Question about Refrigerators
Fisher & Paykel Refigirator N249T, Problem was fridge section working as a freezer so could you help me how to adjust the temperature.
  • MickeyB09 Apr 13, 2009
    Which way do you turn the dial?
Turn the temp. up....
Posted on Oct 23, 2008
SOURCE:
I have a 10 years E521T fisher & paykel. The freezer compartment is working fine, however the fridge compartment is not working even adjust temperture. It's beeping and can be reset with pressing
From thee sounds of your issue you will need a sensor or a fan motor to move air from one section to another. Most likely this would be a fan motor located within the freezer section either not running or air flow is obstructed and can't leave the freezer section to enter through passages to cool the other section. Locate the air ports within the refer section, open freezer door (is there air coming out of air port in this section?). Now, close door to freezer, (is the same air flow still there?). If not you have an air flow restriction and this would need to be addressed. Good Luck, hit me up if you have more questions
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 04, 2014 | Fisher and Paykel Active Smart® E522BR...
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
I bought a second hand F&P Fridge Mod N249T about 7 years old..and it keeps feezing all of our food!!! The teperature control shows 1-7 seven, we tried setting it to 1 which we thought would be the...
I was not able to find a manual for your model; perhaps the company has not posted going back this far. Your model seems to be available on the resale market in Australia. If your model is not from Australia, vist the following site http://www.fisherpaykel.com.au/customercare/userguide/ and in the bottom of the webpage select the country the refrigerator was purchased. verify your model number and then go to Customer Care > Find A User Guide. Use the search fields to find your User Guide; if you leave the model number blank and select rerfigertaor you wil get a selection of all the available User Guides for refrigerators.
The Fisher and Paykel site seemed to only has one User Guide for all their refrigeration model but it does not list as applicable for the N249T. See here: http://www.fisherpaykel.com//admin/pdfs//pdf_usecares/837186-Ref_Freezer-UG_NZ-AU-UK-PAC.pdf
However on page 18 it does describe the Temperature Control:
1 is for the warmest setting
7 is for the coldest setting
The Problem Solving Section on page 29 advises that when food is freezing in the refrigerator the temperature setting is not correct or food is placed directly in front of air outlets.
If the unit is not shutting off when the desired temperature is reached there may be a problem with the thermostat.
Hope this is of some assistance.
Sep 10, 2011 | Fisher and Paykel Active Smart E522B...
Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Nov 04, 2009 | Fisher and Paykel Active Smart® E522BR...
I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Sep 14, 2009 | Fisher and Paykel Active Smart E522B...
Top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
Dec 16, 2008 | Fisher and Paykel Fisher Paykel 21768 -...
Very hot compresser upside down fidge
Is there a little fan back there with the compressor? if so is it turning? also check the outside coil, it may be covered with dust & crap. Sometimes that is all thet it takes. A good cleaning.
Feb 16, 2008 | Fisher and Paykel Active Smart® E522BR...
Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
956 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
