Question about Canon PIXMA iP4200 InkJet Photo Printer
Ip 4200 print head
My ip 4200 print head has an electric fault
please tell me the solution...............!
Rtfgh
Posted on Aug 25, 2008
Dear Sir, Kindly tell me how to remove cartridge from my printer HP 4200 and re assemble Thanks, V. Gopinathan
Turn the printer on.
Lift the lid that covers the print-head assembly.
The print-head should slide to a position from where you can "unlock" an ink-cartridge from the carrier, and remove the cartridge(s).
Jul 30, 2011 | Office Equipment & Supplies
I am trying to locate the ip address on an office hp 4200n
Usually you can print a configuration page and it will tell you the IP address that is assigned to the printer. You should be able to use the small menu screen on the printer to navigate to, and print a configuration page, or use it to navigate to the network settings to view and/or edit the current configuration. If all else fails, sometimes you can run Angry IP Scanner on a computer that is on the same network as the printer and see if any of the hosts come up with a name that matches the printer, then you will see the address of that host.
Jul 20, 2010 | HP LaserJet 4200 Printer
LaserJet 4200 Printer: HP LJ 4200 has Jetdirect card that worked fine unt...
Is the jetdirect card part number a 615n? If so, replace it with a 620N. The 615 cards were bad from the get go. Hp recalled them for about a year providing free upgrades to the 620.
May 16, 2010 | HP LaserJet 4200 Printer
I need a replacement print head for my Pixma iP 4200.Can you supply ?
You can obtain a print head from canon .
We dont sell products but we do offer assistance and solutions and ways to fix stuff, for example I'm now going to outline a way to fix your print head without actually having to buy one!
1.) remove the head from the printer (its called an ink well)
2.) Submerger the head of the inkwell into rubbing alcohol or a strong spirit
(the head is the nozzles under the ink well where the ink flows to the paper)
3.) using a straw slowely drop some alcohol on the nozzles which are located inside the ink well (the ones that touch the cartridge) (not the circuits)
4.) place on tissue paper, blot and let dry.
5.) replace and do a few deep cleaning's until it prints.
6.) U may need to clean your waste ink pads as well as u many need to reset your ink counter . If you need to do this click my name and ask directly to me and I'll outline the methods used for you.
In some cases if the above dont work, use this method as a last resort.
1.) Put dome water to boil.
2.) submerger the buttom half of the ink well (ink heads only) in the boiling water until all the old dry ink runs out. (usually 10 - 30 seconds)
3.) dry, blot.
4.) replace in printer and do a few deep cleanings until it prints.
If you have any further questions feel free to ask!
Feb 25, 2010 | Canon Office Equipment & Supplies
Error on printer Connon ip 1000
Error code: 5600
Description: Cartridge displaced error
Symptom: blink in orange 9 times,beep 10 times
try removing and replacing the cartridge
please rate our help to keep the service online
Aug 24, 2009 | Epson Stylus Photo® R2400 InkJet Printer
Ip 4200 blinks 5 times
This error is the print head is not installed
[1401], or it is not properly
installed (Print head temperature
sensor error [1403] / Faulty
EEPROM data of the print head
[1405]).
Feb 06, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Hp laserjet 4200 printer- how to find the current ip address?
To have an IP address for the printer you must either have a HP4200n or install a Jetdirect card into the printer. The Jetdirect or "N" version of the printer with the built in Jetdirect holds the network IP address. Subnet Mask, Gateway Derfault and handles the networking functions. If you have a 4200n or Jetdirect installed it will print out on the configuration page.
The standard HP 4200 doesn't have the networking capability without adding the card. In the event that you have a card installed and its not recognizing the card on the configutation page it may be bad. The HP 615n cards are known to have burn out issues. If you have to install a card to upgrade your printer, I recommend a HP 620n or better to get around the known bad issues with the 615n cards.
Jul 07, 2008 | HP LaserJet 4200 Printer
Missing print
Check the paper size within the menu as sometimes causes this fault.
Thanks J
Dec 19, 2007 | Samsung SCX 4200 All-In-One Laser Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
161 people viewed this question
old marine
old marine
