Question about Acer TravelMate 2300 Notebook
Removal of an Optical Drive
How do I remove & replace the DVD drive?
Acer help gives the removal of a TM 4100 & following the instructions(which do not 'exactly' conform to my model:TM 4151LMI) the drive will not 'slide out'.
Richard HE Honey
  • 244 Answers
For model TM4151,
1. you need to open the power cover (power cover is cover where power button is).
2. remove screw that hold keyboard.
3. after you remove keyboard, you will see the screw that hold dvd (it's under keyboard)
Posted on Aug 24, 2008
Replace an optical drive
depending on model it is usual that there is a removal tab one one edge of your drive face. press this in and the removal tab should be visible then pull to remove the drive from the laptop. (do this when power is off)
order replacement of drive and insert into slot.
I hope this was useful.
Feb 25, 2013 | Computers & Internet
Coins in macbook cd slot
This happened to me yesterday. My 3-year-old stuffed the Macbook's DVD/CD slot full of game tokens, hoping that one of them would play a movie. Took me his entire naptime to extract them, but everything works fine now.
First, open the guts of your laptop and remove the optical drive. Depending on your model the appropriate guide should be here:
Among those I found the following excellent guide for mine:
Once the drive is out you can skip most of the remaining (replacement) steps, since you're putting the same drive back in.
Now switch to the following guide to get foreign objects out:
Jan 23, 2013 | Apple MacBook Mac Notebook
Everytime i put a disc in my xbox it reads dvd. I got to keep ejecting it and closing it back to make it read the game . Pleasee!!!!!!!!!!!!!!! help me
Just to make certain it's not a burnt game on a modded/flashed xbox then more likely your optical dvd drive on the DVD player for the xbox 360 is going out. The lens and laser can be acting up inside and the only way to fix this is to replace the optical dvd drive. You can remove the optical drive and it has 4 screws. You carefully remove the chip inside and transfer to new xbox 360 optical drive which by the way has to be the exact same model to work properly. There are detailed instructions on youtube on how to remove and replace a xbox 360 dvd player.
Dec 22, 2010 | Microsoft Xbox 360 Console
I have Acer Extensa 4620 its dvd drive is not working where should i get repaired and how much will be it costs?
Fix it yourself heres how: purchase a replacment dvd drive heres an example of one you could purchase that will fit your model
Most dvd drives from any acer extensa will fit your model with the relevent bracket, which you will already have connected to your broken one.
ok now veiw the service manual here Service Manual and go to page 57 chapter 3 (67/142) here you will find the section called removing the optical drive module. its really simple just follow the instructions and pictures carefully.
Hope this Helps! Please Rate!
Nov 27, 2009 | Acer Extensa 4620 Notebook
How do I remove the DVD player from my Dell 1530 XPS laptop ?
download the service manual via this link: unzip it and run the index.html file, this with open a local webpage with various options on it. Select 'Optical drive' this will then give you a step by step guide on how to remove and replace the DVD drive, it even includes good detailed pictures. remember to follow the instructions carefully. Hope this helps.
Nov 25, 2009 | Dell XPS M1530 Laptop
Dvd drive removal
Hello There and Welcome to Fixya,
Your optical drive (dvd drive) is not a "Customer Replaceable Unit" (CRU) following Lenovo's service standards. What I recommend instead, is for you to contact their helpdesk through phone. Here's the link for their consumer support for further guidance :
Lenovo Support
It will provide you with options and more knowledge about your Y510.
I hope this helps, Thank you for using FixYa.
Nov 19, 2009 | Lenovo IdeaPad Y510 Notebook
Toshiba Satellite U305-S2808 DVD replacement?
Optical drive removal varies among notebooks. Some have quick-release gadgets, which may be on the bottom of the notebook or in the memory compartment. Some have screws that need to be removed from the notebook bottom. On my Satellite Pro 6000, it's on the bottom, aligned with the drive, but halfway to the other side of the case. If this is the case, pop it out. Get the model number off of the drive; you may have to replace it with the same one. While most optical drive chassis are standard, the drawer fronts are different, and not necessarily exchangeable.
Mar 04, 2009 | Toshiba Satellite U305-S2804 Laptop
Dvd drive removal
go here and look on the site for some goood tips and pictures
I hope this helps
Dec 24, 2008 | Computers & Internet
DVD/CD Combo drive, removal/installation.
I believe that this model has a built in drive the only way to remove it is to remove cover to the laptop. If the drive isn't working go into hardware profiles right hand click on the drive and select remove. This will remove it from windows then when you restart windows should find the drive and install the drivers. Make sure you have the software drivers before you do this.
Thanks J
Feb 05, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Removing old/Installing new optical drive?
hi chris, best thing is to get hold of a manual but since NEC's support is not that good they don't provide them on their websites for download. but not to worry, generally you got 2 options from my experience i can confirm that the first one is the old drive is secured with a screw located in the back of the laptop underneath the drive itself if that's the case just unscrew it and release the old drive , the other option is you might need to strip the laptop down and unscrew the drive from inside the laptop i guarantee you these are the only ways manufacturers secure optical drives to laptops. hope this helps
Aug 19, 2007 | Acer Aspire 5003WLMi Notebook
Computers & Internet Logo
427 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
