Hard drives Hi There, the blue light blinks but doesn't turn on properly, the machine won't work. Should I open it up and connect directly to the disc? thanks
    Master:
  • 505 Answers
Sounds like the hard drive
you may need a new one there
Posted on Aug 23, 2008
Blue light on the start button on my e-machines desktop keeps blinking and mouse stopped working what is wrong
Blue light is for hard-disk drive.It means your hard disk is working.Mouse working has nothing to do with this.
May 06, 2014 | E-Machines eMachines Desktop PC
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My WD element extrenal hard drive won't open. i can see it in my devices, and the blue light stays on. it also makes the sound saying it's connected but I can't see the device in my comput
First thing, try to change the cable, try a different one, then if it does not work, try to connect the hard drive on another computer, and changing cables as well. This will help you to narrow down the problem to find out exactly what the matter is. If the Hard drive spins properly and it does not produce any click-click sound then it is fine. If all the above fail, then you have to slave the hard drive using its internal SATA connection. You have to open up the hard drive and remove the pin that connects the hard drive to the cable. This will enable you to see the SATA connection. Slave the Hard drive on a desktop computer and see if you can gain access to it. If you can, then consider replacing both the cable and the pin that connects the cable to the hard drive. If your hard drive just spins and you can not access it while its a slave to another computer, then the hard drive has a problem.... Try the methods above, i believe your hard drive did not go this bad...
Mar 26, 2012 | Western Digital Elements powered by WD 320...
Acer Aspire 5732Z won't turn on - the light comes on for a few seconds and then turns off - whilst the light is on the disk drive will open - the screen doesn't show anything
Could be bad ram,hard drive or possibly a bad display panel or video card.Try using different ram and removing the hard drive then try it.Also,connect it to an external display and see if it shows video or not.If after trying these things it still isn't showing let me know and i'll try to help more.
Nov 22, 2011 | Computers & Internet
My HP Pavilion dv5 1125nr laptop won't boot up. The screen never lights up when the power is turned on, the little hard drive light next to the power light doesn't flash at all (normally it flashes...
check by removing the battery then put it back again power it on, or without battery power it on directly then check, if still the same problem, the fault is in the motherboard of the laptop, better take it the service center or consult some technician in your area
Aug 02, 2011 | HP Pavilion dv5-1125nr Notebook
Light is on but no one is home.
please remove the raw drive from the casing
if its a sata connect it directly to your pc using a power cable for sata drive and a data cable and connect it to the mother board
i am sure it would detect your drive
if no then your drive has lost its firm ware ata module or the rom bin file
if you know how to fix firmware the drive can be up again
pm me if you cant solve your problem
datarecoveryfactory.
Sep 05, 2009 | Western Digital My Book Essential 1TB...
Blinking lights and not recognized by computer
Try to remove the internal drive from enclosure and connect directly to PC. Does it show up this way?
Does it make any new clicking/knocking/whirring/grinding sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
Nov 04, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Red Light/Blue Light I/O Error
My nx2 is working again after having the "red light/blue light/I/O Error" problem. I just:
1. turned off my computer
2.unplugged the HD,
3. took out the HD from the enclosure and plugged it back into the enclosure,
4.started up my computer without the HD being plugged in
5. after my computer had been on for a minute, I plugged the HD in and my computer recognized it and had the proper mixture of red and blue light coming from the HD, indicating it's working properly.
Aug 26, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Blinking blue light
the only blue light that i know blinks is the Kmart blue light special .. we need model of things you're working with to properly diagnose.
is it external drive ? with a blue light blinking ? is it connected in usb ? sounds like if its external drive with blinking light could be bad hard disk or bad controller card inside that translates ide to usb.
Jul 29, 2008 | Computers & Internet
My SanDisc 2Gg Cruser is not working "It's DEAD", i have three computers at home one is a laptop all running Windows XP,none of them are reading the scan disc, the light doesn?t turn on and when i go to my...
Likely a power or power connection problem.
I squeezed the cruzer's connector for tighter fit to PC and that works. I also found that my laptop coming back from standby might not redeliver power to USB--PC needs restart. Also, if not already tried, plug it into another port on the machine.
Because I had to open cruzer to fix detached socket, I notice socket connection to circuit is not reinforced. If cruzer socket had been bent, there may now ba a defective connection between socket and board.
Apr 30, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
391 people viewed this question
David Payne
David Payne
