Question about Intel Motherboard
Mic doesn't work with DG 965 RY
Were you ableto find a solution to this probelme ? I am facing the same problem. Please help
  • Ravel Lively
    Ravel Lively May 11, 2010
    What makes you think you have talked to this board before, you only became a member this month and this is your first and only question so far. We do NOT represent any manufacturer ( hardware or software ), but we do have the ability to research problems in the vast majority of cases.
    Sergeant:
  • 226 Answers
Your motherboard manufacturer is Intel and their website for that mainboard is located here. Drivers and bios updates ( last bios update is 27 July 08 ). I highly recommend you get and install the bios update, but to be truthful only the driver updates should be needed to satisfy your problem. I suggest that either the audio driver you are now using is defective or that possibly you don't know how to use the audio controls to set your mic volume.
On most windows installation if the audio drivers are set up as a default installation, there will be located an audio configuration control in the system tray ( lower right of windows screen next to the time/clock. This audio control will have various icons depending on the software involved but could be as simple as a speaker cone or as complex as the name of the software controlling the audio. Open the icon if one exists and set the Mic modulation to around 80% of maximum and unless the driver is totally wrong for your chipset, it should work like a champ....
Posted on Aug 30, 2008
SOURCE:
What is ry jt240
Hi there:
Some electronical equipement incorporates thermostat and thermal link to safeguard itself. The RY-JT240 RY-JT227 RY-JT192 RY-JT157 are some of this devices.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jul 24, 2012 | Cars & Trucks
I facing mic problem kidly guide the setting of mic that i can use mic as my sound card driver is propely install but still not working kindly help me in this regard
Hi, your products homepage is here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5LMX/#download
Please select your operating system.
Here is a small clip from youtube that shows
you how to get the mic to work:
http://www.youtube.com/watch?v=zkl8WRWmdPU
Remember to connect the microphone to the red jack connector.
Hope this will help you.
Aug 17, 2011 | ASUS P5L-MX Motherboard
Console says replace belt unit even though I have minimal copies on the printer. Dell 3115 color laser
Hi
Try and reset the power to the printer and re-install check the toner cartridge. If this doesn't help then please try and reset the printer to default factory settings. Y?? ??n reset ???r Dell printer by using 'Reset Dell Printer' icon. Y?? ??n g?t t? th?? icon in folder 'UAN'--> 'Logic Utilities' -->Reset Dell Printer. Hope this helps... Please post back if you need more information.
Daniel
May 28, 2011 | Office Equipment & Supplies
Like to upgrade I have DG 965 RY LGA 775 Socket
Hi, your motherboard supports several different kinds of processors. You have a choice of two for the fastest performance. You could go with an Intel Core 2 Duo Processor #E6700 that runs at 2.66 Ghz with a front side bus of 1066 Mhz and 4 Mb L2 cache, or you could go with an Intel Single Core Processor #670 that runs at 3.80 Ghz with an 800 Mhz front side bus and 2Mb L2 cache. The Core 2 would outperform the Single Core, but it is more expensive. Hope this helps! Hal
Jun 03, 2009 | Intel DG965RY Motherboard
HP V3640tu lap top mobile intel 965 (X3100) For Xp Audio Driver
There may be a problem concerning drivers for WinXP.
- it seems like that Vista is the supported software, however,
try downloading this update software for your laptop, from HERE:
if this doesn’t work, I´d suggest that you go back to Vista.
regards /Teis
Jan 09, 2009 | HP Pavilion dv4000 Notebook
Special useage fujitsu m2537m-19B
MalcolmCal.: 1.44MB 3.5" Floppy Drive
Positions: DS 0123 + DG RC ST2
Both use Jumpers: 1-1 + 1-1
KISS: (Keep it Simple)
Dec 14, 2008 | Computers & Internet
Mousepad not working
Hi Sharad arya,
Try pressing Fn+F8 to activate/deactivate touch Pad.
takecare.
May 12, 2008 | Lenovo 3000 Y410 Laptop
Nokia 5200
Hi
Check the MIC. The limitation of a MIC should be more than 1000 ohms.
The connectors of the MIC may be soilly, clean the foils.
Supriyo DG
Apr 05, 2008 | Nokia 5200 Cellular Phone
Intel Motherboard Logo
51 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
