Question about Zoom Wireless-G 4410 (44100000) 802.11g/b
My computer restart after 15 mins give solution
Hi sir ,
Maybe smps or motherboard problem
Posted on Aug 23, 2008
SOURCE:
94 olds cutless supream 3.1 starts runs then stops running after 15 mins
Have you had the computer checked for trouble codes,that would be the first step.If you have then start testing separate componets,coil, ignition module,etc.
Jul 02, 2012 | 1994 Oldsmobile Cutlass Supreme
Sir i got a viewsonic lcd 19" model 1918 it
Let the unit cool down for 30 min., give proper ventilation because your processor have a heat sensor, once reached the peak temp the unit will automatically shuts off. Keep away all the obstruction from your vent.
Let me know if the symptom is still there...
Thanks for using fixya.
Feb 02, 2011 | ViewSonic VX910 19" LCD Monitor
Every 15 min wii netflex cuts out says lost sig or something like that -try again or reconnect, have to restart comp to get it back every 15 min
what you should do is first contact wii,if they give you rubbish information,tke out your game gently blow into the disc recever or take it apart and give evrything a good old tweak.
note1:do not hit your console ever,never ever,because it could damage your console.
note2:gently tweak evrything otherwise,YOU CAN SAY GOOD BYE TO YOUR CONSOLE!!
thank you for reading.
Jan 16, 2011 | Video Game Consoles & Games
Good day sir, my radiator leaks coolant from under the radiator whenever i put on my a/c and it runs for a while. it started with the coolant bottle boiling & over flowing. please i need your help
hi sounds to me that your rad is blocked or sprung a leak first drain the rad and then refill with a rad flush run the engine for about 15 mins then drain be careful it will hot /when your engine is cool fill useing rad weild or another brand run this for another 15 min drain and refil as normal if this dose not work i think your looking at a new rad hope this helps if so please give me a rating best of luck pete
Nov 24, 2009 | 1998 Jeep Grand Cherokee
Computer keeps restarting itself after about 10 - 15 mins.
Start the PC, Click Start > Right Click on My Computer > select Properties > Advanced tab > Settings (in the Start up and recovery section) > Unckeck the box next to "Automatically restart" under "System failure". > click "OK" > click "OK" again. Restart your PC and give it a go.
Apr 20, 2009 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
Dell inspiron 9300 getting hang or restart after every 15 min
Sounds like your hardrive is starting to fail-backup all files!!!
Apr 12, 2009 | Dell Inspiron 9300 PC Notebook
Motherboard
Hi Sir! my problem is that when i start my computer it doesn't starts instead it gets restarted automatically and doesn't starts Windows,it gives me 4 options ,one of them is "Start Windows Normally"but even after Starting Windows Properly it restarts.Sometimes it also gives BIOS Update message.
Kindly tell me what to do.
Thanks!
M.Mujtaba .
Sep 21, 2008 | Mercury P4VM800M7 Motherboard
Sony PC
is it fixed 15 mins or its a round figures. does i happen without any fix time. the options are normal like save mode, normally etc...
have u checked ur processor's fan. is it normal or resists to run. it can happened b'coz of it also. also check ur ram too.
regards,
Jul 31, 2008 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
Monitor
ferozkhan, It could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. Depending on the monitor this is usually an economically repairable problem. Let us know if you have any other questions and please don?t forget to rate this posting.
Apr 25, 2007 | IBM E74 17" CRT Monitor
Open Questions:
See all Zoom Wireless-G 4410 (44100000) 802.11g/b Questions
Zoom Wireless-G 4410 (44100000) 802.11g/b Logo
23 people viewed this question
Top Zoom Computers & Internet Experts
Paul Castley
Paul Castley
Prashant M
Prashant M
Ekse
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
