Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Weird lines on Toshiba REGZA
Hi. I've got a 42" Toshiba REGZA. Sometimes when we are watching, the left half of the screen will fill with vertical colored lines of varying colors. It's clearly the TV because they remain as you change channels. They will sometimes go away after a couple of minutes, sometimes last as long as 15 minutes. It's still under warranty, but when I approached our salesman he said he's never heard of the problem. I showed him a photograph of the screen as well. The closest warranty repairman is is 80 miles away, so we will be without the TV for at least two weeks if we ship it off. Do you recommend we do this, or is there an easier solution?
Thanks in advance for the help.
Craig Parks
  • 2 more comments
  • tdelong Mar 12, 2009
    My 14 month old LCD Toshiba regza has a fine vertical line on the right side of the screen 4" from the outer edge. It usually goes away after 15 minutes or so. Very disappointing for such an expensive Tv.
  • irby Mar 14, 2009
    I have the weird colored lines as well as the resolution difference on the left side of the screen.
    1st major purchase w/out extended warranty! Hind sight?
    The resolution difference I can live with, the colored lines are annoying.
    I found I could hit TV on that side and lines would either change or, go away. This suggested a loose connection or cold solder issue.
    I have gone as far as tearing it down. I still have not found the source. The obsticles are that ( in my case), laying tv down with screen side down clears problem right up and, I need it down to disassemble. Next issue is needing all the electronics off to get to the problem. It is a bit complicated in there
    I do have success clearing it up-though temporarily by sqeezing screen and case or repositioning it. If you have a wall mount, you probably can't do this.
    If and when I figure it out and, hopefully without further damage, I will post it. I have the feeling now that it is inside the LCD assembly. Not something I recommended for the novice to tackle.
  • stahoe Mar 21, 2009
    its a conspiracy, i purchased my 40" regaza in february 08, it just started doing the lines right after the warranty expired, it lasts about 15 minutes then returns to normal. I am just waiting for the day i turn it on and i permantly have half a picture, very disappointing, it sounds like this is more common with the toshiba product than what was stated
  • kristinkay66 Mar 26, 2009
    This seems to be the problem that I'm having with my Toshiba 32HL95. Vertical lines, double vision, amd pink vertical stripe on right side. I'd like to repair it myself. Any advice what part I need? Do I replace the processor board?
  • 558 Answers
Its in warranty ship it, the problem is actually not common but it is a problem it is related to the processor on the main board, and um don't trust salesmen to tell you about repair issues. They really don't have a clue. if you need a tv for to weeks then rent one for two weeks they are not that expensive to rent
Posted on Aug 23, 2008
How to fix Toshiba Regza LCD TV when half the screen with vertical streaks?
hi this fault sounds like a bad tab/ribbon fault, at top of the tv are ribbons connector to the screen, when one is faulty the heat makes them flex causing this fault, you can bond the ribbon down with a bit of rubber to stop it flexing, but this not a permanent repair as it is a screen fault. hope it helps
regards
shaun
Apr 24, 2014 | Toshiba 42HP66 42 in. LCD Television
Lg 42lg70yd aa Weird screen problem
I've tried the link, but failed to see your youtube video. Anyway, if there are vertical lines, and all of them are closed to each other, indicates either a T'Con or Panel problem. To make it sure, just get into this link http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar or see it in Timeslide option. There are screen shots of different problems to flat panel TVs. Compare them to your TVs' and make sure about the fault.
Jun 17, 2013 | Televison & Video
HI, I have a 42 toshiba regza tv that is 3 years old when watching tv the screen goes blank and the sound is still there i power it off then back on and the picture is fine. Somtimes wont happen for days...
If you are using a hdmi cable take it off and switch to component cables if the problem goes away keep it that way. Sometimes the hdmi hookups have bugs like this.
May 25, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
42 inch toshiba\r\n tv screen
Dark picture. I adjusted brightness, but it keeps getting dark. It has vertical lines that can be seen in grey areas on the screen.
Dec 08, 2010 | Toshiba Regza 42RV535U 42 in. LCD HDTV
Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
Oct 30, 2009 | Toshiba 52HL167 52 in. LCD HDTV
Fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Jan 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Vertical black line down centre of screen
I have same problem. Toshiba 42' hl196 purchased 4/07 line appeared 1 year and 9 months researched on Toshiba thread. Bad LCD screen. Repair cost more than tv-have to replace lcd screen. I didn't get the extended warranty. If still under warranty get hold of toshiba. Lot of people having same problem. Should get aclass action lawsuit started selling defective LCD screens. Kathy in Cleveland,OH
Dec 15, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Vertical black line on a LCD screen
LCD screens do not work the same as CRT tvs no vertical output IC, you have a screen fault which would need the screen replacing
Oct 09, 2017 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Black line
Called ghost lines or banding. I researched on toshiba thread LCD screen bad. I have same problem purchased HL196 4/07 problem appeared 1 year and 9 months ago no extended warranty. If still under warranty call toshiba. LCD screen more expensive then orginal price of TV. Should file class action lawsuit for selling defective screens. Lot of people having same problem. goforth2953
Sep 09, 2008 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
747 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
