Question about Hotpoint Aquarius WF000 Front Load Washer
Vibrating across the floor
I have a brand new machine no operating instructions, put in my first load and the machine has vibrated and bounced across the kitchen !!!
Should I have taken something out of the inside of the machine before commencing operation
    President:
  • 1,462 Answers
You have not removed the transit bolts!!!! do not use machine till you have done so as you can cause a lot of damage and it will not be covered under guarantee
Posted on Aug 23, 2008
SOURCE:
How to fix a bouncing floor
Is your floor the problem, or a vibrating wash machine? You can buy feet for an appliance or put carpet underneath it. anne melhuish
Jan 25, 2012 | Washing Machines
Leveled washer gets out of balance when load in spin cycle
A vibration problem is about the hardest thing to diagnose long distance but I will give you the most common things to look for.
Shipping brackets and materials not removed from the machine. You should be able to move the basket around easily by hand. Go over the installation instructions and make sure everything has been removed.
Leveling legs and lock nuts misadjusted or loose. You want the legs adjusted as low to the floor as possible. The higher it sits, the more movement it has.
Weak floor. If you can stomp the floor and have pictures rattle on the wall, you will have vibration problems with the washer. If it is on a laminate hardwood floor, you will have vibration problems. These floors have too much bounce for a washing machine.
The tub support to stiff causing too much vibration to be transferred to the cabinet or not allowing the tub/basket to return to the upright position so that it starts an out of balance spin. Put the washer into a cycle and let it agitate. Before it goes into a spin, open the lid and see if it is leaning awkwardly to one side. If the washer has some years on it, this may be your problem. If you remove the front panel you will see the thick washer the whole unit sits on. If it seems the unit is stiff , you may try spraying a LITTLE wd40 on the base it sits on so it slides easier, but just a little.
Check these things out and you should find your problem.
Thanks/Mike
Oct 24, 2007 | Washing Machines
I have a Maytag front load washer which I can't seem to level. It is on uneven floor, we used the floor leveling legs, but where should we place the level on the top? On the side, which is raised: or in...
You can check the level on the top, across and fore and aft and both must be level. It is actually more important that the machine is standing firmly on all four its feet, you should not be able to rock the machine by hand, and this creates a problem with your if it is not solid. Any vibration on a sprung floor will be amplified and any unbalance in the machine will cause ot to bounce on the floor. Rather than try cushion the vibration, try spread it across the area of the machine by placing a piece of some hard plate under the machine that all four feet stand on and you can place a piece of thin hard carpet under the plate to protect the floor. It will need to be water resistant, so some plastic sheeting about 3/8" to 1/2" should work for that.
Mar 26, 2011 | Maytag Washing Machines
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
I have a brand new washing machine that vibrates across the room on spin cycle. It is level and the load was checked for even distribution. Any ideas
Is the washer on a lino floor? If so you'll have to place some sort of stops on the floor to keep it in place .Unless of course the floor is unlevel and that would be another problem in itself. corner guards are a good bet for sliding problem
Feb 26, 2010 | Whirlpool Washing Machines
Washing machine vibrates bad in spin cycle
dont put full load please check it with half load or add water excess
Sep 15, 2009 | Kenmore HE2 Plus Front Load Washer
Lg Tromm wm2277hw
Try Ke shake away pads. i found them at lowes for $30. Solved my problem with a front load pedestal. Shook the pictures off the wall in the room next door. Best money I ever spent.
Jan 28, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Hotpoint Aquarius WF000 Front Load Washer Logo
148 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
