DeLonghi BAR 140 Espresso Machine Logo
Posted on Jun 27, 2011
What is a DeLonghi crema disk? I have a DeLonghi Caffe Cortina ModelBCO-250, but no Crema filter.
4 Related Answers
A
Anonymous
  • Posted on Aug 31, 2007
SOURCE: failing delonghi espresso machine ed140
check the filter holes. They might need to be cleaned with a needle.
Anonymous
  • 25 Answers
  • Posted on Jan 08, 2008
SOURCE: UNABLE TO GET GOOD CREMA ON TOP OF COFFEE:
It could be. Your grind should determine the amount of time that it takes the shot to pour. Standard is 18 - 30 seconds. I prefer 25. If it only takes 10 sec, your crema will be weak.
Are your beans fresh? Older beans produce less crema. By old, I mean more than a month if properly stored.
What is the temperature of you shots? The water coming out of the head should be about 195 F which makes the shots roughly 170-185. If it's too cold, you'll get worse crema. It's also possible to have mostly steam in contact with the grounds which will give the same results. Both indicate other problems.
Make sure your group head screen isn't clogged. And make sure everything is very clean, especially inside the handle (under the grounds basket - just pop it out with a screwdriver). Good luck!
Anonymous
  • Posted on Jan 28, 2009
SOURCE: Heat
Hey Nashville,
I have a few suggestions/questions for you. I've had the Innova(Ascaso) Dream for several years now and use it at least twice daily. I would trust your own senses before sweating the gauges too much. If you're really worried about it being a temperature problem, my first question is whether or not the espresso is actually hot when it comes out.
But my best guess is honestly your beans and grinder (or lack thereof). The problem with using pre-ground beans is that even on the day you open the can, they won't be nearly as fresh as truly fresh ground beans you grind yourself. And the problem gets dramatically worse every day after they are opened.
The key to a thick, crema-laden espresso is very fresh beans that you grind right before making your espresso. You can certainly confirm that the machine is working with any old coffee grinder and a bag of *really* fresh beans from a local roaster.
You really need all the oils that come with really fresh-roasted and fresh-ground beans. And the beans really need to be ground very fine for espresso.
I keep a can of pre-ground Illy decaf beans around for the rare occasions I need to make a decaf, and it's like night a day between that and what I drink daily.
If you try the fresh beans and grind them yourself and can see the obvious difference, then you may want to invest in a good-quality burr grinder (as opposed to the spinning blade kind that most folks use for drip coffee). The reason is that with a burr grinder you can get consistently-sized particles every time. So once you get the setting right on your grinder you can keep pumping out the shots time after time. With a rotary blade grinder you get some big pieces, some little pieces and the water flows through too easily -- or you grind it longer and (1) burn the beans from the heat, and (2) end up with some particles that are just too small -- essentially dust, that will actually clog the process.
So, my best suggestion would be to find a local cafe/roaster and buy a half a pound of beans from them and grind yourself. If you don't have a grinder or want to eliminate a variable, ask them to grind it for you for an espresso machine.
Again, if you can see the difference (and I think you will), then you can consider getting yourself a good grinder.
Tony
Tom Torre
  • 279 Answers
  • Posted on Sep 18, 2009
SOURCE: I need instructions for a DeLonghi CAFFE nabucco
goto deloghniusa.com. They may have it there
Why can i not get crema?
bring the cup up to the spout, without submerging it
Where do I find the schematics/drawing of internal parts for Briel Cadiz Espresso maker
I just bought a new Briel Cadiz and it doesn't make crema. I tried my old Briel crema filter and it works fine making good cream. I was told to untighten the screw in the new crema filter but the screw just goes round and round, even with an electric drill. Can't tighten it or loosen it. Anyone got any suggestions?
1helpful
New machine but no crema.. very disappointed
I have the same machine with excellent crema. You need to be sure you are using a high quality burr grinder on the fine setting. Also be sure to tamp using a tamper for even compression. The espresso should come out SLOWLY and smoothly... it will end with a great crema.
Broken handle on filter holder
Hi
Yes, you should be able to buy them. Let me know if you can't find one, cause I have one.
My Koala espresso machine pours slowly then sprays
SOUNDS LIKE BLOCKEDGE PROBLEM SOKE ALL SPRAY JETS IN WARM SOPEY WATER AND CLEAN .
DeLonghi EC140 Espresso filter
Why is the coffee not flowing aas fast and why is the crema not consistant?
Failing delonghi espresso machine ed140
Sempre Crema
before changing the filter, try cleaning it following the instructions in the manual(page 9, i'll attach it to my post). The Delonghi web site also offers the following solution: "The coffee may have been ground too coarsely or the grounds may not have been pressed with a tamper. Also check to make sure that the coffee is not old or stale." Parts are supposed to be available from the delonghi website(www.delonghi.com), but i couldn't find where they hid it. but there's an option on the site to go to local sevice centers, lets say you live in canada, then you pick the canadian website from the pull down menu on the top, the customer support tab, then service center on the left. Good luck
Top DeLonghi Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
