I am getting error message on HP photosmart 5180 printer Photo Tray Problem Push output tray all the way down, have pushed the tray allthe way down and have tried resetting to default settings , still getting the error message and cant print.
  • rose10mary Aug 23, 2008
    I am getting error message on HP photosmart 5180 printer Photo Tray Problem Push output tray all the way down, have pushed the tray all the way down and have tried resetting to default settings , still getting the error message and can t print.
    This corrected my problem, Great news, I am now able to print.
    Genius:
  • 1,665 Answers
Pop along to www.hp.com Enter 5180 in the search box Choose exact model Click drivers and downloads download the latest Vista driver
Posted on Aug 23, 2008
    Master:
  • 623 Answers
Click start
right click my computer
properties
hardware
device manager
?ports
scan for hardware changes
  • 19,396 Answers
If basic hard reset (unplugging power cord) did not work try the following:
  1. Remove cartridges
  2. Unplug printer USB
  3. Unplug printer power cable
  4. Wait ten minutes
  5. Plug back printer
  6. Install cartridges back
Also open printerdoors and check for fragments of paper or small foreign objects. Turnprinter upside down and shake gently to see if there is any foreignobject inside, such as small screws etc.
If it still does not work do the following:
  • Unplug printer USB from computer.
  • Uninstall printer from 'installed printers' in Windows Control Panel.
  • Insert printer disk or install drivers after download from Dell website here : Drivers and Downloads
  • Run printer drivers setup wizard and follow instructions.
  • Connect printer when asked by setup wizard.
This should fix the problem, unless printer is faulty
  • Ginko
    Ginko Aug 23, 2008
    Try also taking the blue tray off and removing it than insert it again in its place, this often fix the photo tray error.
    If it does not work do the following reset procedure:
    1.. With machine powered on, unplug power cord from back of printer and wait for 30 seconds.
    2. While holding down the "ok" and "?" buttons, plug the power cord back into the printer.
    3. Let the thing power up again and give it time to go through all of its process.
    If it get fixed do not forget to vote the solution.
    Many thanks
  • 157 Answers
Hello
Try turning the printer off for a while, take the cartridges out and put them back in
  • John Smith
    John Smith Aug 23, 2008
    there may be a paper jam somewhere too
  • John Smith
    but the best way to fix this is turn it off for a while, take cartridges out , turn printer on and off, put cartridges back in and turn on
    Then post and tell us if this worked
Error message "push output tray
PowerCycle your Printer. Unplug all cables and push the power button for 5 seconds. Plug the cables back and try again.
-please thumps-up if you find this helpful
Mar 28, 2011 | HP Photosmart C6280 Printer
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
Output tray
The tray above it where papers come out must be all the way down. In cannot be inclined at all.
Mar 06, 2010 | HP Photosmart C7180 All-In-One InkJet...
My hp2780 keeps telling me the photo tray is not pushed in when it is
It's an incredibly frustrating problem. One thing that worked for me was to:
1. shut down the printer by pulling out the power source
2. make sure to push output tray down as far as it can go
Aug 27, 2009 | HP Photosmart C7280 Laser Printer
Photo Tray Problem
When nothing worked, I reexamined the trays, and there is a small plastic hook about half an inch long under the left side of the D7460 output tray. The tray below had a small hole. So I clicked the two together, and the printer started printing. Probably like many of you I had elevated the output tray as the printer spews onto the floor. Apparently it needs this connection. So much time lost....
Apr 11, 2009 | HP Photosmart D7460 Printer
HP c7180 message "Push output photo tray all the way down"
I have the HP C7280 and I was able to fix the problem.
HP seems to have 3 trays. The bottom tray is for the paper. The middle one has a small blue tray for the photos and the top tray is where the paper comes out.
Well I lifted the top tray where the paper comes out (it can angle up) and then I clicked OK on the problem. I may have even rebooted, but then I got a new error message which is good. It said to push photo tray (the small blue tray) all the way in which I pulled out and pushed back in. Then I pushed the top tray down so all is flat again. I clicked OK and it re-calibrated with no more error messages! Hope this helps.
Feb 16, 2009 | HP Photosmart C7180 All-In-One InkJet...
Pictures will not print and paper will not load for printing pict
You need to push the paper through just touching the boundary of the printer paper tray
Feb 12, 2009 | HP Photosmart D7260 Printer
Errors
just take the blue tray and remove it than insert it again where he suppose to be
Oct 09, 2008 | HP Photosmart D7160 InkJet Printer
Out put tray
The quick start says to load plain and photo paper - don't!
Leave out the photo paper and it should install correctly - then you can use the photo paper.
Good Luck
Andy L
Jun 26, 2008 | HP Photosmart C5180 All-In-One InkJet...
110 people viewed this question
k24674
jasbo
jasbo
