Question about Samsung Televison & Video
Changing Regional setting on Samsung DVD - Samsung Televison & Video
  • dancer rick Jan 30, 2009
    Hello thank you for your responce on how to unlock my Samsung DVD player. However the player I have is just called the DVD-1080P8 with out the XEU DVD. I don't know if there is a difference but the instructions I got did not work. Is there another way, Thanks cheeers
  • 10,594 Answers
Here is the procedure, perform it with care and at your onw risk..because I found it on web...
1. Press the Menu button on your remote control
2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the onscreen display
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Posted on Aug 23, 2008
SOURCE:
I own a 5-DVD Changer with a Home Theatre System. It is an LG Model # LH-E932TB. It was working great then all of a sudden it now says ''CHECK REGIONAL CODES''. Does anyone know what to do...
Have you changed the Regional Code of the DVD changer? Changing of Regional Code of the Changer is permitted for 5 times. To view movies of different region code, some people change it. Suppose you or someone have viewed a movie of different region movie after changing the region code & now you are trying to view a DVD of your region. In this case you will have to change the region code to your region. Changing of region code is available through the setup of the Changer.
-sonsunny
Jul 09, 2011 | LG Audio Players & Recorders
My DVD player won't play the DVD. It tells me to check the regional code. What is a regional code?
a regional code is something embedded in a dvd so it can only be in the region of the world where the dvd was ment to be sold. In North America the letters NTSC are seen on all DVD's and games. In europe it says PAL. Look for the letters on the dvd.
Oct 17, 2010 | Samsung DVD-V5600U DVD Player/VCR
Changing region code to all on a LG DV550 DVD player?
icon_minipost.gifRegion code hack posted by hackaroto, December 27 2010:
1. Switch off the DVD player in to Stand By mode
2. Open the DVD tray using the remote control
3. Press "pause" in the remote
4. Enter 0, 0, 0, 0 (zero 4 times)
5. The display should indicate the regional code set in the DVD and prompts for the new regional code.
6. Enter the new regional code
7. Press Pause to exit the setup
8. Switch off the DVD using the remote and wait for a while before switching it on again.
works for other LG DV55X players
Aug 03, 2010 | LG Televison & Video
A DVD bought in Australia cannot be played in a samsung htz310i dvd player in the UK
Brigid,
The world has been fenced off into areas by these manufacturers, and you Aus DVD is security locked to Code 4.
The UK has a different Area code, and your Samsung was setup to play only DVD,s sold in Europe.
However a knowledgeable friend with a computer can play another areas disk by changing the area code in the computer.
Cheers
DeJudge
Sep 11, 2009 | Samsung Televison & Video
Regional codes
you can buy or download a disc that you put into the dvd player and it will unlock it to all regions
Jul 26, 2009 | Samsung DVD-V6800 DVD Recorder/VCR
DVD'S will not play..
Sounds like the unit is bad, or set to the wrong Regional Code. Its not easy to set the regional code and it varies by model. You are better off buying a new DVD player given they can be found for under $30.
Aug 28, 2008 | Samsung DynaFlat CXM2785TP 27 in....
Samsung DVD-P171 Player
Follow the instructions on the following page to change the zone of your player:
http://www.answerbag.com/q_view/775274
I followed the instructions without updating the firmware and it worked for me. Hope this helps.
Jan 19, 2008 | Samsung DVD-V90K Multisystem DVD/VCR
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Televison & Video Logo
96 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
