Question about Samsung Washing Machines
Water leaking from spin dryer in washing machine samsung swt65b1p . leaking from shaft underneath spinner unit
  • 89 Answers
Sounds like the seal on the tub is shot youll need to replace it (easier to have repair shop do it unless your real couragous)
Posted on Aug 23, 2008
  • 1 more comment
  • wes gilbert
    wes gilbert Nov 10, 2013
    how can in do it myself im pretty handy
  • wes gilbert
    any links
  • wes gilbert
    do i have to take the drive belt and motor off to get to it?
My kenmore elite topload washer is leaking underneath washing machine leaving a puddle whats causing this?
depends. first and foremost, I would fill the unit up about halfway with water, with tub being empty of any clothing. Tilt the machine back where you can look underneath it real good. see if you see any leaks with it half full of water. If you don't see any leaks, put the unit back on all fours, and put it into drain/spin. After tub empties of water, tilt unit back again and check for leaks near the drain pump and hose. If you need any further assistance, look for me on 6ya
Nov 27, 2015 | Kenmore Washing Machines
Samsung wa13g7q1 top loader
UNPLUG and lean forwards. sounds like a blocked pump. look underneath for the pump and remove it, check out inside and remove any blockages.
Nov 18, 2013 | Samsung WE356A5W Washer/Dryer Laundry...
LG twintub- water leaking at the spinner onto motor
This is due to failure of the seal on the tub and also if the spindle/bearing seal is also faulty. you need to remove and reset the assembly once again.
Click for tips: Bearings
Feb 01, 2013 | LG Washing Machines
Leaks water underneath - i think it only does it during the cycles that spin extremly fast to wring the water out
FAV6800A or FAV9800A correct?
If so you need to remove the front cover and try to determine if the water is coming down the Spinner Support shaft or if there is a leak in the drain line system.
I suspect with limitted info this could be a tub seal leak. with water collectig on the Clutch Pulley. Possible Tub Seal issue a big job but can be done by a basic DIY'er. I have helped others on this site replace the tub seal and Outer Tub Bearings.
If you want to DIY the fix we need to troubleshoot further and this is not the forum for that.
If you want to DIY the repair Google this phrase ""Sticky: Neptune TL Washer FAV6800AWW""" post your problem as a new issue not in the sticky and I will try to help.
Jan 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Kleenmaid top-load washing m/c leaks water and then smokes!
It sounds like you are leaking from the bottom of the unit. If you are leaking at the top then you need to check the water inlet valves, and also the drain pump and all water hoses. This doesnt sound like a seal issue.
Jan 02, 2010 | Washing Machines
MY WASHERS LEAKS WATER FROM UNDERNEATH DURING THE SPIN CYCLE
Check the water pump shaft seal for leakage (watch while the unit is spinning). Also check the hoses and connections at the pump.
Aug 19, 2009 | Washing Machines
Hot point washer heavy duty 7 cycle jewelry caught under spinner
if the unit is just a few months old the agitator has not seised the the shaft. the very top of the agitator should unscrew and with a little effert you should be able the lift the agitator off the shaft collect the jewlry and put it back together all should be find
Aug 10, 2009 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
139 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
