My Philips 32PFL7562d/10 TV is switching itself on and off at random. It goes to both standby and 'full off' mode. The problem isn't being caused by the remote or by a dodgy power supply. It also occasionally does other things while turned on (such as the volume changing). Any ideas?
ronpar
  • 27 Answers
SOURCE: Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Posted on Dec 06, 2007
  • 1694 Answers
SOURCE: When I am trying to turn on the tv by remote or pushing the power buttton it goes to stand by mode
Solder bad connections vertical output IC......requires chassis
to be pulled....................T.
SOURCE: Philips tv turns on by itself and is stuck in demo mode
Change the eeprom
Posted on Mar 17, 2008
chrispurs1
  • 372 Answers
SOURCE: Matsui 28WN TV keeps turning
Hi.
Is your Matsui model just 28WN ?
Does it have anything else eg
28WN03 28WN04 28WN05 28WN20
Please give full model number.
http://dysonmanuals.llc.nu/
Posted on Jul 16, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from www.cnet.com
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Televison & Video
I have a Philips 32PFL7562D t.v. connected via a Humax HDR-FOX T2 recorder. When I change back from a recorded programme to the T.V the screen goes blue then breaks up into 'hundreds and thousands. (s
How are you changing from recorded to TV? If you are switching the TV input, it could be because it's looking first for analogue TV stations but there are none any more, so it then reverts to the SCART and shows the Humax satellite station. If you are just pressing STOP on the Humax then you shouldn't have a problem, but if you do have the problem then the Humax must be faulty.
Sep 05, 2014 | Televison & Video
Philips 42plf7422 RANDOMLY SWITCHES INPUTS
There is nothing wrong with the TV I assumes. Have you tested it a hard reset? If not do a hard reset and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. An overnight unplug will be more effective. This must make the TV to a hard reset. If it do not help you, you have to enter its service mode options to make it a factory reset. If you wish to get more details about how to enter the factory mode check this link. http://electronicshelponline.blogspot.com/ Service mode and alignments to many brand TVs, including Philips models, have been discussed in detail there with illustrations. Pull up older posts there, and surf the site with patience.
May 29, 2013 | Philips 42PFL7422D 42 in. LCD TV
Toshiba LCD tv switches itself on or off randomly. No timer or child lock on
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 19, 2012 | Toshiba Televison & Video
My pioneer plasma tv in standby mode and wont turn on
Try restting it by unplugging the tv for a few mins and it should rest to original factory default settings but leave it unplugged 10-15 mins to be sure.
Dec 18, 2011 | Pioneer PDP-4270HD 42 in. Plasma...
MY 32" LCD PHILIPS KEEPS CLICKING AND SWITCHING ON AND OFF ON ITS OWN, ALSO THE REMOTE RANDOMLY STOPS WORKING
tomlyndlevjo, Possible failure of internal "switch-mode-power-supply" board in tv. Remote not bad or intermittant!!! SMPS board is detecting "fault condition" and goes into "shutdown mode" to try and "save itself" from catastrophic, nonrecoverable failure. e.g. sparks, smoke, fire!!! If warranty no longer valid option for you, then you or qualified electronics technician will need to investigate SMPS board to find cause as to why SMPS cycles in/out of "shutdown mode" 12fixlouie
Sep 13, 2010 | Philips 32PF7320A 32 in. LCD Television
Standby light
This problems is cause by FBT-Flyback tranformer the big black block of plastic with a red wire with a cap hook to the CRT(tv tube) and the "H" horizonal transistor left side of the steal plate cage of the big black block of FBT.U have soldering tool,and solders?Resolders the FBT,and "H" horizontal transistor will help to stop this problems,if those parts are still goods,not dying.Or might help just leave the tv on 4 or 5 hours,the heat of the tv could heal the cold solders itself.
May 10, 2010 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Tvs stuck on standby
Please can anyone help me, my tv switched off itself cant switch it back on. it is on standby mode tried everything in vain the model is Toshiba 28/32YT56
Oct 09, 2009 | Philips Magnavox 20MS3442 20" TV
We have a large tube pansonic wide screen tv. it sometimes would stay in standby mode and would not turn on when using the remote or channel switches on the tv.. this is getting worse to the point where...
This fault can be caused by low secondary supply voltages often caused by the value of capacitors becoming low and requiring replacements but you will have to have a technician.
SUPER8
Dec 01, 2008 | Panasonic Televison & Video
Philips 29PT9418/69G
A qualified tech will need to practice visual acuity technique! Look at power supply circuit for signs of stress,dis-coloration and/or bad connects.Check for bad 47mf/25v cap in area of stress.Replace BC-327-25 xistor w/BC-328 and replace BC-337-25 w/BC-338,if present in your set's chassis style.
Sep 25, 2007 | Philips 25PS40S 25" TV
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Electro Med Services...
