Question about Pioneer Car Audio & Video
My car radio, Pioneer DEH-P4750MP, 2 years old is connected to the 12v battery system on our boat, and has just suddenly started flashing when turned on. We cant turn it off or input anything. Have to take face off to turn off. Checked power and we are getting 12.6v to unit. Can anyone help
  • sailpuravida Aug 24, 2008
    The radio is not subject to water. IT is well protected in the yacht with other equipment. Surely it would not flash if it had shorted.
  • 39 Answers
Well, it might have something to do with the fact taht it was designed to be installed in a car. theres no waterproofing or weatherproofing. you probably got water in the unit somehow and it shorted. i did the same thing with my pioneer FH-P404 and it cost me more to repair than to replace.
Posted on Aug 23, 2008
I have a pioneer DEH 150 radio it's loses its memory when the isolator switch is turned off in the tractor?
The radio has been wired incorrectly so no 12v battery power is applied to retain memory when the isolator switch is turned off.
Jan 02, 2017 | Pioneer Car Audio & Video
DEH-15UB
hi brian, the remedy to your problem is simple. your power wiring from the unit has been incorrectly connected to the vehicle. from the unit connect the yellow wire "directly" to the battery +12v positive line, and the red wire to a "swiched" +12v positive position on the ignition barrel, OR the yellow and red wires can be joined together directly on the battery +12v positive line. also make sure that the ground connection is 100% secure. cheers.
May 04, 2013 | Pioneer Car Audio & Video
I shut off my car and turn it back on i need to setup the radio and my settings again it doesnt save ! im missing the orange wire for illumination but my deck still illuminates its the memory thats doesnt...
Make sure the yellow wire is going to a source that still has 12v when the key is turned off. The yellow wire controls the memory and needs to be connected to a constant power source.
Sep 08, 2011 | Pioneer DEH-3400 CD Player
Installed Pioneer DEH-1200MP, won't turn on.
sounds like yours acc (red wire) is not connected
Aug 23, 2011 | Pioneer Deh-1200mp Car CD/ MP3 Player
I have a Pioneer DEH-P6400 head unit. I need a wiring diagram so i can reinstall it.
the standard radio diagram is
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
that should help u
Aug 13, 2010 | Pioneer DEH-P6400 CD Player
Radio does not come on
There are a few things you may need to check:
1.Make sure you have 12v to the yellow wire on the harness with a good ground at the black wire, and the red wire should be your ignition switched acc wire.
2.Make sure your fuse under the radios wire harness connector is good.
If all of that is in order hook it up, turn the key on and hit the on/off button on the cd player, most aftermarket radios require you to manually turn them on the first time, and anytime the battery is disconnected. If is still doesn't work the unit is more than likely bad.
Feb 20, 2009 | Pioneer DEH-1600 CD Player
Trying to install pioneer cd player in street rod.
You need:
a 12v + source from the battery (yellow wire)
a 12v + switched with the key (red wire)
a Ground (black wire)
then you need your four speakers hooked up, i'm unsure of the color codes on them but they are usually pairs i.e. green and green with black stripe for one speaker white with black stripe for another etc.
other wires such as illumination (orange) and power antenna (blue) are optional
the illumination (orange) you would connect to 12v + from a headlight switch and it would cause the unit to dim when you turned your headlights on
The power antenna (blue) is used, as the name implies to control a power antenna if you have one, or more commonly as the signal to turn an audio amp on (on the remote connection)
Hope this helps
Feb 15, 2009 | Pioneer DEH-1600 CD Player
Wiring Pioneer DEH-225 to 1996 Kia Sportage
the difference between constant and switched 12V is the constant is usually for the clock and memory. it draws precious little current. the switched would be for the radio and amp once the car is turned on. You can use tape but either a wire nut (not the pink ones) or a crimp on cap would be better than using tape.
Feb 09, 2009 | Pioneer DEH-225 CD Changer
Red wire Pioneer MP 2050?
yes you can. but you risk battery drain in the long run. the ignition switch provides that feature for you... doesnt the old head unit have the wire for that? (red and yellow)
May 04, 2008 | Pioneer DEH-P2000 CD Player
Pioneer deh-1600
i know theres many of people out in this world using google or what ever and need this so here it is for pioneer DEH-1600
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Aug 26, 2007 | Pioneer DEH-1600 CD Player
Car Audio & Video Logo
531 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
