Computers & Internet Logo
Anonymous Posted on Aug 23, 2008
Sony DRU 190A CD/DVD drive compatibility to XP SP2?
New drive inserted, very slow response, can open for exploring, but no reading audio or DVD files, no burning
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
84
Points
Upgraded to newer BIOS version on the MB
Why won't this thing read or write?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Windows don't detect drivers of sony dvd rw dru 190a
can you see your dvd drive in windows explorer if not
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
if you dont have motherboard disk you will need to download the drivers
http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html
http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
Adaptec
Sony dvd dru-190a not able to read dvd's but reading cd's. Please help.
It sounds like the laser on your drive is gone. But there are a couple of things you can try first before buying a new one.
Uninstall the driver for it in Device Manager and let windows reinstall it automatically on reboot.
or use DriverEasy to install it > download here .
Uninstall and reinstall whatever burning software you use.
Take a look at this thread. Some of the tips there might apply to you.
http://www.techsupportforum.com/micr...ng-cd-rom.html
The drive I had trouble with back when I posted in July finally died a couple of weeks ago. CD's worked fine, just like you. All my good settings with Auto Run, etc, were still there. So I bought a new drive and I'm back in business.
2helpful
2answers
Sony CD / DVD DRU-510A. Reads CD's and DVD's, burns CD's, but will not recognize blank DVD's. Sony support page states: 4X DVD-RW Media Compatibility Notice Please Note: 4X DVD-RW media is not...
Well a quick check here says it should manage 4 x DVD write speeds:-
http://reviews.cnet.com/dvd-drives/sony-dru-510a/4507-3212_7-21226932.html
The only thing I can think of is that lens may have some dust on it, try a CD lens cleaning disk or a blast of air from an aerosol spray can.
After this, I'm afraid its down a replacement.
Till last month the drive was working fine and BIOS was displaying the name and model no. properly. But from then the name and model no. is overwritten and the OS is not able to detect the drive and...
Try changing the data and/or power cable using with the optical drive. If after that the bios don't see your optical drive then also try reseting your bios, after those 2 checks if the optical drive remains undetected is fried, need to be replaced.
2answers
Dvd not recognised but plays cd
well, we experienced the same problem, have you tried cleaning on the lens, if you already tried doing it, try to upgrade its firmware, if this not work, buy a new one this time not a sony, tnx.
Dru-190a sony it takes 50-60 min to write
Just right click on my computer, go to properties> hardware> device manager> IDE ATA/ATAPI Controllers. there u will find several primary and secondary IDE Channels. Right click on first IDE channel and goto properties> Advanced settings, change transfer mode to "DMA if Available". Repeat it with all the channels. If problem still persists then uninstall the channel containing ur DVD Writer and restart your computer. It will detect new hardware as DVD Writer. Now if it is showing the transfer mode "DMA if Available" by default then your problem is solved.
1helpful
My dvd writer DRU-190A takes 50-60 minutes for each dvd writing.
Sony DRU-500A Won't read DVDs... at all.
INSTALL VISTA ANY WAY the problem is that windows can use the drive..
BOOT OF THE VISTA DISC
enter setup when the system boots up
go to booting options
and select the dvd rom as the first boot device
ensure the vista disc is in the drive
and save and exir setup
it will tell you to pree any key to boot from cd/dvd
and it will install vista without any hassle
Sony DRU 700A, can't play/write DVD
go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive Good luck!
Grand Canyon Tech
Grand Canyon Tech
