Question about Mitsumi (D359M3 SILVER) Internal Floppy Drive
Floppy drive (d63119)
when i bought my computer(p4 windows xp professional),at first, i didn't view
my floppy drive(A:). i checked power source and it's connection between
motherbord(tape wiring),the green led ligth is turnon, everything is correct,but
my computer don't display the floppy drive A:.can you guide me please?
is there a hardware problem or a software problem?
thank's already your attention.
best regards
  • 326 Answers
Is the green light on all the time, if it is the ide cable is probably plugged in wrong, if not when your windows startes up press rather F2/delete or F12 (different for different motherboards) your looking for ''enter setup'' look in there to see if floppy has been picked up and if its enabled. might just be a dead floppy drive.
Posted on Sep 01, 2008
Why doesn't Disk Manager find my external floppy drive?
Check connections, make sure power connections are correct, make sure drivers are installed correctly. It might be a bad drive or it may not be communicating correctly.
Jun 04, 2014 | Microsoft Windows XP Professional for PC
Windows XP download
Windows XP Professional SP2
Step 2: Run the Setup disk program to create the Setup disks
When you download the Setup disks, the download contains only one large program file. When you run the downloaded file, it extracts the files. You receive the following message:
This program creates the Setup boot disks for Windows XP. To create these disks, you need to provide 6 blank, formatted, high-density disks.
Please specify the floppy drive to copy the images to:
Type the drive letter for the floppy disk drive (this is typically drive A). After you type the floppy disk drive letter, you receive the following message:
Insert one of these disks into drive drive letter:. This disk will become the Windows XP Setup Boot Disk.
Press any key when you are ready.
When you press a key, the downloaded file starts to extract and copy the files. Continue to insert the blank disks as you are prompted to do this until all six disks are created. If the process is interrupted, you must run the downloaded program file again to create all six disks.
Make sure that you label each disk appropriately with the number that is specified by the program. You must use the disks in the correct order during the Setup process.
Step 3: Start your computer by using the first Setup disk to begin a new Windows XP installation
After you create all six disks, insert the first disk in the floppy disk drive, and then restart the computer. The computer must be configured to start from the floppy disk drive. You may have to modify the BIOS settings on your computer to do this.
The Setup process starts. Insert the other floppy disks when you are prompted. You must use the Windows XP CD-ROM to finish the Setup process.
hope it helps
May 13, 2012 | Microsoft Windows XP Professional With...
Down laod xp recovery disk
If you're running Windows XP and Windows crashes or becomes unusable, you may have to run a Windows XP recovery setup disk to make your computer usable again. When purchased, many computers don't come with a Windows XP recovery setup disk, but you can download one for free from Microsoft. The Windows XP recovery setup disk holds the computer software and files that you need to assist you in rebuilding your operating system.
Place a formatted floppy disk in your floppy disk drive. You will need six formatted floppy disks. Visit Microsoft's Download Center and download the version of the setup disk for your version of Windows (see links in Resources). Home Edition Professional Edition set up disks for floppy XP Recovery CD Maker Windows XP Home Edition and Windows XP Professional Edition have their own recovery setup disks and you must use the correct disk for your version of Windows. Click "Download" and then "Save." Find your floppy drive or optical media drive on the menu and click "OK." If Windows isn't functioning at all, you will have to perform these actions from a working PC. Remove the last floppy disk when the Windows XP recovery disk download is complete and place it in the computer on which you need to use it. Shut down your computer and then turn it back on. If your computer prompts you to boot from the disk, press Enter. If it doesn't, you'll have to go into your BIOS to set the computer to boot first from your disk drive. When your computer boots from disk it will automatically start running the Windows XP recovery setup disk from which you can then set up Windows XP. Hope this helps.
Jan 30, 2012 | Microsoft Computers & Internet
Floppy disk drive not detected.
