Question about Yamaha HTR-6030 Receiver
Yamaha HTR-6030, Sound only from Front Speakers
Hi, I have my Speakers in properly, I have "SUR. LR" set to "lrg" and all my speakers. I go to basic setup, set it to 5 speaker, it does the test and they are all working properly and make sound. I then hit enter on "ok" and on the display it goes back to just the front Left and right. I had it working a few days ago but I unplugged it to move it, now its just not working. Any help at all would be greatly appreciated, it is really annoying me.
Thanks,
OverZealous
  • darc_sphinx May 11, 2010
    ive got same problem can run the test but it just resorts back to 2 channell in stead of five channel like selected
  • 46 Answers
U could have it cross wired some systems wire in sequence not always pos and neg
Posted on Aug 23, 2008
  • 476 Answers
Unplug them and replug then retry them,
this could fix your problem
keep me updated thanks
Have a Yamaha HTR-6030 and all of the sudden we can't get all 5 speakers working
We just discovered in chat session that receiver is defective and left speaker has no sound, please take it in local repair shop for visual check and repair.
Thanks.
Feb 20, 2011 | Yamaha HTR-6030 Receiver
Yamaha Surround Sound HRT-6030
Hi!
maybe you select the Fader mode.. you simple select the fader balance to center then you hear the sounds coming out to the front fader mode.
Nov 16, 2007 | Yamaha HTR-6030 Receiver
I have my HTR 6030 receiver hooked up with a blu ray and am trying to get true 5.1 sound. Have a blu ray disc playing and have put the setting on "straight" on receiver as instructed by future...
If you only have sound from the front left and right speakers when it's set to STRAIGHT, it means the audio source is only 2 channel stereo. As the audio source is from Blu-Ray, the audio should be HD if you are using the correct type of audio cable.
I really need more information from you to give a definitive answer. If you are only using a RCA type audio cable (red/white plugs) from the Blu-Ray to the Yamaha receiver then you will only get left and right front channels on the STRAIGHT setting. This receiver does not have HDMI, so you really need to be using a digital optical audio cable to get true 5.1.
Please can you let me know how the BD player is connected to the Yamaha receiver if you need further assistance.
Thanks,
BElectric
Feb 05, 2011 | Yamaha HTR-6030 Receiver
I can't get surround sound to work on my HTR-6030. All the cables are connected properly, and I'm sending the signal from my Blu-Rays optical out into the DTV/CBL optical in of the receiver. I'm only...
Check that the Blueray isn't set to downsample to stereo. Your receiver could also be set on stereo. Do you have a "sound" button where you can cycle through different modes?
Jun 30, 2010 | Yamaha HTR-6030 Receiver
My surround sound speakers don't work. No power
LCD will display which speakers are active. And this depends on 2 things: the source signal and decoder mode.
If source signal is stereo, only front L+R speakers are used. For 5.1 signal (for example DVD over HDMI / optical/coax spdif) all speakers installed (which are not set to None) are used.
To listen to stereo input signal using all speakers, switch decoder to enhancer mode.
Feb 24, 2010 | Yamaha RX-V457 Receiver
Yamaha HTR-6030: all speaker have sound coming out but it is not true surround. The display only shows front speakers on, how do I get all speakers to come up on the display?
I think you mean the display only shows Front >>Channels<< available.
What source? Digital or analog (analog is only stereo).
Dec 27, 2009 | Yamaha HTR-6030 Receiver
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
May 18, 2009 | Yamaha HTR-6130 Receiver
Surround speakers don't work
Hello barstep,
Let's go through some steps that will help alleviate your problem. We'll start from the simple to the not so obvious:
1.- Perform a visual inspection on the back of the receiver and verify that all speaker connections (specially the surrounds) are not loose, shorting out another connection or are pushed too deep into the speaker connector so the wire insulation prevents proper contact. If this is not the problem then...
2.- Get into your receiver's "Manual Setup" and verify that your surround speakers are set either to "SML" or "LRG" but not "NONE".
3.- Verify the receiver is not in "Straight" mode, shown on the receiver's display. I f so, press the "Straight" front panel button until indication disappears.
Your owner's manual can give you detailed information to access the setup menus.
Hope this information helps. Let me know if we can further assist you.
cancerags
Dec 30, 2007 | Audio Players & Recorders
Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Dec 21, 2007 | Yamaha HTR-6030 Receiver
Yamaha HTR-6030 Receiver Logo
237 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
