Resistor has failed and heated in home theatre amplifier
Yahmah RX-V1070, reisistor component circuit board number R218 has shorted and overheated. The banded coding colours are discoloured on the resistor and I do not know the resistance value of the component.
Can you help?
Kim.
[email protected]
  • kimrusch Aug 23, 2008
    YAMAHA RX-V1070 home theatre, resistor that has failed and overheated has been removed from the circuit board. The component part on the board is R218, but because of the heat, the colour coded banding on the resistor has faded and is unreadable. Can anyone advise what reisistance value this component has?
    Kim
If your are still looking for this...
According to the service manual, R218 is a flame proof carbon resistor of value: 4.7Kohm 1/4Watt
Marc
Posted on Mar 06, 2009
SOURCE:
I recently revisited my car after a few weeks out of my hands, and seconds after turning the key and the unit powering up, the sound of popping and shrapnel in the amp was heard and the smell of smoke...
What has probably happened is a short somewhere in the amplifier. Here are some possible scenarios:
1. When the new capacitors were installed, make sure that no solder shorted any pads on the circuit board to anywhere else.
2. There is probably a resistor upstream of the capacitors that has shorted but still appears to be fine. Look at the circuit board & follow the traces that connect to the 2 terminals of each capacitor and follow them to other components. Examine them very carefully. Pull on the wire terminals of upstream & downstream components to ensure they are solid. Check each side of the component with an ohm meter. If a zero resistance is given, or no (open) resistance is given the component could be in question. To properly check it out, one side of the resistor must be pulled up from the board, then check the resistance again. If out of spec, it would need replaced & then it would properly voltage limit the capacitors, keeping them from going up in smoke.
3. This can be a very tricky problem without a schematic. See if you can get your hands on one, it makes circuit tracing much much easier
Mar 17, 2011 | Kenwood KAC-9104D Car Audio Amplifier
RX-V1070 tuner fault
This only a cold solder symptom in tuner section .Just reworks all solder joints components parts in tuner section.
Good luck:
Regards:
Dont forget to rate.
Jun 30, 2009 | Yamaha RX-V2700 Receiver
Picture shaped like a bowtie, (shrinking)
Hello, This is your classic convergence Amplifier IC problem. Here is a way to deal with it. These are generic instrustions: 1) Get the schematic/service manual for this TV (You will need it because it contains the part numbers and component values you will need for replacement) 2) On the schematic/service manual locate the convergence amplifiers (STK392-110, 120, 150) and the biasing resistors (Write the resistor values down from the schematic) 3) Unplug the TV and remove the rear cover to expose the electronic circuitry. 4) Using the schematic/service manual find the physical location of the two convergence amplifiers (Usually attached to a big metal silver in color heat sink) (Basically it will look like two big black six sided flat modules with a lot of pins on the bottom (18-22 to be exact)). 5) After finding the heat sink and amplifiers remove the screws or the tension bar holding the amplifiers in place. 6) Using a soldering iron and a de-soldering device (either a de-soldering pump or de-soldering wick) remove the solder from the pins of the amplifiers and biasing resistors that protrude from the solder side of the circuit board. (Take into mind that you may have to remove the board in order to do this, use the instructions in the schematic/service manual to do this, and make sure you mark everything you remove to make sure you have a guide as to how to put it back) 7) After removing the solder from the pins off the amplifiers and the biasing resistors, remove the resistors making a list of the value, part number, and location on the board (all of this should be in the schematic/service manual). Then remove the two convergence amplifier modules taking care so as not to damage the circuit board. NOTE: The heat sink compound (the white goopy stuff) may have hardened and caused the module to stick to the heat sink, you will have to gently pry the module away from the heat sink, I have used a light application of isopropyl alcohol to dissolve the heat sink paste. 8) Once the modules are loose from the heat sink, you can gradually remove them from the circuit board. 9) Clean the heat sink off by using the alcohol and a heavy paper towel (remove all of the heat sink paste, and yes this is messy) At this point you have removed the two convergence amplifier modules and the biasing resistors and cleaned the heat sink. Now you will have to use your schematic/service manual to find the part locations, values and numbers you will need to replace the old parts I suggest replacing the biasing resistors first. 1) Sort out the resistors you will need and as stated in the schematic/service manual and replace them according to the schematic/service manual locations and part numbers. 2) Solder the components (resistors) in place making sure not to short out anything in the process. 3) Apply heat sink paste to the metal side of the modules one at a time and the put the modules into the circuit board lining up the screw holes of the modules with the screw holes in the heat sink, use the removed screws or tension bar to hold the modules down once in place in the circuit board and on the heat sink. 4) Solder the pins of both amplifier modules to the circuit board, taking care not to short out anything. 5) Reinstall the board to the TV, reconnect all cables removed (DOUBLE CHECK EVERYTHING) If all went well the convergence amps should be working, and you will need to realign the convergence of your TV, I suggest using the AUTO Convergence feature of your TV (Use the instructions in the schematic/service manual). All should be good now. Now these instructions are generic in nature but can be use for a number of Models of Projection TVs. In addition to this also make sure your Yoke transformers on your CRTs are functioning as they should, check the voltages applied to them. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 10, 2009 | JVC AV-56WP30 56" Rear Projection...
Blurred picture, colors not aligning.
Hello mekysor,
You have a convergence amplifier problem. This is a common problem in these types of televisions. The fix for this problem is to replace the two convergence amplifiers in your tv. These amplifiers usually go bad along with the associated bias resistors. I would suggest that if you are going to do this yourself you should use only the manufacture recommended replacement parts. There are many who will tell you to upgrade the amplifiers, but my experiences have told me this is more trouble then it is worth, if you don't plan on redesigning the circuit itself. So with that being said, here is the basic procedure:
1) Get a schematic for your set (to be used in parts location and alignment instruction)
2) Using the Schematic locate the STK329-xxx or STK392-xxx series amplifiers (They are the two large six sided components attached to a large heat sink on the deflection board)
3) unplug the TV set
4) remove the deflection board from the TV set
5) using a soldering gun or iron with either a de-soldering pump or de-soldering braid remove the solder from the pins of the amplifiers and the associative biasing resistors.
