Sound drivers i have got volume controls.. i have updated the sound drivers in my computer.. have tried to downloaded realtek.. Still m omputer is not producing sound ... can you tell me why???
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Realtek HD Driver Instllation failure
Please explain more the position:
1. Is the hard drive properly connected in the computer?
2. have you booted the computer to recognize HD in BIOS?
3. Have you inserted bootabe Windows CD to attempt loading the operating system?
4. Has the Operating system loaded and failed?
Note: hard Drives are made in Standard Industry specs. If its good and connected properly it should work. If it is a second or third hard drive you are connecting, it may be connected wrong in data cables.
Posted on Feb 18, 2008
Anonymous
  • 16 Answers
SOURCE: no audio
Open your computer then boot to safe mode(press F8), go to add/remove programs then uninstall the toshiba audio driver, also check on the Device Manager if it is still there then uninstall it. Reboot the computer to normal mode then install the toshiba audio driver again. Be sure to have the correct driver downloaded.
Posted on Jun 18, 2008
cpenzes
DEKR
  • 1102 Answers
SOURCE: soun problem in my pc having xp
control panel add new hardware then next and follow instructions
if it does'nt find your driver then option choose from list
a list will appear if you see the driver click then next if you don't see the driver then scroll to add new hardware usually bottom of page then highlight and next follow instructions
let me know if this helped
also you might want to check and be sure the sound card is secure
Posted on Jan 20, 2009
Anonymous
  • 34 Answers
SOURCE: need Realtek Ac'97 Audio for VIA (R) Audio Controller driver
here you can download it for free in all windows versions... http://www.radarsync.com/drivers/d131057-realtek_ac%27%2797_audio_for_via_%28r%29_audio_controller
don't forget to rate!... xD
Posted on Jul 05, 2009
I have no sound at all or sound scheme ima first time owner and have never been able to even listen to anything on my computer/
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you dont have a motherboard disc you will have to download the drivers
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
http://www.boxdrivers.com
using this link you will be able select your drivers
http://download.cnet.com/Realtek-AC-97-Driver-Windows-98-Me-2000-XP-2003/3000-2120_4-10238712.html
Realtek AC'97 Drivers & Applications. The package includes: Driver/Application Setup Program; RtlRack for Win98/Me/2000/XP and AvRack for Win95/NT4; Realtek Sound Effect Manager. DirectX 8 is required to enable advanced features.
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
http://download.cnet.com/Realtek-High-Definition-Audio-Codec-Windows-Vista-Windows-7-32-bit/3000-2120_4-10788600.html free sound drivers
Realtek HD audio driver package. The package includes: driver setup program, drivers for Vista 32-bitedition.
if these arent right you will find free sound drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
(be precise)but don't use numbers or / - also the download software finder under that there will be a list place a tick in the box of any one you want/need
hope this help you
Sep 06, 2011 | eMachines Computers & Internet
Theres no audio sound drivers on my sound card
also
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check:
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer:
if you dont have a motherboard disk you will need to download the sound drivers
Update your embedded sound from Realtek to the latest AC'97 codec.
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or you can download the drivers
Download the driver software by
hope this helps
Aug 02, 2011 | HP Sound Card
No sound in my presario c300,please help me to find sound divice
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
Realtek AC'97 audio driver package. The package includes: driver setup program, drivers for Vista/Windows 7 32-bit and 64-bit editions.
Realtek AC
Jun 27, 2011 | Compaq Creative Sound Blaster PCI 128...
No sound
also
hope this helps
Realtek AC
Jun 27, 2011 | Intel D915GAG Socket 775 Motherboard -...
No sound
also
hope this helps
Realtek AC
Jun 27, 2011 | Sony DRIVER Computer Speakers
Polk audio trying to download speakers into computer
you cant download speakers but you can download speaker drivers
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers if you dont have a motherboard disc you will have to download the drivers
hope this helps
hope this helps
Jun 24, 2011 | Polk Audio Audio Players & Recorders
My computer can't detect my speakers MS-710 so, i think that i have to update and download the program for this one but, i can't found it. please, i need help!
hope this helps
Realtek AC
Jun 22, 2011 | AOpen Speakers: MS-710 Pro Computer...
Realtek audio not install
If you are having problems with you sound
also
hope this helps
hope this helps
Jun 18, 2011 | Computers & Internet
No sound driver
cnetdownload.com if these drivers are not suitable on the home page you should see the download software finder under that there will be a list platform, category sub category price fromthe category drop down list select drivers then from the price drop down list select free or which ever applies to your need or you could try some of these
hope this helps
http://majorgeeks.com/Realtek_High_Definition_Audio_for_VistaWin_7_d5513.html
Win7/Vista
control panel administrive tools computer management device manager scroll to sound video and game controllers could be a yellow question mark? right click to re-install drivers
click start control panel sounds and audio,volume you can adjust the volume also
advanced,speakers select appropriate speakers or select audio you will find 3 drop down lists make sure you have selected the right speakers also hope this helps
Jun 11, 2011 | Computers & Internet
My Computer have an integral Realtek sound card,and Gigabyte motherboard. The option for mic volume is grayed out, and i just can`t turn it on. I saw in one forum that evryone have similar problem, but for...
You should update your sound driver. Update of Sound Card Driver.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Click on Sound, Video and game controller
  • Right click on sound driver from the list.
  • Click on Update Driver.
  • Update Driver Wizard start.
  • Realtek Sound Driver
Apr 25, 2009 | Computers & Internet
Open Questions:
Computers & Internet Logo
14 people viewed this question
Ekse
Marvin
Marvin
