Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
My tv display the view as three images
I am seeing three views on one single image
  • JVC Master
  • 8,617 Answers
You need to replace the convergence ICs they are both stk392-110 you can get replacement at the following link with free instructions, they also have the kit which includes both ICs and all new resistors for your model .
http://servicemanuals.vstore.ca/
Posted on Aug 23, 2008
WHEN I AM RECORDING I DON'T SEE ANY VIEW PICTUREONLY, I CAN PLAY CASSETTE I CAN VIEW PICTURE.
Manufacturers default feature functions makes capturing while viewing with lense. Alternately, capturng images whiles observing the display screen least makes image display at lense. Refer to the camera user guide to ascertain the methods available.
Mar 02, 2011 | Sony Handycam DCR-TRV27 Mini DV Digital...
I have a samsung hp5033 plasma for 18 months and is now having pixel problems. 3/4 of the picture is showing fuzzy tiny squares, this started 3 days ago and seems to get worse. I have tried to self...
Hello rqromero2,
I found this on HP's website. I hope it helps
Picture quality problems (such as lines, fuzzy image, or wrong colors)Check the cables and connections:
  1. Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
  2. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
    Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal.
    For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away.
    If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and .
    If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Open OSD to adjust the picture:
    Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed.
    If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
If this dosent solve your problem, letus know and we will find another solution,
Dahaka
Jul 22, 2008 | Televison & Video
I cant see the preview of images&live video i took
Link
"USER GUIDE FOR SONY DSC-T1
You can view images shot almost immediately on the LCD Screen. You can select the following 3 methods for viewing images.
1)Single-image screen
2)Index Screen
3)On TV Screen
See link for manual attached and look for pages35-37.
Thank you.
Aug 01, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Screen does not display image
make the "live view"/"viewing screen" first enable by locating it in your menu or your settings. then after that you can go back from taking picture by using the viewing screen
in regards of viewing the pictures taken, press the display button. keep pressing until the viewing screen appears
Apr 30, 2010 | Canon PowerShot G9 Digital Camera
Camera giving invertd image.
The camera displays an inverted image on the LCD camera screen or when you view the image on windows vista? If it is Vista what program are you using to view the image? If it is the camera check the settings on the camera for the special effects settings and see if the image inversion setting is on. Ther could also be a problem with the LCD display on the camera.
Sep 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
I'm unable to get a full size image on my D80's monitor.
You must have accidentally hit the Thumbnail button while viewing photos (the one with a magnifying glass and 4-way arrow). Press the Playback Zoom button (bottom one with just the magnifying glass) to go back to single frame view. If you keep pressing the Zoom button it will zoom in further on the image you are viewing, and you can use the arrows to move around in it.
Feb 07, 2009 | Nikon D80 Digital Camera with 18-135mm...
Puzzled about simultaneous laptop+TV screen viewing way to setup
you still havnt given any extra info.
your pc has s-video your tv has s-video..
you link it up to view pc data on tv via fn +f4....(or whichever f key with square icon on it)
as soon as you link up nothing is seen on tv press fn key and f4 key together and you can see image on tv and pc press again image only on tv press again image only on pc again....
to watch continuous go to control panel click display,select screen saver and click powe and disable or reconfig sleep mode,hibernate.
eg..turn of monitor=never...turn off disks=never...system standby=never....change minute countdown in screensaver.
eg wait =5min change field to 2000min...
to view screen size on tv you use tv config 4.3,16.9,cinema,widescreen etc...
Jan 28, 2009 | HP Pavilion dv4000 Notebook
E-mail pictures/photos
Mail providers usually restrict images to be automatically displayed in order to protect your privacy. When someone send you an email with image and when you viewed that image it is possible to the sender know that you have read/view the mail. Who knows Who send you what!
IF you want to view image, on the upper side you should see "Display images below....." or may be similar words
Jan 21, 2009 | Computers & Internet
HV-175 LCD
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Check the  display issue with  a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV , switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Try to Reset the TV ( LCD) quality options. Please look in to User Guide to make the TV to factory Defaults..
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV . If the image quality problems still exists across all types of signal sources, the TV should be serviced.
I hope that this should resolve the issue. However, if the issue still persists then please contact LCD manufacturer for further more on the issue.
Bye.
Oct 17, 2007 | Proview HV-177 17 in. HD-Ready LCD...
What is the rate of continuous advance?
The speed is selectable from 3 types at the continuous advance. Continuous advance: Single shot AF: max. 1.8 fps (live view and anti-shake are activated for each frame. TIFF image cannot be taken), continuous AF: max. 1.9 fps (live view, AF, AE, anti-shake are activated for each frame. TIFF image cannot be taken.) Hi-Speed continuous advance: max. 2.7 fps (Anti-shake is activated for each frame. AF, AE, WB, and live view are fixed at the first frame. TIFF image cannot be taken.) UHS continuous advance: 7 fps. (Image size is fixed at 640x480. AF, AE, and WB are fixed at the first frame. TIFF and RAW image cannot be taken. Digital zoom disabled.) Actual speed may vary depending on the subjects and shooting conditions. * Three frames can be taken continuously in normal and Hi continuous mode. *In UHS mode, the images can be taken as much as possible to the limitation of the storage capacity. For reference, STD: 180 frames, FINE: 160 frames, X. FINE: 100 frames (approx.).
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
