Question about Microsoft Xbox 360 Console
Xbox Live If i have a wireless router (DLink) then what else do i need for xbox live because it says network adapter disconnected. Do i need one or not?
    Master:
  • 505 Answers
I would just use a Ethernet cable easier and faster Ethernet cable from xbox 360 to dlink router
Posted on Aug 23, 2008
Older XBox 360 with wireless antenna - can't connect to network - why not?
What color does your wireless adapter (xbox) turn when you power on your xbox? Green, Red, or Grey (No light)?
If it's grey(no light), try connecting the adapter into one of the USB ports in front of the console(the usb ports are behind that flap)
If it's red, it's a hardware problem and you should try and repair it.. or replace it (xbox antenna).
If it's green, then it's something to do with your network settings.
Good Luck
Jan 12, 2013 | Video Game Consoles & Games
Cant connect to xbox live
What you need:A high-speed Internet connection such as cable A router, gateway, or wireless access point (WAP) that is compatible with Xbox LIVE. An Xbox 360 Wireless Networking Adapter (original Xbox 360 console only) Instructions: On your console, go to My Xbox, and then select System Settings. Select Network Settings. Select the name of your wireless network. Enter your wireless network password. Select Yes if you are prompted to update your console software. When you successfully connect to Xbox LIVE, your screen will look like this:
Jul 25, 2011 | Microsoft Wireless Network Adapter Xbox...
Having trouble connecting Xbox live. Have wireless router and wireless Xbox 360 adapter. Figured out where adapter goes. Now I'm stuck.
Is the router already setup and working? Do you have anything else that successfully connects to it "wirelessly", like a laptop or desktop or smartphone? If the answer is yes, here's how to setup the 360 to connect to your router:
1. Turn on the console and navigate to the wireless settings screen. On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
2. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
3. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
4. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead.
5. Save your settings and verify the network is functional. On the Xbox 360, use the "Test Xbox Live Connection" option.
Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need: Active Xbox Live subscription (to access services)
edited from here: http://compnetworking.about.com/od/wifihomenetworking/ht/xbox2wifirouter.htm
Mar 05, 2011 | D-Link DI-624 Air Plus XtremeG Wireless...
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
Wireless adaptor was working fine until xbox live update, and since the update is unable to pick up our wireless netowork. Tried switching everything back on and on and re synching modem with xbox, to no...
To connect your Xbox 360 gaming console to a NETGEAR router's wireless network:
  1. Turn off your Xbox 360 and disconnect anything from the I/O port on the back of the console.
  2. Insert your Xbox 360 wireless adapter to the I/O port as instructed by the wireless adapter manual.
  3. Connect the wireless adapter cable to your Xbox 360 I/O port.
  4. Flip up the network adapter's antenna.
  5. Turn on your Xbox 360.
    • If you are using an unencrypted wireless network, your Xbox should connect to it automatically and you do not need to proceed to Step 6.
    • If you are using an encrypted wireless network click the System tab, and then click Network Settings and continue with Step 6.
  6. On the Network Settings page, select Edit Settings.
  7. On the Edit Settings page, select your wireless settings on the Basic Settings tab.
  8. On the Select Wireless Network page, select your wireless network.
  9. On the WEP Network page, type your wireless network key, and then click Done.
  10. On the Apply Settings page, click Test Xbox Live.
  11. If this is the first time you have connected your Xbox 360 to Xbox Live, you will probably be prompted to apply an update. If there are no updates, the Xbox Live Connection page shows that you're connected to Xbox Live. Press the Y button on your controller to continue.
If testing the Xbox it says DNS failed, then update your NETGEAR router firmware:
  1. From your computer, open an Internet Browser and navigate to http://kb.netgear.com to download the firmware for your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. Click Router Upgrade on the top left pane under Maintenance, browse for the firmware downloaded and click Upload.
  4. Wait for the router to reboot.
Dec 20, 2010 | NetGear MA101 802.11b Wireless Adapter
How to hookup wireless internet
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 07, 2010 | Video Game Consoles & Games
I am trying to set up xbox live for my son but when i try to go live on the xbox dashboard it says that wireless network not connected but i have a wireless network running in my house and need to know how...
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
What You Need:
  • Active Xbox Live subscription (to access services)
Source: About.com
Sep 29, 2008 | Computers & Internet
Xbox 360 wireless adapter connection
Try resetting your router and reconfiguring. Secondly try using a different wireless security mode that the 360 adapter supports. If the router is a linksys, that could be the problem. Linksys has a very common drop problem. I have found that D-Link has better integrity for wireless devices. Also try putting another device on the network via Wireless, if the same result, replace the router. Also, you can do a search on google for wireless router tweaks, to optimize the router for and xbox wireless connection. One more thing. be sure you force an ip address for the adapter in the settings area on the 360. That promises the same IP everytime it connects. Then go into your router configuration and forward the ports for xbox live, the wireless connection may not even be dropping, but a port problem with live while trying to authenticate your game system
The following ports must be available for Xbox Live to operate correctly:
• UDP 88
• UDP 3074
• TCP 3074
Jan 06, 2008 | Microsoft Wireless Network Adapter Xbox...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
