Question about Lands Phones
Rapidly flashing indicator light on cd135 - Lands Phones
Hi, flashing indicator light was simply the answerphone memory full
Posted on Aug 26, 2008
Hotpoint fault codes
try a different store.
Oct 31, 2013 | Washing Machines
Haotion 125 bad earth lights working incorrectly
intermintant loss of power to headlights clock air conditioning 2001 toyota avalon ! solution....new alternator and new battery fitted.
Oct 04, 2012 | Cars & Trucks
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
1993 plymouth acclaim turn signal flashes rapidly, new flasher didn't work.
bad earth on a back light i suspect providing their europeon standard lights with yellow seperate indicators and not them funny american ones with a stop and tail and indicators all on the one bulb
Jun 27, 2011 | 1993 Plymouth Acclaim
I have a quantum model 3212 serial #3000...fcc id #kj8intrmt...ok im trying to program my garage door to my truck..help please
1. In the vehicle press and hold the two outside buttons until the indicator light begins to flash (after 20 seconds). Release both buttons. Note: Some vehicles may require the ignition switch to be turned to the second (or "accessory") position during the programming process.
2. Hold the end of your handheld transmitter between 1 and 3 inches away from the Homelink surface (located on your visor or overhead console) keeping the indicator light in view.
3. Using both hands, simultaneously push the handheld transmitter button and the desired HomeLink button. DO NOT release the buttons until step 4 has been completed.
4. Hold down both buttons until the indicator light on the HomeLink Wireless Control System flashes, first slowly then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapidly flashing light indicates successful programming of the new frequency signal.)
To train your garage door opener.
1. Locate the smart/learn button on the garage door opener motor head unit.
2. Press and immediately release the smart/learn button.
Firmly press and release the programmed HomeLink button. Press and release the HomeLink button a second time to complete the training process. (Some garage door openers may require you to do this procedure a third time to complete the training.)
Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
I need to know the process on how to program the cars built in gurage door opener on a 2001 chrysler town & country
Hi my name is Allen!
Program a previously trained homelink button as follows... 1. Press and hold the desired pre-programmed HomeLink button for at least 20 seconds (but no longer than 30 seconds) until the indicator light begins to flash. Without releasing the HomeLink button, position the hand-held transmitter 1-3 inches away from the homeLink surface keeping the HomeLink indicator light in view. 2. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button (or press and "cycle" - as described in "Gate and Canadian programming"). DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful programming) The previous device has now been erased and the new device can be activated by pushing the HomeLink button that has just been programmed. however, it may be necessary to follow steps 5-7 of the "programming" section to complete the rolling code training. This procedure will not affect any other programmed HomeLink buttons.
Dec 20, 2008 | 2001 Chrysler Town & Country
Program garage door opener
You must first erase what's in the memory.
1.) Simultaneously press both buttons 1 and 3 on the Audi's built-in remote. Hold them until the indicator light flashes (20 seconds or longer).
2.) Now hold your garage door remote close to the Audi remote.
3.) Simultaneously press and hold both your garage door remote button and the button you would like programmed. The indicator light will first flash slowly then rapidly.
4.) You may release both buttons once the light flashes rapidly.
Jul 01, 2008 | 2000 Audi A6
Philips model cd135
Hi there Fred
Here are links to user guides for your unit. Good luck, thanks for using FixYa
http://www.p4c.philips.com/files/c/cd1302s_73/cd1302s_73_qsg_eng.pdf
http://www.p4c.philips.com/files/c/cd1353s_05/cd1353s_05_dfu_eng.pdf
regards
Graeme
Mar 15, 2008 | Lands Phones
Philips CD135 Twin Cordless Phone
Disassembly the battery pack, and power on after that.
Oct 28, 2007 | Philips DECT 2252S Cordless Phone
Lands Phones Logo
151 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
