SOURCE: door open error on frigidaire affinity atf6700 washer
hello, it sounds like you have a bad door latch that needs to be replaced if you need a web sight on were to order one let me know and i'll find the part for you.
SOURCE: my Frigidaire affinity washer doesn't
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
SOURCE: Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
SOURCE: I have a Frigidaire Gallery GLTF1040ASO front load...
For general advice on cleaning a washer lint filter, try http://www.ehow.com/how_2083872_clean-washing-machine-lint-trap.html
