Question about Kitchen Ranges
Tappan series 110 gas range
The alarm clock keeps beeping even in the clock function. this questions was answered before. how do i disarm it?
  • Anonymous Nov 28, 2008
    The clock sounds like an annoying alarm clock - flip it to timer and it stops.
2 Suggested Answers
  • 3 Answers
SOURCE: tappan series 110 gas range
Takes about 15 minutes to fix. You will need a philips head screwdriver, pair of scissors and a butter knife. What you're going to do is cut the wire to the beeper. Your clock will still function.
Start by removing the glass faceplate that encloses your clock. By removing the 2 screws on either side of the metal housing, you can remove the faceplate (you'll have to remove the clock's pushbuttons, but that isn't hard, either. I used some spring-loaded pliers to get a good purchase, then pulled straight back. Oh yeah. You need pliers, too. Don't worry, you won't break the buttons; they'll snap out and push back in, later). Use the butter-knife to carefully work the glass out of the metal frame. The actual clock is secured by a couple more screws, which are easily removed, once you've removed the abovementioned faceplate.
[The clock, btw, is made by Fridgidaire (part # AP2125434 ), in case you want to replace it. Costs more than $130(!)]
If you haven't already unplugged the stove, now is a good time. Do not touch the two metal connectors of the two most prominent wires on the back of the clock, when the unit is plugged in! Yes, it's the voice of experience, talking...
You will notice, when you're looking at the back of the clock unit, a small metal disc, enclosed in plastic. If you plug in the stove, and listen, you should hear the beeping coming from this area. There is a medium-sized hole in the middle of the plastic housing, allowing access to the metal disc. There are two very small wires, red and black, leading into the housing and attached to the disc in two places. One wire is attached to essentially the center part of the disc. The other wire (in my case, the black wire) is attached rather toward the outer edge of the metal disc. The outer edge is even a slightly different color, so you can identify the two parts. In my case, the sound was emitting from the outer edge, as opposed to the center portion of the disc. If you press a Q-tip against the center portion of the disc (thru the hole in the plastic housing), and the beeping continues, unchanged, the sound is probably coming from the outer edge. You can check by bending the Q-tip, and working the tip over to the edge of the metal disc--by applying pressure, you should hear the sound change, slightly.
Unplug the unit, and cut the wire that corresponds to the part of the disc the sound is coming from--that should solve the problem!
Posted on Nov 16, 2009
I have a tappan range that keeps getting F1/F3 in on the display panel.
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Mar 03, 2010 | Tappan TGF363 Gas Kitchen Range
Apr 03, 2009 | Tappan TGF320 Gas Kitchen Range
OVEN SHUTTING OFF, CLOCK FLASHING
ve continually had the same problem for years. Now the display flashes F1 and beeps continually and I have to keep the unit unplugged. I can use the burners and manually light them but the oven is unavailable because there's no power.
Mar 29, 2009 | Tappan TGF657 Gas Kitchen Range
TAPPAN GAS RANGE, CLOCK CONTINUALLY BEEPS. IS IT AN ALARM FOR GAS LEAK OR ANOTHER PROBLEM?
I CALLED TAPPAN DIRECTLY. THEY HAD ME TRIP THE BREAKERS WHICH DID NOT HELP. THEN I HAD THE GAS CO COME OUT TO MAKE SURE THERE WASN'T A GAS LEAK. THE CLOCK STOPPED BEEPING ON IT'S OWN AFTER THE SERVICE MAN MOVED THE STOVE OUT TO INSPECT IT. THE NEXT STEP WOULD HAVE BEEN TO HAVE A TAPPAN SERVICE COME OUT, BUT I GUESS I'LL NEVER KNOW WHAT THE REASON WAS. HOPE IT DOESN'T HAPPEN AGAIN,.
Jan 16, 2009 | Tappan TGF363 Gas Kitchen Range
Smell gas no heat
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
Aug 29, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan Series 110 Gas Stove Owners Manual
stovetop works well, oven will not ignite. Whats up?
Feb 04, 2008 | Kitchen Ranges
Tappan gas range is beeping a code
This is what f 2 means for Tappan:
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor
Nov 15, 2007 | Tappan TGF657 Gas Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Kitchen Ranges Logo
372 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
