Question about GE Profile PDW8400J Built-in Dishwasher
My controls are locked
How do I unlock my controls. The lock was accidentally pressed for 3 seconds which locks all the controls.
  • 1 more comment
  • kanddchoate Aug 28, 2008
    I have the ame problem...please help!
  • rantessa Sep 01, 2008
    My dishwasher controls are locked too. How do I fix this problem.
  • Anonymous May 14, 2009
    that didn't work
If you accidentally pressed "Heated Dry" for 3 seconds and it locked your controls, just press the same button for 3 seconds and it will unlock.
Posted on Oct 30, 2008
SOURCE:
How do I unlock the control panel of a ge microwave oven?
See the link
Many microwave control panels can be locked to prevent accidental use or access by children.
There are two different ways to lock the control panel:
  1. Press and hold the CLEAR/OFF pad for 3 seconds. The display will show "LOCK" and then revert to the time of day. A small "L" will appear in the corner of the display as a reminder that the control panel is locked. If anyone tries to use the microwave, the display will show "LOCK".
  2. On some models, press and hold the 5 and 7 pads simultaneously for 3 seconds.
To unlock the control: Repeat the procedure which was used to lock the control. (Press and hold the CLEAR/OFF pad for about 3 seconds or hold the 5 and 7 pad simultaneously for 3 seconds.)
unlock the control panel of ge microwave Google Search
Nov 05, 2017 | GE Microwave Ovens
I have a code of loc coming on and my dryer wont work how can I fix this issue??
The control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
May 29, 2015 | Frigidaire ATF6000ES Front Load Washer
Control locked
Howdy:) Try this:
Microwave - Explanation of the Child Lock Out Feature
Farmerbear at FixYa.com
Sep 14, 2010 | GE Advantium 120 Convection/Microwave Oven
I have accidentally locked my microwave oven (profile performance convection oven). I was cleaning the front. Can you tell me what to do?
Got you covered. Here you go:
That info is from GE
Hope that does the trick.
Regards, Farmerbear at FixYa.com
Sep 13, 2010 | General Electric Microwave Oven
Control locked. How do you unlock it?
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
Check below link for detailed explanations
http://www.fixya.com/support/r3608801-control_panel_lock
Courtesy JSROCK
Mar 31, 2010 | Kenmore Elite 45986 Front Load Washer
Controls locked light
Courtesy JSROCK
Mar 31, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Control locked how do I unlock?
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds to 10 seconds.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Controls locked on washer and cant unlock them
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Mar 15, 2010 | Maytag Washing Machines
"CONTROL LOCK " light is on. How do I get appliance to work?
Mar 15, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How to recode remote to vahicle
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press lock or unlock button. Within 10 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control.
Jan 18, 2010 | 2003 Honda Civic
GE Profile PDW8400J Built-in Dishwasher Logo
1,094 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
