Question about Kitchen Ranges
I have an Stoves Fan Oven. Oven is warm even when off. Is it a thermostat or a switch problem. Its a Stoves 700DFD0a
I had same problem! engineer came out and changed oven thermostat and problem was solved!
so replace your thermostat or get someone to do it and all will be ok,
or just turn off cooker on wall switch and only switch it on when you need it, that's if you can put up with it and need to save money
Posted on Mar 17, 2010
Fan oven not getting warm
It is normally the element that has gone, located behind the fan. A long shot could be the thermostat. Have a look at the thermostat sensor. It will be located in the oven at the back somewhere. It should be clean and bright and not covered in dirt or grease etc. If it needs a clean, use a spray cleaner and do not treat it to harshly. The thin wire leading from it is quite fragile! However, if you decide to replace the heating element, I would suggest that you replace the thermostat as well because quite often the element blowing damages the thermostat, which could lead it to fail, it it hasn't already done so, at a later date.
Oct 31, 2011 | Stoves 720EF Electric Double Oven
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Oct 30, 2011 | Stoves 720EF Electric Double Oven
Just moved, can not get stoves double oven to work light and fan comes on both ovens but no heat
On the main oven, does the circulating fan at the back of the oven start to rotate when you switch it on and does the fan oven neon illuminate as well.
For the top oven, the heating element is not very big so the oven takes a long time to warm up. Does the top oven neon illuminate when you switch this on as well?
Aug 02, 2011 | Stoves 720EF Electric Double Oven
My fan oven works but doesn't heat up very well - only gets warm even though the indicator is clicking off and saying it's hot - eg 220c
It sounds like the thermostat has gone faulty or lazy. As a check, I suggest you buy the round oven thermomater from Lakeland - I think it is about £5.00 to see what the actual temperature is being achieved. Also check the sensor in the oven. It is the long thin tube located at the top rear right hand side of the oven above the circulating fan cover. The sensor should be clean and bright not covered with grease etc as this may cause incorrect readings. Don't attempt to clean it manually as it is fragile - use a brush on cleaner - again from Lakeland and follow the instructions on the label. If you have to replace the thermostat you will have to take the whole oven out of its kitchen cabinet - the handbook tells you how to do this.
Dec 31, 2010 | Stoves 720EF Electric Double Oven
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
Stoves 720ef fan oven cuts out after a while, then cools down and restarts......help
There are thermal cutouts for both ovens. When the fan oven cuts out, does the thermostat display and the oven lamps go out as well or do they stay on? Is the oven cooling fan working ok, i.e. does it run for about 10 mins after you turn all the controls off? Do you think the oven thermostat is working ok and not running too hot? If it is, Lakeland do an oven thermometer for about 5 pounds that you can check the thermostats with.
Apr 22, 2009 | Stoves 720EF Electric Double Oven
Oven cooling fan keeps on spinning
Sounds like you have a oven probe or (if equipped) computer issue. From the looks of it, you dont have a computer on this model, so you probably have a thermostat stuck somewhere in there. The thermostat closes at the set temp, then opens when the unit cools. Sounds like this one is stuck in the closed position, allowing the fan to run all the time. You will have to look and see if you have a wiring diagram on the back of the unit, then find the fan wires and see which thermostat controls it. If no diagram, follow the wires out of the fan and see if on runs to a thermostat. Good luck and let me know if you need further info.
Nov 16, 2008 | Stoves 1000DFDLm Gas Kitchen Range
Stoves 720ef top oven warms but does not reach high temps. element replaced - no fix. thermostat ok as heating light cycles on and off at around 120 deg C, but reluctant to get hotter.
Have the same problem. Went and bought an oven thermometer from Lakeland and found that when the top oven thermostat was set to 160, the temperature only got to 140. I did clean the sensor inside the oven using a cleaner from Lakeland which did improve matters but it is still running cooler that it should. ( It takes at least 20 to 30 mins to warm up)
May 01, 2008 | Stoves 720EF Electric Double Oven
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Fan oven stays warm
is the fan working when oven is staying warm? possible fault if you don't have an earth trip is a short to earth on the neutral side of the element
Mar 23, 2007 | Stoves 1100DFSID Kitchen Range
Kitchen Ranges Logo
111 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
