Question about HP Computers & Internet
Looking for a wireless network security key - HP Computers & Internet
  • 876 Answers
Did you just set up a router and a wireless network? Tell me about what you have please. Each key is different. We can't give you a key, but if you have one I might be able to help you locate it.
Posted on Aug 23, 2008
Reset password on wireless router
That more than likely mean you have put the password in wrong or you are using the wrong authentication type.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
Jun 08, 2012 | NetGear N300 Wireless Router
Can no longer connect to home wireless intranet. Says I'm connected but when I try to get on it says I'm not. Yellow triangle w/black ! in it. Wireless light on computer base is constnatly
AuthenticationThat means you probably don't have the password or theAuthentication Type set correctly.
May 29, 2012 | Acer Aspire 5742Z-4200 Notebook
Dell vostro a860 won't connect to internet
Why not? Do you have the wireless turned on? Did you put the correct password in?
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
If you put the wrong password in, it will never connect. it will keep trying to connect but never will.
Authentication
That means you probably don't have the password or the Authentication Type set correctly.
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 28, 2012 | Dell Vostro A860 Notebook
Thinkpad having limited to no connectivity
More than likely your password is wrong or the Authentication Type such as WEP, WPA, WPA-2 is wrong.
May 11, 2012 | Lenovo ThinkPad T420 Notebook
Dell inspiron 8000 password authentication system
Are you talking about the authentication process on trying to connect using wireless?
May 10, 2012 | Dell Computers & Internet
Cannot get the internet to work
May 08, 2012 | Computers & Internet
I dont know what my network key is.
open new Internet Explorer and type in address Bar " http://192.168.1.1" and hit enter.
Leave user name field blank and type "admin" for the password.If you changed the router password, then log in using your password to login to the router.
Once you are in the router setup page, click on the Wireless Tab at the very top of the page. Once you are in the Wireless Tab, just right under the word Wireless you click the sub tab that Wireless Security. On this page you will see the Security Mode. If your security mode is set to WEP you will have four sets of keys available. To known which key to use look for the Default Transmit (Tx) Key, If your default transmit key is set to 1, then you will use the key in Network key 1 to connect to the wireless network. Now if your Security mode is set to WPA (Personal/Pres-Shared Key/PSK) what's inside the WPA-shared key or Pass phrase / Personal Key box is the network key for your wireless network.
May 15, 2011 | Linksys Wireless-G WRT54G Router
What does it mean by network security key
The name 'network security key' is itself self-explanatory. Every network has a security key and you will need this key to be a part of that network. Just as is the case of any other term that comes from the field of network engineering, there are a lot more details attached to this term, too. So, let us try to understand all the aspects related to network security key
An explanation as to why we need a wireless network security key is not even required. Still, if any one is skeptical about adding any complexity to their available wireless network, just think about it. Your wireless network range can be detected by any other computer with a wireless setup and that comes within the range of the network. So, without you knowing, it's very easy for any user to get connected to your wireless network and gain access to all the data that you intend to share only with those computers with which you have setup your wireless network. So, what is a wireless network security key and how is it useful in such situations?
Well, a network security key or passphrase is something like a password, which any user who wants to connect to your computer will require. But, I think that before we go into the details of figuring out, how to get network security key for wireless computer, we should take a look at the different methods of securing your wireless network
Oct 03, 2010 | Computers & Internet
D-link 802.11g wireless router security key
First, go to your router's ip address (192.168.0.1).
Then, login to your router (default username: admin default pass: blank or admin)
There, under tools or network security or similar to that sort, look for your network/WEP key. There, you should be able to find your network key to access the router's network, and even change it if needed.'
Hope this helps, please rate ^_^
Jun 19, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I don't know my security key or network key
Sign into the router and look under the wireless settings.
You can reset the key but you'll have to reset it on your wireless devices too. You have to make sure your wireless device (laptop for example) has the wireless setup on the right channel and security setting too.
Apr 11, 2009 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
20 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
