Have a teledyne laars lite LLD pool heater and was told that I needed a new ignition control unit. Replacement called for a digital ignition control unit (#RO317500) to use in replacement for model 05-339011-003 that was originally on my analog heater. Paperwork included did not give info on exactly how to wire it to the unit - there is a IND connection and a diagnostic area on the unit that was not on my original control unit. Anyone out there that knows what to do to connect it correctly? I'm particularly puzzled by how to attach the thermostat start control switch to the ignition unit. I'd appreciate any help possible..!
chillmaster
  • 104 Answers
SOURCE: I tried to replace my
Your "R" terminal is basically your "hot" and your "C" terminal is basically your "neutral" to simplify explanation. The Furnace supplies the "R" power to the thermostat and then depending on what wire the thermostat sends the power back on determines what the system does. The thermostat terminals are as follows "G" is fan, "W" or "aux" is elect heat, "Y" tells the outdoor unit to run, "O" or "B" tells the outdoor unit whether it is heating or cooling, and "E" is emergency heat. "G" should connect from the t-stat directly to the furnace and go no further. "W" or "aux" AND "E" should both connect to your "W" or "W1" terminal in the furnace, there should also be a "W" connection to the heat pump ( this allows the H/P to turn on the elect heat when the unit defrosts) "Y" and "O" or "B" may or may not connect to a terminal in the furnace, usually they just pass through the furnace from the t-stat to the H/P and get wire nutted in the furnace. Now, here is the key. As I mentioned previously "O" or "B", a system will only use one or the other. The entire industry (except for Rheem and Ruud) uses the "O" terminial which has 24v on it when you are cooling and no power when you are heating. Rheem and Ruud use the "B" terminal which is just backwards, 24v in heating and no power in cooling. This is all for a heat pump, If you do not have a heat pump, then disregard the references to "O", "B", "E", and "aux". You will have R-power on red wire, W-heat signal to furnace, G-fan signal to furnace, and "Y" cool signal to outdoor unit.
Posted on Jun 15, 2008
SOURCE: Remote Thermostat Control hookup for AZ28E15DABM1
I called out an electrician and he wired it for me. Even told me they sold me one not designed for my model, but he retrofited it and it works fine. Been about a year now.
Posted on Jun 18, 2008
pierre1811
  • 144 Answers
SOURCE: I have Bryant HRV and the motor has failed.
Wire nut and tape the blue and red wires they are not used.
Posted on Mar 06, 2009
  • 4 Answers
SOURCE: replacing old thermostat with new digital
Wire nut or tape the black off. The red is normally 24volt supply power to the t-stat. Blue may or may not be the common. Have a voltmeter?
Posted on Jun 24, 2009
  • 9 Answers
SOURCE: Laars Teledyne Pool heater flames on for 2 seconds, shuts off
You have no flame rectification.....LLD series heaters check for a signal through the flame to ground; if the module does not detect this signal, it go through two more trials for ignition and then lock out the module. There should be a flame rod and it may need cleaning. I use steel wool.
Posted on Jun 28, 2009
I am replacing ignition control unit for pool heater laars lite 2 LD325. New replacement I/G unit do not have a F/S(flame sensor) wire connection terminal what can I do the original flam sensor circuit?
sounds like you have a universal replacement go by the directions it will show you how to hook it up if you don't have instructions call jandy tech line
Aug 10, 2013 | Teledyne Laars Pool & Spa
Heater runs about 40 min then shuts down . replaced water temp sensor and it still shuts down
make sure it is a propane heater propane burns hotter than gas if not correct heater it will overheat if ok check gas pressure if not enough heater will overheat you also might have too small gas line and are emptying it
Oct 10, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a larrs lite lld 400 n it heats up but it doesnt get hot enough
if you have a bypass made of plumbing only open 1/2 way if you don't have one put one in if you slow the water down it will heat more per pass
Sep 18, 2010 | Teledyne Laars Laars Lx Pool Heater /...
I have a Teledyne Laars Lite pool heater Model LLD 250N. When I turn the heater on it will run for 10 minutes and turn off. If I turn the power switch off and right back on it will run agin for 10 minutes...
It sounds like your pool heater might have a defective controller (the part, not you). Check the controller and replace if necessary. It could also be that you need to cycle the ignition sequence until the air is out of the gas line. It could also possibly be that your gas valve needs to be replaced.
May 30, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
We have a laars lite 2 pool heater , the pilot is lit but the unit will not fire up
With these pool heaters, there are a couple of things that you can try before you call a pro. First, make sure that your gas valve knob is turned to the on position. Secondly, you could have air in your gas line. Cycle the ignition sequence until all air is out of the line. It could also be that your gas valve is malfunctioning and needs to be replaced.
May 20, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
May 30, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
pull out flame sensor and clean with sand paper or emmoring cloth then try again should work (small black wire with sensor sitting above burners)
May 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Heating & Cooling Logo
127 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
