Question about ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard
Replaced RAM; PC keeps shutting down?
Hi. I have an ASUS P5N32-E SLI AI Lifestyle motherboard and a Pentium 2-core 6600 CPU with--until this week--2x 1GB DDR2 RAM sticks (Elixir PC2-5300/DDR2-667, as I remember).
Earlier this week I added more RAM to the system, with two higher quality sticks than the original two (it turns out, though, that these are Elecom PC2-6400/DDR2-800). I also blew out the dust with an air can, for which I had to remove the CPU fan/cover to remove the kind-of thick dust under the fan. I had a bit of trouble replacing it over the CPU, as two of the four holding pins were not intact, but finally got it straightened out.  I'm hoping I didn't damage something--but it doesn't seem so.
The PC shut down soon after booting it up. I removed the original sticks and moved the new pair into the original slots. Seemed okay. I was able to game, and run other programs with no problems.
Over the past few days though, I've experienced intermittent shut-down problems. At first I attributed this to incompatible memory sticks--someone suggested the different densities would affect things. Now, though, I am only using the new RAM and don't know what to do to stabilize my system
I put this PC together myself a year ago with Vista 32-bit, and while I'm 'okay' with putting hardware together, I'm really no good with the software side, so I don't have a clue how to diagnose what's going on. I'd appreciate your help!!
  • ispy88 Sep 08, 2008
    Thanks, Todd...I found it with no problems, but unfortunately, I really don't know what all that means. There are over 50,000 events logged there with several occurring every second, and I am no engineer. The description, either general or details, just doesn't explain anything that I know how to interpret. What I need is a 'click here to fix 100% of your Windows problems...There! All done'. Appreciate your help, but I simply don't know what I'm looking at.
2 suggestions:
1. Make sure the CPU cooler is on properly.
2. Check your power levels. I had a computer which did this. Turned out to be the PSU which eventually died. A different PSU has had the board going for 5 days now, instead of 1 day or just a few minutes.
Posted on Jan 16, 2009
Asus P5n32 Sli Premium
There is a couple of things you can do to troubleshoot this.
If there is an on-board VGA (video) port on the back, try that.
Clear the CMOS. On that spec board there should be a coloured plastic jumper next to or near the motherboard battery like this >>>>>
If there is no jumper then remove the power cord from the back and take the motherboard battery out for half an hour then replace and see if you get a post screen.
If it still suffers from the same symptoms then there could be micro fissures between solder points on the motherboard as Intel's tend to run fairly hot.
This means you have to re-float the motherboard and is a last resort repair.
If you need anymore help or advice please post back.
Good luck.
Aug 12, 2009 | ASUS AI Lifestyle P5N32-E SLI...
Help on Asus P5N32-E SLI Motherboard and hard disk
I am an advocate of ASUS boards..rock solid...Vista on the other hand...problems occur out of no where...when problems arise you always have to ask yourself" what has changed"..and work backwords from there.
Jul 26, 2009 | ASUS AI Lifestyle P5N32-E SLI...
ASUS P5N32-SLI Premium mobo w/ WinXP Pro (SP3). System dead
After doing all of that and nothing has changed, sounds to me like your mobo is bad
Jun 26, 2009 | ASUS AI Lifestyle P5N32-E SLI...
System has been working fine for several years. Now on boot up, shows initial screen with ASUS information (motherboard model P5N32-SLI SE Deluxe, Press DEL to run Setup). No BIOS beeps. Warm reboot,...
Are you able to enter into the BIOS settings by pressing DEL?
If so, load default settings in the BIOS and try booting up again.
Best wishes,
May 05, 2009 | ASUS AI Lifestyle P5N32-E SLI...
ASUS P5N32-SLI Premium/WiFi-AP
they dont sell them u need clal asus .com ask f they have one 5 10 bucks ok or else just dont use it alsoways install i o shild 1st then mobo
Oct 13, 2008 | ASUS AI Lifestyle P5N32-SLI...
No boot, continuous Beep
I would take the CPU back out. Remove the excess thermal compound, you should only use a very thin layer. Make sure the CPU is oriented and seated properly.
Jun 06, 2008 | ASUS AI Lifestyle P5N32-E SLI...
Problem in my asus motherboard
I don't understand the exact problem you are facing but hope that you are getting your problem due to the processor. If possible, try with dual core processor.
Feb 14, 2008 | ASUS AI Lifestyle P5N32-E SLI...
Systme shuts down
as i think this is purely the problem with the smps which is located at the top inside the cpu ...
due to some power s voltage variation the smps is out .. there is no other problem so just replace the smps your problem will be solved ....
Feb 11, 2008 | ASUS AI Lifestyle P5N32-E SLI...
ASUS AI Lifestyle P5N32-E SLI (P5N32-E-SLI-GREEN) Motherboard Logo
123 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
