Question about Compaq Presario 5000 PC Desktop
Compac presario V5000
Iam ramesh i have a lap top,Whenever i start the laptop it is just starting and the opening options are appearing even i tried all options but it is switching off only i am able to acess BIOS setup, earlier the optic drive icon was not appearing in my computer window please help me
thanking you
    Champion:
  • 200 Answers
Sorry to tell you that my friend but you will need to reinstall windows orrrr the easiest way for now is to do a repair
so that you can do by inserting the OS disc and select a repair option.
cheers
Posted on Aug 30, 2008
I downloaded free open office and can see it in my download box but cant see the icon on the desktop so i cant use it, what am i doing wrong? i use a compac presario laptop with windows vista.
Click the start button and in "Start Search" text box type open office.
If it has been installed it will show up in the search list.
Right Click the icon and a sub menu will appear. From the sub menu hover mouse over "Send To" and options will appear to the right. select "Desktop (create shortcut)".
Desktop icon should now appear from which you can run Open Office.
Congratulations on using Open Source alternative to MS Office!
Hope this helps.
Dec 09, 2009 | Cell Phones
Don't Turn on. LED just turn on/off but don't start.
They will not replace it, they will repair it.
It is possible the problem is caused by a faulty battery or even a faulty power cord.
I cannot say where you shoulod take it for repair because i have no idea where you are located. So I therefore suggest you take it to any Outlet that sells/repairs Compaq listed in your phone book.
Kindly rate our help++++Thanks for using FIXYA
Oct 16, 2009 | Compaq Presario CQ50-215NR Notebook
Broken touchpad on compaq v5000 series
Disassemble the laptop, down to where you can remove the top case cover, and get to the Touchpad. (AC adapter, {Charger}, removed, and battery removed)
Here's how:
1.http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=499847&lang=en&
This is HP.com/Support, and the Manuals page for the Compaq Presario V5000 CTO laptop. (Even if it isn't your exact model, your laptop is part of the Presario V5000 Series, and this information transfers directly over)
On this page I would like you to click on ->
Compaq Presario V5000 Notebook PC - Maintenance and Service
Guide <- in blue.
It states that it's a 'guide', but it's a Service Manual, believe me!
This is a PDF file download. After you click on it, you may not see
anything happening for up to 30 seconds. Usually after 10 seconds
you will see the first page. I caution you to Not look through it, until it has fully downloaded. You may accidentally break the connection.
AFTER it has fully downloaded, you can save it to your computer.
This way you can burn it to a CD disk, and look at it anytime you want. (You can also delete it off of your computer, and free up harddrive space, plus you can put the disk in another computer, and view it as you work on your laptop)
To do this click on the Floppy Disk icon. This is in the upper header, and is the second icon from the left. Hovering your mouse over it will briefly reveal, "Click to save this file to your computer or another location"
If you do not have your downloads set to be saved to your My Documents folder, this pdf file will go to your desktop screen.
(c00700903.pdf)
Suggest you start with Page 77 first, then on Page 125 (Base Enclosure and Top Cover), you'll find the info for removing the Top Cover. The Touchpad is in the Top Cover.
Jun 03, 2009 | HP Compaq Presario V5000Z Notebook
Instaling new hinges lap top compaq v5000
HP recalled the Pavillion laptops, one reason was the hinges .. If you call them and explain your problem LOL.. they will send you a box to send your laptop in for repair. for FREE
I hope i could Help..
Mar 29, 2009 | HP Compaq Presario V5000Z Notebook
HP Compaq Presario V5000 LCD Problem
I have the same problem. I thought the problem was due to a loose cable so I opened the computer up only to find out the cables are all good. I still haven't found a solution
Sep 07, 2008 | HP Compaq Presario V5000Z Notebook
S-Video port on my Compac Presario V5000 Laptop
try installing manufacturers Drivers for your video card... You're probably using the "default" drivers.. Might fix it to get the current ..
May 17, 2008 | Compaq Presario-Notebook 900 Series Video...
Compac Presario V5000 S-Video problem
Perhaps you can change your resolution or your refresh rate on the out to TV? Give it a try.
May 17, 2008 | HP Compaq nc6230 Notebook
First sheck and configure display properties > settings > advance for multiple or external S-Video TV. Check device manager > display adapter > update drivers. Restart.
Broard band change over
hi friend
here is link for u 24 hour online service tecnision 4u
contect him diis cribe ur hole the problem he will gave u a solution
here is link for u
http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&lang=en&product=500508&dlc=en
Mar 08, 2008 | Compaq Presario 700 470024-192 Notebook
Could be a stuck key somewhere, has anything been wasted on the keypad, tap the keys one by one to refresh is. Could also be that the keyboard is broken.
Fixya me ... thanks!
Feb 20, 2008 | Compaq Presario 2170US Notebook
Compaq Presario 5000 PC Desktop Logo
119 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
