Two laptop connected to wireless router. comp1 can access files from comp2 but comp2 cant access files from comp1. both comps show network map and can get ip yet comp2 keeps timing out when attempting ping.
  • 4 Answers
Considering that you are using both comp with dynamic IP and from same wireless roughter and OS is same from both laptop.
As you are able to ping from comp1 to comp2 and not able to ping from comp2 to comp1 .. check the firewall setting of comp1 or disable the firewall from comp1.
Posted on Aug 23, 2008
Cant get wireless on my advent modena red
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Apr 13, 2012 | Advent Modena M101
Actually, im just unistalled my pc's wireless network adapter, the problem is,.. i dont know how to install it again,. i cant connect to any wireless network,.
Simply go ahead and restore your comp to a back date.
Click on start, all programmes, accessories, system tools, system restore.
Select a bold date with description showing check point.
Click on restore.
Once restore is completed successfully the driver shud be back on the comp.
And u shud restore it to the date before u uninstalled it from ur comp.
Jun 05, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Can i connect 2 a wireless network?
Actually it is an office with 2 different networks. Currently there are two wireless routers (router A connect to network A; and router B connect to network B), then router A with a server set for internet access. The two network somehow link together already, but all nodes in both networks can't see each other(cant share files thru "My Network Place"). All nodes equipe with Windows XP.
It’s help u.
And Thanks.
Mar 03, 2010 | HP 285527-001 - Compaq Presario...
Changed tvs and now the player plays dvds in black and white. I never unplugged the red white and blue cables from the player.
You've got the cables plugged in wrong at the TV end. The green plug is the luinance conductor or the black and white signal, and yyou have it right, but the red and blue are wrong. Check your connections again and make sure all the connections are amde on the same input (comp1, comp2...), and not crossed over such as green plugged into comp 1, and red and blue plugged into comp 2.
Good luck.
Dec 04, 2009 | RCA RTD215 Theater System
I cant find the wireless switch to turn it my dad got a modem but i cant connetcet my laptop to it we tried everythink evern ring the help line but they could do and think help
hi
give a staic ip on the comp not the default gateway on lan
connection.
connect the comp to the access point
opent the access point GUI using the address on the bottom of
the access point u have
do the same w/l settings u have on the router and make sure
the security is WEP
then if u want to connect the access point w.l with router
then excange the mac address of each device into each other
if u dont want to make access point w/l to router then there is no need to exchange such mac addressess
then u need to change the ipaddress of the access point in the same range of ur router
then try to connect thru w/l network name and password if any.
you will be able to connect and go online
gud luck
thanx and regards
sukhiii
Jul 27, 2009 | Computers & Internet
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Adding hard drive to network
search the ip address which you give to the secong hard drive.
Jul 02, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Pare help..
Please ask the smartbro for the router, from the router then connect to switch, maybe u should by 8 port switch which i recommend the d link or the linksys switch. do you know how to terminate the UTP cable?
In each connection u need a 2 Units RJ 45, You should a crimper to terminate it each end point.
guide to create network cable.
http://www.wikihow.com/Make-a-Network-Cable
U don't need a server as long as you have router. bale ang kailangan lang ay pangalan ng bawat computer ay iba iba.
smart bro --router--switch(8ports) --Comp1
-- comp2
-- comp3
-- comp4
-- comp5
-- comp6
-- comp7
sana makatulong. melnavz
Jan 29, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
David Payne
David Payne
