Question about Samsung SGH-Z500 Cellular Phone
Cable problem What is the flex cable and how do you fix it??
  • odie673 Aug 24, 2008
    sorry haven't done this before
    I feel like I am going to break the phone when I try to wedge it open. Is there an easy way to open up the cp. thanks
  • 1,800 Answers
First things comes first.
u gave me a "Innapropriat" rate when i was helping u in the last time.
that wasn't a good behavior.
any way i will be better than u and helps u this time u dunno if i can trust u but anyway i will.
the flex cable is an electronic belt that connect the screen of the CP to the Cp's keypad.
when a chanel of the flex cable cut a specific function of the phone stops
any way u need to change it u can find it in the chinese Micro electronic stores.
buy it and dissemble the CP and remove the damaged one and replace the newer .
i hope this is helping u if its not tell me so i can help i further.
please rate this post and be cool that the mast time.
Posted on Aug 23, 2008
  • Jalal Sordo
    Jalal Sordo Aug 25, 2008
    did u remove the screws of the keypad part??
    remove the battery cover
    and use something to toggle the lcd screen like a knife!
IN SONY HANDY CAM HDD XR150 - LCD SCREEN THE SOME COLOR LINES ARE DISPLAYING INSTEAD OF PICTURE . THE PROBLEM OCCURRED AFTER REMOVING THE HANDY CAM FROM THE TV SET AS PLACED IT OVER 30MIN.
You need a new sony display flex cable installed in your camera.. it is a rather simple procedure.. dont let anyone tell you it is going to cost 300-500.00 to fix. the cable or flex that makes the display viewable is called a LCD display Flex. If you don't get any image on your display, the image has lines, display has no backlight or anything like that, replacing this flex cable should fix the problem.
you can buy the flex cable on ebay for less than 30.00 and the fix is rather simple.. the display has the flex cable on the back side and there are 3 screws that holds the display on the camera body. when you take them out of the camera using a PH00 small screw driver, you can then take the flex cable out of the display and easily replace.. it doesnt take rocket science to take these out and replace them.. good luck.. remember... you can buy the flex cable that makes the display viewable and then when it is replaced you will then be back in business with your camera.. good day....David...Mt Holly, NC
Jul 29, 2011 | Sony Handycam DCR-SR300 Camcorder
When slided in the display goes out... screen becomes blank and calles and messges cannot be seen
you have a defective flex cable or sometimes called ribbon cable, replacing it will fix the problem.
Oct 15, 2010 | Cell Phones
My MOTORAZR v9m's phone's screen went blue and whenever I open it up it stays blue. The outside screen is fine, its just the inside. I read that it had something to do with the flex cable. Is that right?...
Hello, Yes there may be a problem with the flex cable of the LCD, if you know how to open your phone try changing and replacing new flex cable. but be careul not to damage the flex cable, but if you are not familiar in opening the phone let the technician do that or you, Go to Motorola service center.
Sep 16, 2010 | Motorola Mobility Motorazr2 V9m Cell Phone
Touch screen won't work
Had the same problem. It's ainternal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's a common problem as this cable is bend each time when we open the LCD screen, so the cable become faulty.
Good luck
Oct 01, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
How can i fix the flex cable in my phone? it just went blank everything works but i cant see anything
The only way of fixing a problem such as a damaged flex cable is replacing it, so i suggest you find the nearest cell phone mechanic so they can replace it for you
Jun 15, 2009 | Motorola Mobility RAZR V3
Motorla MPX220 Screen turning Red
where you got the flex cable from.....
Nov 03, 2008 | Motorola Mobility MPx220
No sound through earpiece/white screen
you can send too sony ericsson it in if you are the origanal buyer and they will fix it for free but it also has to be under a year old
or if you are on a plan you can get a new phone every two years its not free tho it is very cheap you have to be with at&t to do that tho (cingular)
Jan 28, 2008 | Sony Ericsson W300 Cellular Phone
White screen
Your flex cable has most likely gone bad. If the phone is under 1 yr. old I would suggest have it repaired by a warranty repair facility. If you are going to try replacing yourself let me know, I will try to help w/ disassembly. Good luck.
Sep 11, 2007 | Motorola Mobility E815
Flex cable
It's fairly simple to replace a flex cable if that's the culprit. This is a flex cable: http://cnn.cn/shop/motorola-razr-keyboard-flex-cable-p-300.html It's got adhesive on it so if you plan on repairing yours, you need to peal your old one off. That's really no big deal, the thing you REALLY need to worry about is damaging your keypad when removing it from your housing. You might want to order a new one just incase for that very reason. Be aware that unlike the V3c's flex cable which is a separate cable that connects to the main board to go up to the upper part of the phone, the V3's keyboard flex has its cable attached, which means you must open the top portion of your phone as well. Opening the bottom part of the phone is simple. Opening the top part is where things get slightly tricky, if you're not careful you could really damage your phone.
May 14, 2007 | Motorola Mobility RAZR V3
Samsung SGH-Z500 Cellular Phone Logo
59 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
