Question about Kitchen Ranges
Hoover hd 889 bottom oven not working after power turned off.
    President:
  • 1,462 Answers
Get your instruction book and try resetting the clock - you probably have it set to the auto position
Posted on Aug 23, 2008
Power not getting to power nozzle on Hoover S3765
replace your belt on bottom of unit under beater bar panel.
Jul 22, 2014 | Hoover Vacuums
Hoover bottom oven not heating up
Hoover Oven not heating? How to replace a Hoover fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 14, 2012 | Ovens
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
Apr 24, 2011 | Hoover Washing Machines
No water/coffee comes through? the temprature indicators doesnt light up?
The POWER LIGHT for the 889 is RED and located on the LEFT of the center cowling
The BOILER LIGHT for the 889 is YELLOW and located on the RIGHT of the center cowling
If you turn on the power to the unit (the INNER SWITCH on the RIGHT SIDE) the RED light should turn on, showing that the machine is powered. At that point the YELLOW light should also turn on for about 10 seconds, at which point it will turn OFF with an audible CLICK.
If the RED light does not turn on then you have a very dead machine.
If the RED light does turn on but the YELLOW light does not then you have a half dead machine.
Opening up and repairing the 889 is not for amateurs. High voltage, heat and pressure inside.
If you decide to bin the machine I would appreciate getting the drip tray from you as I have lost mine.
Graham Leach
Sep 05, 2010 | Dualit Espresso 889 Espresso & Coffee...
Hoover vision HD 1400 AAA 8kg washing machine - wont start & four flashing lights on timer delay ?????? any advice pls
can I have the instruction how to use for HOOVER vision HD 1400 AA+A. I lost the manual
Feb 01, 2010 | Washing Machines
The water does not get pumped out of the machine
The filter is to be found at the bottom front left of washer behind a removeable plastic trim, if you can see a screw in the filter cover, undo this, and turn filter anticlockwise to remove.
If no filter at front, then remove rear panel of washer, and remove large black hose fastened to drum, check for blockage here, and check the pump at the same time.
Thanks
.Please rate my solution;
Nov 08, 2009 | Hoover AAA160 Front Load Washer
Dualit 889 espresso maker leak
my machine did the same.... i just descaled it and gave all the parts a really good clean and it seemes to solve the problem
Dec 30, 2008 | Dualit Espresso 889 Espresso & Coffee...
Hoover S3630 WindTunnel
Broken wire reconnected and power was restored.
Jul 13, 2008 | Hoover S3630 WindTunnel Bagged Canister...
Stoves 720 / 900 GRa GR DO gas electric dual fuel oven
Our oven had the same fault.
It turns out that the air intake was blocked.
The air intake is at the front, just below the bottom oven door. Some liberal sucking with a hoover sorted the problem instantly.
Apr 06, 2008 | Stoves Premier 720GRa Gas Double Oven
Kitchen Ranges Logo
123 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
