Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Ionic Breeze do you have the number to call to get it fixed
I sent an email over 6 weeks ago but have received no reply....
Posted on Oct 19, 2008
    Problem Solver:
  • 12 Answers
Info@sharperimage.com here is their email address for more information, I will have to look for the phone number. If you have your original order form it has it on it. That is what I will look for though. hopefully their email will get you the number faster though.
Posted on Aug 24, 2008
Parts for S1697
Good luck with that.
Here is the information that I have for your air purifier. You may want to check it out.
"NOTE: THE OLD SHARPER IMAGE COMPANY IS BANKRUPT AND GONE! & THE NEW SHARPER IMAGE NAME COMPANY OWNERS WILL NOT WARRANTY, FIX OR REPAIR YOUR OLD IONIC BREEZE AIR PURIFIER!"
Source: http://www.aircleaners.com/sharperimage.phtml
"Ionic Breeze Suit Drives Sharper Image into Bankruptcy"
Source: http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
Jan 08, 2012 | Sharper Image Ionic Breeze 3.0 Air...
My ionic breeze quadra air purifier keeps turning on and off. I have cleaned the fins, what else can i do?
Hi.
The filter will probably need replacement. Ionic breeze purifier are not being manufactured anymore because of heath concerns. Parts are also not distributed anymore.
I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Sep 08, 2010 | Sharper Image Professional Plus Ionic...
My Quadra Ionic Breeze, has a small glowing fire within it at the base. There is a smell of plastic/electric burn. Though the odor did cover the odors in my house, I think I have a fire hazzard on my...
the ionic breeze uses high voltage to move/filter air .. if the insulators break down there will be an arc such as what you see .. there is a way to dig out the carbonized material and seal it with materials that can handle the high voltage but any repairs are costly .. its unlikely you can repair it for less than a new conventional filter .. the ionic breeze was unique and expensive but didn't move a lot of air ..it was quiet but often produced some ozone .. long exposure to ozone is not a good thing .. here is a site where you can learn more about your unit
http://en.wikipedia.org/wiki/Air_ioniser
check out where it says "Consumer Reports court case" ... that said, the electrostatic concept does probably remove small particles that are hard to do with conventional filters .. the arcing you see in your unit is indeed not safe . ... here is more that you likely don't want to hear..
in the next one look down where it says "Ionic breeze" under "helpful information" that will frost the cake
http://www.sharperimage.com/Pages/Helpful+Information/#ionic_breeze
i am sorry to say that your expensive ionic breeze is not safe and not repairable.
Aug 15, 2010 | Sharper Image Professional Plus Ionic...
WHAT ARE THE GREEN AND BLUE LIGHTS FOR
To let you know when the ionic breeze is working properly (Green Light) and when it needs to be cleaned (Blue light). Hope this helps.
Apr 19, 2010 | Sharper Image Professional Plus Ionic...
Ionic breeze gp does not work .
Hi.
Check power cord. If power cord has a built in fuse, replace it.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Regards.
Ginko.
Mar 27, 2010 | Sharper Image Ionic Breeze 3.0 Air...
There is a red blinking light and it is not cleaning.
My Ionic Breeze would work for a short time after cleaning and the blue light would start flashing and the unit would stop working. I checked the wall cube power adapter with a volt meter. It was putting out only 10 volts instead of the needed 12 volts. It seems The Ionic Breeze needs a full 12-13 volts to work. So I went to Radio Shack and bought a universal 12 volt 800ma power adapter. I checked the voltage in the new adapter, it was 13 volts. This fixed the flashing blue light problem. However the Ionic Breeze produces harmful Ozone gas, so I don't use it anymore.
Aug 09, 2009 | Sharper Image Professional Plus Ionic...
Broken "wire/filament' in ionic breeze quadra
This does NOT work. The electric guitar wires burn out in 1-2 months.
Jul 13, 2009 | Sharper Image Professional Plus Ionic...
Where can I buy replacement grid for ionic breeze professional series model S1831?
G15T8 15W 15 Watt UV Germicidal Bulb IONIC BREEZE GP
Item number on ebay is: 220444965077
$10.99 plus around $5 to ship.
Pull up on the tab on the bottom of the front filter and pull up. You then should be looking at the bulb, which you will turn 1/4 turn (2 clicks). You should then be able to pull the bulb out.
Hope this was helpful.
Jun 10, 2009 | Sharper Image Professional Plus Ionic...
Ionic Breeze Model SI637
I did that on mine, and was able to take it to an appliance repair shop, some how they were able to fix it
Apr 21, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
51 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
