Question about Maxtor Hard Drive
Harddisk i am geting messages saying my maxtor external harddrive is corrupt and access denied. i do not want to format the disk as all my songs is on there and i will lose them. thanks any help will be greatly appreciated. chris
  • chrislawcu30 Aug 24, 2008
    hi lafalot thank you for the reply. when i first got the problem i was writing a song on the computer using my music sequencer.
    yes given that the maxtor is an external disk, yes i have disconnect and reconnect it again.
    am still geting the same access denied message.
    when i try using maxtor utility it clicks okay but nothing happens. stii the same message file corrupted access denied.
    thanks once again lafalot
    chris
    Scholar:
  • 152 Answers
Can you recall what you were doing when you first got that error message? Try disconnecting the drive and then reconnecting it. If you still get the same message, check the Maxtor utility to see if there is some type of repair procedure that you can do without reformatting it.
Posted on Aug 23, 2008
SOURCE:
Unable to delete files in maxtor onetouch iii mini
Access can be denied for several reasons - if the file is in use or even part of it - try dragging the folder or file to your desk top and then delete it
May 07, 2010 | Maxtor OneTouch III Mini Edition 120GB...
My harddisk drive is corrupted of damaged!!
Maxtor has merged and become Seagate. Here is the site for India warranty information:
http://www.seagate.com/ww/v/index.jsp?locale=en-GB&name=india-warranty&vgnextoid=47e815dfc9a86210VgnVCM1000001a48090aRCRD
Or just click HERE
Good Luck!!
Apr 03, 2010 | Maxtor Hard Drive
Maxtor external harddisk recognition problem by pc
Hi Maxtarm,
It sounds like either the drive or enclosure is failing rather quickly.
The first and cheaper solution is to take the drive to your local computer shop and have the techs there move the harddrive into a new enclosure and test it. If it works in the new enclosure, you're done, but please take my advise and never rely on a single copy of your files. Always keep your important files in 2 or more places, on your computers hard drive, external drive and a backup to CD's or DVD's you can store in a firesafe or friends home is a good idea.
Now assuming that change of enclosures doesn't work, you will need the help of a recovery pro to get your files back. If that is the case comment back here with your location (Country, state, city) and I will advise you on a reputable recovery provider in your location.
Hope this helps Fixya,
Chris
Jul 15, 2009 | Maxtor Computers & Internet
Maxtor basics 160gb portable hard drive is showing error performi
go to my computer p[roperty then hardware -> device amnager then uninstall usb drivers from it then install aagain.
then connect your harddisk then it found.
Jun 23, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
Access denied on an external harddrive.
quick fix is to format the hard drive.. otherwise you'll have to get your data back with a seperate program...
Jun 01, 2009 | Seagate FreeAgent Pro 500GB External USB...
Data disappeared overnight
I've seen a lot of flack about these puppies lately. It's usually due to the external enclosure, the harddrive is in, and not the harddrive itself.
It is for this reason, that I suggest that you take the harddrive out of this enclosure, and install it into a decent, affordable, new external enclosure.
External enclosures are relatively cheap!
The harddrive inside the Maxtor One Touch II is a desktop size harddrive. It's a 3.5 inch one.
(3 and a half inches across in width)
It is a Sata harddrive.
These are examples of external enclosures for a Sata 3.5 inch harddrive,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(My recommendation would be the Vantec NexStar 3 NST-360 Su-BL)
This external enclosure has instructions, is easy to install the harddrive, and uses a USB cable just like your old one.
May 14, 2009 | Maxtor OneTouch II external hard drive...
Computer doesnt detect chrashed harddisk so that to recover data
Your going to need a technician that specializes in hard drive data recovery.
Nov 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Local Disk(D:) is not accessible Access is denied
first u have format the c:drive the problem is solved
if not u should format all over the system
Feb 20, 2008 | Computers & Internet
Seagate harddrive diskread error
go to bios and see there whether it is showing showing your hard disk or not if it is showing then re-install your XP again format your hard disk with the slow formating option,while re-installing it.
Nov 23, 2007 | Asrock GE PRO-M2 Motherboard
External Hard drive Failure
Seems to me like your MFT of FAT is corrupt. You can go ahead and do a format on it by right clicking and going to format. You should then be able to copy your backed-up files back onto the drive.
Nov 12, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Hard Drive Logo
155 people viewed this question
Top Maxtor Computers & Internet Experts
Ekse
Phil Whisenant
Phil Whisenant
Alun Cox
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
