Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Compact Presio V2000
Im have trouble starting up with the \windows\system32\config\system error and i dont have a Windows Setup Disc it brings me to PhoenixBIOS Setup Utilities when i hit f10
  • 446 Answers
The boot files are corrupted, you might want to reinstall your windows, or repair this through software
Posted on Aug 28, 2008
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
Saying:/windows/system32/config/system is missing or corrupted n i dnt now how to fix it wut link exactly do i have to download to my usb to fix it n wut r the steps?
Assuming it is windows XP here are the steps to fix that error:
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:md tmp
My YouTube Channel
Click Here Live Tech Support
May 03, 2013 | ASUS Eee PC 2G Surf Notebook
Hi guys, my notebook 0xc00000e9 this problem and how I want to save or return all my program really work? I need to go back but I do not want to format? need to save my back as folders? I hope you...
This error indicates a corrupt registry. Luckily, when Windows is installed, a pristine copy of the registry hives is also installed and it remains untouched...replacing your corrupt registry hives with these ones will allow you to boot your operating system again. You may have to reinstall a few programs and drivers but all of your data will remain intact and you really won't lose anything. I will describe the process to you. I will also include instructions on how to back up the current registry in case you want to go back to it for any reason.
First you will need to locate the Windows install disc. If you don't have one you can borrow one as you will not need a key to perform the steps.
Put in the disc and perform the steps necessary to get your computer to boot to it.
Once you are the "Welcome to Setup" screen, press R to go into the Recovery Console.
Enter the administrator password when prompted
Tell the program what installation of Windows you would like to recover.
Now for the commands
md tmp (this creates a directory labeled tmp)
These 5 commands will make a copy of your current registry hives and back them up to the tmp directory. Type these in first. ENSURE you back them all up.
These 5 commands will delete the current, corrupt registry hives.
These 5 commands will copy the pristine, uncorrupted hives into your system.
Once you have entered your last command type exit to leave the recovery console and your computer should restart.
If you want to put the old registry back for any reason, simply follow the same steps but instead delete the current registry and replace it with the files that you placed in the tmp directory. Ensure that you remove the .bak extension from the file when you copy them over.
Really, other than this, the only other known working option is to reformat your computer.
Hope this helps.
Jun 27, 2011 | Computers & Internet
What should i do if my windows\system32\config\system is missing or corrupt
Hi
try to restore system or repair the windows
you can try so copy the folder from another good running windows
Apr 25, 2011 | Gateway 310X PC Desktop
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
Windows XP Missing configuration?
Sounds like you may have bad RAM. Try removing all of the RAM modules on your motherboard and put only one in the first slot. Start the computer and see if it works.
Jun 17, 2009 | HP L1706 17" LCD Monitor
Start up problem
There is nothing you can do without the setup disk to run recovery.
May 19, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Toshiba laptop problem
boot your laptop from a xp cd and select repair option
Sep 30, 2008 | Toshiba Satellite A105 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
