Question about HP Photosmart C6180 All-In-One InkJet Printer
Printing Problem Hello, I would like to no what this problems is for my HPC6180 - EXT_PRN. do you have any solutions? Thank-you
  • Kristian Kate Cajoles May 11, 2010
    where are you prompted? on the display of the printer or on the computer??
Paper jam.
Even after I check out all areas.
Open and close all trays and neatly stack paper so on and so forth.
sometimes, print two pages then paper jam for no reason. Very long and tedious process to remove error message.
Thank You,
Clint
Posted on Nov 28, 2008
Why is Kodak printer printing bank pages when ink ull
You might have a printer head problem or a technical problem. Go through these steps and make sure that you not low on ink.
1. unplug for a few minutes and re-plug, try printing. if not working,
2. Do a printer head cleaning function, if not working,
3. Remove printer head, clean it, put it back and try again, if not printing, then
4. If you have a spa
re printer head, try that one and see if it prints. if it prints, get a new printer head.
5. If after cleaning printer head you tried a test page and failed to print and printer head is totally dry, first try cleaning the contact area with alcohol solution or use a printer head cleaning kid if you have one but don't invest a lot of time and money in buying cleaning material.
6. If all failed, your printer has a technical problem you cannot resolve, call Kodak support and ask for possibility of a free replacement. They may ask you to upload "data diagnostics" under printer tools and if the problem confirms, they may agree to send you a new replacement. Good Luck.
Oct 14, 2014 | Kodak Office Equipment & Supplies
I have designed a software to print visitor badges on spot for conferences but i am unable to send the print command to my Brother QL-570 Label printer ..I am not able to generate a .prn file .. please...
Welcome to FixYa.
To generate a PRN file, you need to have the printer driver installed in your computer. You should be able to see the PRN option (in some cases, it is termed as 'save to file') in the printer dialog box.
In your own software, you have to use the printers driver as well to produce a PRN file as well.
Since you are also unable to send the print command to your printer, it seems that your printer driver is not present or might have been corrupted.
Download and install the driver for your printer from >>HERE
Thank you for using FixYa, have a great day.
Jas247
Jul 24, 2011 | Brother HL-2040 Laser Printer
I require a .prn file for my cx400 for my software support person to design the barcode string to be used for my software to create the barcodes. my barcode printer is Sato CX400 & the software I am...
HI ...
1.I am using Sato CX400.my printer problem is when i give Command for printing copy (default by prn file one copy) but print out two copy and i wastage lots of label .so please help me about my problem.
2. i have sato Cx400 two printer but in both printer font is Bold & another is UN bold.so how make both printer setting same
Please help me by mail (bvionline@yahoo.co.in)
Thanking You
Jun 21, 2011 | SATO CX400 Thermal Label Printer
HOW CAN I PRINT FOLDER CONTENTS SIMILLAR TO THE DOS CAOMMAND TREE > PRN
Go to start button. In the start menu click RUN and in the box that opens type "cmd"
In the CLI go to the directory of the folder whose content you want to print and type the following and press enter to create list.txt file first before printing.
dir /b /s /on >list.txt
This will give you a text file (list.txt) in the folder, that you
can manipulate, print etc. in a text editor or
word processor. In order to redirect the output
directly to your printer, instead of a text file, type:
dir /b /s /on >prn
Aug 25, 2010 | Microsoft Computers & Internet
Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
May 07, 2009 | Adobe Acrobat 7.0 Professional
EPSON LQ 1150 Roman letter two last two Can not print in foxpro
best way to come out of this problem is to fire your printing using an batch file
ex.
set print to scrn.txt
set prin on
? 'hello'
? 'welcome to fast printing'
set prin off
set prin to
run fastprin
create fastprin.bat file
edit fastprin.bat
@echo off
type scrn.txt >PRN
then execute the above program
Mar 04, 2009 | Epson LQ1170 Matrix Printer
I am using Epson LX-300+ Matrix Printer. But it is printing very slow on foxpro. Even I am using basic fonts. How to increase the speed of printer.
ex.
set prin on
? 'hello'
set prin off
set prin to
run fastprin
edit fastprin.bat
@echo off
type scrn.txt >PRN
Feb 25, 2009 | Epson LX-300 Matrix Printer
Prt scr key
After you press print scr, it won't print to printer, you need to paste it in application such as paint (come with ms windows) and from there you can print it to printer.
the combination key,
try press prn scr only and paste it in paint application.
if it isnot working, try using shift+prn scr.
Feb 18, 2008 | Dell Inspiron 1000 Notebook
Hplaserjet printer 1018
Keeps printing what? same page over and over? or blank pages?
install the latest driver
Jan 09, 2008 | HP LaserJet 1018 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
87 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
