Question about Saeco Incanto Classic Espresso Machine
Saeco SUP 021 (Y)
Hello! I cleaned my saeco and now the button for purging won't stop blinking. I tried to let the water get out by the little drain (steamthing) but the water will not flow. I already cleaned the pipe....Help!!! I still didn't have my morning coffee!!!
Nicky (holland)
  • 515 Answers
is it the far right lamp that blinking? Then you have to descale your machine.
Is it the lamp in the middle in the bottom row, then you have to open the door and take out the driptray and dregsbox for 5 to 10 sec.
if the water drop flashing then you have to open the steam knob and make a cup of water(tea).
Hope this will help you.
Posted on Aug 23, 2008
Saeco Odea Go machine, red light blinking,
when the red light blinking it means machine must be primed. BUT if you prime it and still red light -you have to change the FLOWMETER.
Dec 24, 2017 | Saeco Odea Go
I have a (saeco) type sup 016 royal proof (app # Q95155) cffee machine and i dont know how it works? pls help.. e-mail tyvm
Hi, first the water tank must be full. Turn on the power button, wait for it to heat up-approx 2-3 minutes. You must purge the air out of the system by pushing the button for making coffee ,and at the same time you must turn counter-clockwise the steam knob(frother). Until you see a steady stream of water then only your system will be purged of air. Make sure to never run out of water, or you will have to repeat this process over again. You will also have to fill the dispenser with espesso beans. Good luck with purging the air, it`s a little tricky but really worth it when you indulge with a nice shot of Espresso...
Feb 22, 2011 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Italia is stuck in the descaling mode. I tried to descale it yesterday and now it is stuck in the descaling mode. I have tried resetting as instructed in the manual and unplugged it overnight. It...
I had this problem too. I was beside myself wondering what to do. I took the machine apart but there was nothing wrong. It was stuck in an infinite descale cycle. The 5 green buttons never blinked to say it was done. What finally fixed it was to close the steamer valve to where water was being being restricted from the steamer wand but still a little water was spurting out. It finally quit emitting water and the 5 lights blinked and the infinite descale cycle completed. This model espresso maker was a lemon and been nothing but problems.
May 18, 2010 | Starbucks Saeco Italia Digital Barista...
The red Water warning light keeps blinking,even there is enough water supply.
It means ventilate, purge the air out of the system by turning on the knob, the pump should run .Keep it running until the red light stops blinking.If not there's a blockage in the line.
Jan 23, 2010 | Starbucks Saeco Italia Digital Barista...
English manual for a saeco sup 021 - decalcifying
You can download it from this link:[1].pdf
Nov 14, 2009 | Saeco Incanto Classic Espresso Machine
Saeco incanto rapid steam Model #SUP 021yr
Try to clean the brewing unit and make sure the filters is clean.
Aug 21, 2008 | Saeco Incanto Classic Espresso Machine
Rinse cycle won't stop
Start rinsing again, when the water comes out, take off the water tank and let the machine go to it stop.
Water light blinking
ok you have a priming problem
press the warm water button and open the valve . Normally that should prime it.
Other wise you have in the box the primer tool of saeco.
Just press the button and push the water in after opening the knob.
give you details.
Apr 07, 2008 | Saeco Incanto Classic Espresso Machine
Saeco incanto sup 021yr
did you ever descaled the machine not with vinegar but with real descaler normally that does the trick 1 part water 1 part descaler not vinegar put it in water cointainer start machine open side valve for a few second close it leave it in there for 15 minute repeat untill empty rinse very good with clean water that stuff is very corrosif cheers
Jan 23, 2008 | Saeco Incanto Classic Espresso Machine
Saeco magic de luxe cleaning grinder
I don't know what you mean by disarming the grinder. Unless you are talking about using the bypass. If that is the case there is a button on the panel that has waht looks like a scoop. Push that button and put a scoop in the bypass door and then push the button for what cup size you whant. Regarding the taste of the coffee. It may need a cleaning and service. Try googling "saeco repair" and find an authroized Saeco repair center and have a good service done on it.
Aug 20, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Incanto Classic Espresso Machine Logo
1,392 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