6) remove the amplifiers from the heat sink and clean the heat sink off with alcohol or a solvent designed for removing the silicon paste.
7) coat the metal plate of the new amplifiers with heat sink paste and install them on to the heat sink.
8) install the associative biasing resistors
9) solder all of the components, making sure not to create solder bridges (short circuits) on the printed circuit board.
10) inspect the soldering job for bridges and cold solder joints (touching the joins up if they are cold)
11) reinstall the board to the television (reconnecting all cables removed.
12) power up the TV and perform the alignment instructions in the schematic
13) set the alignment of the TV
14) perform the magic focus setup
This should complete this task.
Now if you feel that you can not do these tasks, please consult a qualified TV technician about doing this for you.
I hope this helps
Thank you,
Shuttle83
Jan 17, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Blue and yellow outlines
Hello steveandlill,
I posted this before, however I believe it fits your problem too:
You have a convergence amplifier problem. This is a common problem inthese types of televisions. The fix for this problem is to replace thetwo convergence amplifiers in your tv. These amplifiers usually go badalong with the associated bias resistors. I would suggest that if youare going to do this yourself you should use only the manufacturerecommended replacement parts. There are many who will tell you toupgrade the amplifiers, but my experiences have told me this is moretrouble then it is worth, if you don't plan on redesigning the circuititself. So with that being said, here is the basic procedure:
2)Using the Schematic locate the STK329-xxx or STK392-xxx seriesamplifiers (They are the two large six sided components attached to alarge heat sink on the deflection board)
5)using a soldering gun or iron with either a de-soldering pump orde-soldering braid remove the solder from the pins of the amplifiersand the associative biasing resistors.
6) remove the amplifiersfrom the heat sink and clean the heat sink off with alcohol or asolvent designed for removing the silicon paste.
I hope this helps
Thank you,
Shuttle83
Jan 16, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Convergence problem
Hello nursecmp,
You have a convergence amplifier problem. Now you have two choices: 1) fix it yourself or 2) Get it fix by a qualified TV repair person. Granted if you choose the latter, you will spend about $200-$500 depending on the shop. So as you stated you would want to do this yourself. OK, I will not get into the problems with this, rather I'll give you the basic procedure and the you can search fixya for a more in depth solution (I'll show you how to do this after the basic instruction on how to replace the Convergence Amplifiers (I rarely give these instructions) Here goes:
Jul 18, 2008 | Philips Magnavox 51MP392H Rear Projection...
Tv wont turn on
1024x768 Normal 0 Won’t start
The power supply has an automatic shutdown circuit that senses a shorted component and excessive current flow.
If you can access the convergence board and remove the plugs one at a time (red, blue or green) for the convergence output, the TV may start up and show a picture with the unplugged color misaligned.
This confirms a short in the convergence output. The convergence IC failure can show up as coloured outlines or power supply shutdown.
If this does not help, then there is some other short circuit in power or deflection circuits. You need a technician to troubleshoot HV or power problems.
Replacing the output amplifiers (located within the Convergence IC's) allows the pictures to line up correctly, and no more color outlines or power shutdown.
This is the most common fault in all makes of rear projection TVs.
Some models of TV require major disassembly and considerable shop/manufacturer's support to repair because of their design that causes other power supply or vertical deflection problems. The poorly designed products require a "bench" repair that can typically cost from $350 t0 $700.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung and Hitachi.
It is normal to have some resistors in the circuit burn up or increase in value from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced with the right value or the chip will fail again.
This is not a simple repair like changing batteries or a fuse. Reading through the other posts shows many that try and end up with bigger problems.
Your JVC uses STK 392-110 IC's. Misinformed people replace the IC's with other "new and improved" IC's, like STK 392-150. These are devices with different characteristics and require different value resistors in the circuit. Replacing with the STK 392-150 will cause overheating of the resistors and a damaged IC.
If you are in Calgary, I can help. If not, get someone that has experience working on your JVC. My website is below with some costs and explanation.
calgaryconvergencerepair.weebly.com/convergence-explanation.html
Good Luck,
Easyab
Jun 26, 2008 | JVC AV-56WP74 56" Rear Projection...
Possible short or maybe thermal breaker?
It is normal to have some resistors in the circuit burn up or increase in value from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced with the right value or the chip may fail again.
Good Luck,
Easyab
Jun 22, 2008 | JVC AV-56WP74 56" Rear Projection...
Sony dav-sc5 power problem
it is power regulator ic and must be changed.
you must check around ic pins for short capacitor or burnt resistor to complete your job
Nov 01, 2007 | Sony DAV-SC5 System
Phillips 42FD9954 plasma will not turn ON
I have a Phillips 42FD9954/17S and every time I try to turn it on I also get the power red light blinking and sometimes it will try to turn on with a bunch of clicking noises and it will be green for a while then turn red. What I do and its very weird but works, put a blow dryer on hot and blow it under the tv on the side of the power button for about 10 minutes and it will turn on. I took it apart and there is a heat sink that if i put the blow dryer directly onto it on heat it turns on in less than a minute. Can someone tell me how I can fix this heat sink? I cant take it off. I want to put some thermal compound to see if that works. Give it a try I promise it will work. The Red Light has to be on put the heat on it and then press the power button, if you hear it clicking and green then back to red you are almost there. Keep putting heat on it and it will turn on.
Oct 24, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
185 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
