Question about Pentax Optio 330GS Digital Camera
Black LCD screen on camera
I have a Pentax Optio 330GS. I have it for a little over a year. All of a sudden the lcd sceen is black. It will show the pictures on the memory stick, but nothing else. Does anyone know what the problem is?
    Master:
  • 542 Answers
Just had the same problem (black display). I moved my hand in front of it and took pictures of things but nothing happened. Then my girlfriend tried to point it to a lamp, and all-of-a-sudden it kinda woke up from a screensaver or something. So weird, but it worked. Perhaps it needs enough light in order to start using the display and lens. I couldn't take any pictures when the LCD was black. So, try pointing it towards a strong light source before you break your camera.
Posted on Aug 30, 2005
SOURCE:
Monitor shows white out screen
You can try firmaware update (below link) if available for your model.
http://www.ricoh-imaging.co.jp/english/support/download_digital.html
But the reason could be also the LCD screen connector inside the camera. So it may need service.
Sep 01, 2013 | Pentax Cameras
I ahve the pentax optio s6 camera. the camera
Hello
Thank you for using FixYa for your problem
Sounds like the LCD is faulty, but there are a number of things that can cause the LCD to play up too
Always check the batteries first (check that the voltage is correct with a volt meter) but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Pentax Optio S6 Digital Camera
Lcd screen is black with a few horizontal lines.
compre uma nova pois essa ja era, mas naum se desespere ainda..... fogo rsrsrsr
Jun 05, 2009 | Pentax Optio M30 Digital Camera
I have wo black bands across the screen on my Pentax Option 550
have you tried changing the camera's settings back to default? in the camera's menu, find 'reset settings' or 'factory settings' or something like that to reset the camera settings.. you might have messed with some settings, otherwise it may be hardware failure, may be the LCD of your camera.. hope not so.. lol
Feb 24, 2009 | Pentax Optio 50 Digital Camera
Pentax optio s6
perhaps mazzachris would be interested in unloading his/her E10 LCD to me?  My E10 LCD is cracked.
Sep 03, 2007 | Pentax Optio S6 Digital Camera
Flash hi, good day. Please help me with my digital camera, when i'm taking a picture at night or in a dark palce, my optio 330gs wouldn't flash, so, the result is black and even in the screen is...
Check the manual throughly- usually there is a more comprehensive manual on the CD- to ensure all the correct setting are made. Other wise this is a flash failure[lamp or capacitor] Take a look at the Pentex technical support site.
Jun 02, 2007 | Pentax Optio 330GS Digital Camera
Pentax Optio 330GS its gone blind!
You've probably got something as simple as a ribbon cable loose in the camera. Beware though, dismantling is a serious task unless you have experience. Amazingly the CCD is often connected in such a simple, analog-esqe, way that disconnecting it doesn't cause an error, just a black screen.
Sep 08, 2005 | Pentax Optio 330GS Digital Camera
Hi! Just had the same problem (black display) on a Pentax Optio 330GS(?). I moved my hand in front of it and took pictures of things but nothing happened. Then my girlfriend tried to point it to a lamp, and all-of-a-sudden it kinda woke up from a screensaver or something. So weird, but it worked. Perhaps it needs enough light in order to start using the display and lens. I couldn't take any pictures when the LCD was black. So, try pointing it towards a strong light source before you break your camera.
Sep 08, 2005 | Sony Cyber-Shot DSC-P31 Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Pentax Optio 330GS Digital Camera Logo
139 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
