're getting a supply to the secondary side of the switch (be very careful if you do this as working with live exposed equipment can be dangerous). Your other option is to use a continuity checker and with the mains off and unplugged, place the continuity checker across the switch and move the switch to the on position. If the switch is OK then the continuity checker should either buzz or flash depending on what tyre you're using.
If this fails or you require any further guidance then just ask.
