Make sure your password is correct and your wireless adapter for your laptop is enabled...
Your Laptop> is the wireless turned on? if it is and you can-not see the wireless connection try re setting your modem.. to see if your connecting to a wireless go to the desktop and bottom right of your screen will be a picture of a small computer if your are connected to Ethernet cable, single click this computer icon will bring up a sub menu if you are broadcasting wireless it will pick up all wireless connection in the area if it is not then on your Laptop Press the Fn button and on the top of your keyboard look for something that looks like an antenna or a phone mask even a little drawing of a satellite disk so pressing Fn and then the the wireless button will turn it on if you are on a desktop make sure the correct software is installed for your wireless pci wireless adaptor, If you are using a wireless dongle then it the signal or a fault with the dongle which is common
One of the most common issues with setting up a wireless router is either not turning on the wireless portion of your router or the wireless card in your laptop or desktop PC.
Somewhere on the setup screen of your router will be a checkbox that will be labeled as enabling wireless, enabling radio, or something similar to that. Ensure that the checkbox is actually turned on. Your laptop will also have either a separate switch or function key combination that will enable your wireless card. Ensure that the switch is turned on or the function key combo has been used to turn on the wireless card.
On both the router and the wireless card there will be lights that should be on to let you know that the wireless portion of that hardware has been enabled. If both have been enabled but you still cannot connect wirelessly then please update your query. If you can identify the router and wireless card you are using and provide us with some details of where you are in the setup process it will make it much easier for us to assist you in resolving your issue. Thank you for allowing us to assist you in resolving your issue.
