Question about Compaq Presario 700 470024-192 Notebook
Compaq battery/power problem
I have a compaq presario and though the power supply is plugged in, the battery is not charging.  i had a similar problem with a compaq laptop before this one, which i why i have this one...because the battery on that wouldn't charge.  but it was a matter of a bad connection i think because if i held the power supply in the computer manually it would work for a while.  anyway, this new one is just not charging at all.  do i just pop in the flash drive, back everything up and get a new PC?  (assuming i even have enough power to do that)
  • mctodd Aug 23, 2008
    thanks peeps,
    vicky...it is not showing any signs of charging.
  • CS-Vicky May 11, 2010
    Does the laptop show any signs of receiving any power at all?
    It could be a number of things; a faulty motherboard, a damaged power socket, faulty charger, faulty battery.
    Sounds like the power socket from what you described. Has it been caught or tugged, or in any way mishandled? They're quite fragile sometimes.
  • 70 Answers
Do you have a multimeter at home?
If you do, check the voltage the PSU is giving off is correct. If it's not, I'd see if you can find another PSU to test it off, ask in your local electronics/hardware store if you can try one out.
Have you tried powering it on with power but without the battery?
If it is giving off the correct power, it sounds like it's a problem with the power socket/PCB. Find a laptop specialist in the area and get them to give you an estimate. It may not be worth doing, I'm not sure what they'd charge. At our shop, for PCB cleanup and socket replacement is between 50~100, depending on how bad the damage is.
It could be worse, it could well be a problem with the motherboard. The problem with diagnosing this sort of thing is that there's so many things to go wrong, and to find out, you've got to open up the laptop to test everything, which generally incurs a labour charge, as stripping down and putting together a laptop without any testing is a several hour job, and a fiddly one at that.
If all else fails, speak to the people who give you an estimate and find out if your laptop's covered by any kind of warranty or insurance, they should be able to do a letter to cover you.
Posted on Aug 24, 2008
    Novelist:
  • 210 Answers
That problem is usually because the "charging unit" inside the laptop is broken and not putting any juice into the battery.
...unless your battery is genuinely dead, which is unlikely. Most batteries have a "self-test" button, with an LED bar-graph indication. That should at very least flash the lowest bar when you press it.
Pretty sure the charging unit is your issue.
Please either give me a full score or none at all... I know this answer doesn't fix your problem, but if it means reducing my average, i'd rather have not responded at all. =-]
Posted on Aug 23, 2008
Compaq presario 7pl290 will not power on
Make sure that the battery is charged or plug in the power supply.
Jan 17, 2013 | Compaq Presario 700 470024-192 Notebook
My compaq presario c795tu battery is not charging
Unplug the power supply, take a stiff tooth brush and clean the battery terminals in the laptop plus the battery, re-install the battery and plug the charger in, If that fails you need to find out if the charging circuits are putting out the proper voltage before you replace the battery.
Mar 04, 2012 | HP Compaq Presario CQ40-330TU
Just purchased a compaq presario secondhand--is the battery supposed to charge automatically when you plug the computer in? Mine is not. Works perfectly with the power cord though.
All the laptops I have seen since the 1980's charge the battery, if it is installed, while the laptop is running. They charge at a slower rate if you are using the computer, and faster if you just plug it in and leave the computer powered off.
Most have a 'charging' led [green or amber] indicating that the battery is being charged when you plug the laptop in and leave it turned off. If you don't see any indication, check that the battery is connected firmly and that the connectors are not damaged. If possible, try the battery in another machine or a different battery in your machine.
tom
Dec 21, 2009 | HP Compaq Presario V6000T Notebook
Battery not keeping charge
Some Laptops will not charge unless the PC is started. The moment u shutdown, the main supply via the adapter also stops sending any power for charging the battery. It is similar to most of the compaq presario series too. Try this.....sodeep
Mar 27, 2009 | Computers & Internet
I can't turn on my presario C700 laptop, battery is 100%
Do power drain
step 1: remove battery and ac adapter from your laptop
step2: hold power button for 30second-1minute
step3: now put back battery and ac adapter
step4: now power on you sud be on
give a try hope it helps u
Feb 21, 2009 | Compaq Presario 700 470024-192 Notebook
Laptop won't turn on, battery won't charge
I had a similar issue with the Armada M700 from Compaq. Never did figure it out exactly. But I do know this. When you unplug the power chord and take out the battery and plug the power chord back in while the battery is out usually for some reason it turned on allowing me to replace the battery which would then begin charging. Your problem interests me because I can really relate!
Jan 14, 2009 | Compaq Presario 1200 Notebook
Compaq Presario M2000 DEAD
My power plug that goes in the computer gets hot enough to melt the plastic ring on the end of the plug. so i am going to get a new power board and try that.
Jul 27, 2008 | Compaq Presario M2000 Notebook
Compaq Presario 1000
I have a Presario X1050, not sure if they are similar. Remove the screws from the bottom, carefully remove the keyboard with a small flat head screwdriver. You'll find many screws hidden by small plastic covers and rubber feet that will all need to be removed with the screwdriver. You may have to remove the display to get inside the laptop. Ultimately though, the power supply is actually external included on the power cable.
Jul 01, 2008 | Compaq Presario Notebook
Compaq Presario 700 470024-192 Notebook Logo
130 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
