Question about Sharp AR-153E Copier
Manual guide hi i just bought my sharp Ar-153e and its just 2ndhand actually i dont have the manual of it.can u help me to find it & to print it too
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
SOURCE:
Sharp AR-153E error code H 4
try this site to get a op manual then see the buttons in the book
http://www.sharp-world.com/restricted/products/copier/downloads/select_us.html
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 20, 2015 | Sharp AR-153E/F152 Toner Ctg Black...
There is a small triangle circle blinking, what should i do?
http://www.manualslib.com/manual/324842/Sharp-Ar-153e.html
Mar 19, 2014 | Sharp AR-153E Copier
I cant find the right driver for my sharp ar 153-E for my computer. thee system of my computer is windows 7
go thru the below link.
http://xpdrivers.com/printer/sharp/ar/ar-153e/_5_6731.cfm
May 23, 2011 | Computers & Internet
WHERE CAN I FIND A DRIVER for SHARP AR-153E copier WITH WINDOWS 7 OPERATING SYSTEM please. thanks
Go to the following site. Select your Product (Photocopier AR-153E) and Operating System (Win7) and download Drivers
http://support.sharp.net.au/drivers/driversearch.asp
Hope this helps.
CreativeTECH
Nov 12, 2010 | Sharp AR-153E Copier
Code L1 on a sharp AR-153E digital copier. Any help out there please?
L1 code means problem with scanner unit. cheque to see if scanner is locked if not , lube rails and ck scanner motor.
Apr 05, 2010 | Sharp AR-153E Copier
Office Equipment Copier Sharp AR-153E need to
Have you done simulation 24-7 to reset the drum? Do SIM 24-7 and the unit will start to copy
Mar 26, 2010 | Sharp Office Equipment & Supplies
Where cam i download the driver?
hello. go to this link http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
regards, joe ps - kindly rate my answer as helpful. thank you.
Feb 18, 2010 | Sharp AR-153E Copier
heat roller in fusing unit problem. lamp,fuse,thermostat, or thermistor bad. Try reset first
Jul 12, 2009 | Sharp AR-153E Copier
Driver of Sharp AR-153e
you can download them from sharp.com
Jan 05, 2009 | Sharp AR-153E Copier
How do u reset the Sharp copier AR-153E? wat buttons do u push?
For error codes:
You enter simulation by pressing #,interrupt,c,interrupt in sequence display goes off, then no. 14 then start key.
Hope that helps...
Lbcoaster
Jul 14, 2008 | Sharp AR-153E Copier
Sharp AR-153E Copier Logo
145 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