It sounds as if you have a registry error. try to go to device manager and uninstall the drive. Turn your computer off and restart and see if Windows detects it automatically
Feb 04, 2010 | Microsoft Windows XP Professional
Hello, Anybody Please help me! I just bought compaq laptop with preinstalled Xp. I want to use Xp and because of some problem in existing XP, I would like to re-install XP professional. When I put CD and...
Serial ATA (SATA) drives are the latest in the hard drive fashion and, in theory, installing Windows on the drive should prove relatively simple. The problem is that Windows XP doesn’t contain the necessary drivers to allow windows to see the drive so that Windows can install it.
I found the procedure below on an XP support website. I have not tried this procedure but after reviewing I fairly certain this should work for you.
1/ Copy the SATA drivers (these can usually be found on your pc or motherboard's support disk. Usually these consist of PIDE/SATA Folders and TXTsetup.oem files. Alternatively they may have been supplied on a separate CD that accompanied your SATA drive, assuming you purchased it separately from the pc.)
2/ Insert the Windows XP CD (full retail version – you should not need to follow these instructions if your pc came with a recovery disk) into the CD-ROM and Reboot your PC
3/ Watch carefully as the Windows XP installation progresses and look carefully at the text at the bottom of each screen.
4/ At the Windows Setup Screen (this should be the second screen after installation starts) you should see, at the bottom of the screen) a message saying “Press F6 if you need to install a third party SCSI or RAID driver.”
5/ At this point press the F6 button
6/ When the next screen appears press S to specify an additional device
7/ Now insert the floppy disk containing the SATA drivers into your floppy drive
8/ Windows will next ask you to select a driver from the provided list
9/ Select VIA Serial (or whichever controller your motherboard supports) ATA RAID Controller (Windows XP)
10/ The SATA drivers on your floppy disk should now load
11/ After the drivers have loaded Windows XP will recognise your SATA hard drive and you can continue installing the Windows XP operating system
Jun 07, 2009 | Computers & Internet
Hello,pls I am having problem with my laptop IBM R30. Whenever I turn it on,It displays NTLDR file missing.MY mail is
Windows 2000 users If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive. [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers. Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516. Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive. copy ntldr c: copy c: After the above two files have been copied, remove the floppy diskette and reboot the computer. Windows XP users Insert the Windows XP bootable CD into the computer. When prompted to press any key to boot from the CD, press any key. Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer. copy e:\i386\ntldr c:\ copy e:\i386\ c:\ Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Jun 05, 2009 | IBM Computers & Internet
Troubleshooting Floppy Disk Drive Problems in Windowxp
try using the floppy on another computer, if you have the same problem then the floppy is bad, if it works on another computer then your floppy drive might be bad, if you built the computer, try using another cable for the floppy drive, i ran into problems like that when i put bad cables in
Dec 04, 2008 | Microsoft Windows XP Professional
Windows instaling problem
When you disable for installation it normally does not work correctly when enabled again. Go to Hp's website and download the SATA software. You will need a floppy drive. The driver for it extracts to the floppy. If your laptop did not come equipped with a floppy you will have to use an external usb floppy. No off brand it has to be a name brand. Normally the generic floppies do not work. Once you have the software extracted to the floppy. Boot the computer to with xp cd. When the blue screen displaysa message accross the bottom with say "Press F6 if you need to install a third party SCSI or RAID driver. The computer will read the floppy and select one of the choices preferably windows default.
Hope this helps you
Dec 28, 2007 | Computers & Internet
Please check If your CD drive is detected on BIOS, if yes then Put a Windows XP bootale CD (checkout for the Service Pack) and choose boot from CD in the BIOS and go for "repair option" after the Agreement "I Agree-press F8" session. complete the installation then try installing the printer.
Oct 09, 2007 | Computers & Internet
Mitsumi (D359M3 SILVER) Internal Floppy Drive Logo
444 people viewed this question
Top Mitsumi Computers & Internet Experts
David Payne
David Payne
Are you a Mitsumi Computer and Internet Expert? Answer questions, earn points and help others
