Question about Brother HL-5240 Laser Printer
Printer Looses Connection with Computer
I can boot whole system (XPSP3), and after an hour or so, and after printing quite a bit, the printer flags that it has lost connection with the PC.
Currently connected thru a powered 8 port USB hub.
Switch it on and off and it's OK for another couple of hours.
I tried deleting and re-installing the printer but it still does it.
As the printer sits at my elbow I can re-boot it easily but it IS a bit of a pain.
  • kangabill Aug 23, 2008
    Geordie09; will give it a try and come back in about 24 hours.
    I'm an Aussie, its 1930 and I'm tired.
    many thanks for the tip.
  • kangabill Aug 29, 2008
    Solution so simple that I'm ashamed I even asked. You never think about cable length. Also I had 2 cables coupled thus losong signal strength.
    Novelist:
  • 125 Answers
It sounds like the 8 port HUB you are running the devices through is starved for power , either buy a new one or unplug some unused devices.
This should fix that problem
if not please tell me
Cheers
Posted on Aug 23, 2008
  • Josh Gahan
    Josh Gahan Aug 29, 2008
    Hahah no worries mate , well don't worry we all have moments like that trust me ;)
    Glad i put you on the right path :D
Printer reading offline
The printer connects via a radio link which may have a weak signal, or the card may fail. It could be the computer which has lost the connection. Try closing down the computer, then re-booting. If the printer is soe distance away, try moving it closer.
Feb 25, 2014 | Canon PIXMA MX340 Wireless Office...
Canon mx 882 printer looses wifi connection
It could be that your printer or your router is losing the ip address. You can set a permanent IP address in the machine on the same range as your router. eg 192.168.x.50.
This means the router will always find it and you can also set the address in printer port settings on your computer in the control panel.
Nov 20, 2017 | Canon PIXMA MX882 Wireless All-in-One...
Looses connection with network
Common for this printer. Instead of setting it up as a network printer, attach it locally to a machine and share it. It will be much more stable.
Aug 09, 2012 | Lexmark T620 Laser Printer
I have a lexmark x2350 (all-in-one,2300 Series).In the troubleshoot ,said printer status ready.But when i try print,or take a print page text,i hear:printing started,printing complete,but the machine don`t...
Try to update your printer driver. Please visit the Lexmark website at http://bit.ly/qQJd8g. Select your operating system to download the file.
If that doesn't help, follow the steps below: 1. Disconnect the printer from your computer. 2. On your computer, go to Control Panel > Printers and Faxes. Delete the Lexmark X2350 print object. 3. Reboot your pc. 4. Once the pc completely boots up, reconnect the printer into the pc. Wait until your pc fully recognizes the USB connection. 5. To ensure the print object has been successfully created automatically. Go to Control Panel > Printers and Faxes. You should see a new Lexmark X2350 print object in the list. 6. Try to print again.
Jul 28, 2011 | Lexmark X2350 All-In-One InkJet Printer
Lexmark t630 error says remove paper standard bin. Never knew anything about standard bin -- can't get it to print, and yes, there is a connection to the computer
The Remove Paper Standard Bin error can be possibly caused by the exit flag that is out of position, stuck or broken. Follow troubleshooting steps found at http://bit.ly/dhOTEo. If any part of the flag or holder appears to be broken, contact Lexmark technical support or a local authorized service provider.
Sep 20, 2010 | Lexmark T630 Laser Printer
ERROR COMMUNICATING WITH DEVICE - HAVE UNSTALL AND RE-INSTALLED SOFTWARE, DOES SCAN FROM PAINT- BUT DOESN'T SCAN FROM THE PRINTER OR THE COMPUTER - I HAVE ALSO UNINSTALLED THE VIRUS PROGRAM AND STILL...
The best thing you could do is to, ( A ) disconnect the unit from computer. ( B ) un-install the software from your computer and re-boot. ( C ) Disconnect all external devices from your unit and re-start unit.
( D ) Check your device manager for any outstanding marks or flags. ( If found, remove them and re-boot. ) Check device manager again. If clear or flags,( E ) reload your software for your photosmart All-in-One printer. Note. you must have this unit disconnected, both the USB and Power connection to the Printer, until the software asked to power up and Plug in USB connections.
Hope this infomation has been of help to you.
Please rate you techs.
Oct 06, 2009 | HP Photosmart Premium C309A All-In-One...
Cannot delete a print job
Microsoft has the help you need for this issue and I wont try to give you long and possibly misleading information on here.
It is a common problem but the answer is here
http://support.microsoft.com/kb/946737
You need to refer to method "D" about half way down the page
Once you clear the print job check you dont have any extra printers installed as quite often happens in these situations. If you have then delete your extra printer installations.
Oct 03, 2009 | HP Office Equipment & Supplies
HP 7210 all-in-one is having trouble printing. At best, will print just the first inch or so of the document---at worst, prints only a few symbols at the top, or prints a meaningless barcode-like pattern,...
It was a connectivity problem between the computer and printer. I had recently switched from a direct USB connection to a non-powered USB hub. Apparently, routing through the hub resulted in an inadequate, inconsistent connection between the computer and printer, so print jobs were garbled or only parts of the page were getting printed. Switching the USB cable back to a direct connection between the printer and computer completely resolved the problem.
Dec 02, 2008 | HP Officejet 7210 All-In-One InkJet...
My printer
If you're using a MAC System
> Delete the printer in the printer list ( make sure that there's no printer left in the printer list for the CX 8400 )
> Click on the plus sign to add the printer again in the printer list
in the Printer Brouser window you should see the printer listed there via USB connection., Click on it and check under
"Print Using" if the CX8400 driver is listed ( not a guten print driver )
> If CX8400 driver is listed under Print Using., click on add and try to print.
> If "guten print driver" or no driver selected you may need to uninstall the printer driver and download a driver from the epson website.
Steps to uninstall the printer driver:
1.) Make sure that the printer is deleted from the printer list
2.) Click and open MAC or Apple HD / Library / Printer., and look for the Epson folder (drag the whole Epson Folder to your trash bin)
3.) Click and open MAC or Apple HD / Library / Receipts., and look for "Epson Printer driver package or Epson Printer driver.pkg and drag it toyur trash..
4.) disconnect the connection from your Computer to Printer (USB)
5.) Empty your trash bin and restart your computer
Steps to download printer driver:
1.) Download Printer Driver Ver 3.88 epson12439.dmg
try this link > http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=90342&prodoid=63069506&infoType=Downloads&platform=Macintosh
2.) Ones it is downladed to your desktop click and open the file or click on the "Vise X Installer" / Install and then quit
3.) Connect the printer to your computer (USB)
4.) Click on the Apple Icon / System Preferences / Print and Fax.,
Click on the plus sign to add the printer and print
Jun 27, 2008 | Epson CX8400 All-In-One InkJet Printer
Printer stopped working claiming the jobs have been 'stopped' and giving no explanation.
Hi Plug out the usb cable from the cpu. Try deleting the printers from the printers window(START, Printers and Faxes), uninstall the software. Power off the printer and unplug power adapter. After the printer has been deleted from the printer window, plug it back in and reconnect back to computer. Then try a new installation of the printer and software. The pending documents that have been stopped should now not be in the spooled documents.
May 02, 2007 | Epson Stylus DX4200 All-In-One InkJet...
Brother HL-5240 Laser Printer Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
