Question about HP Officejet 4215v All-in-One Printer
Just doesn't print any more
It has stopped communicating with my pc. I tried downloading the new and improved driver software, but my pc says it can't finish installing it correctly and to get help from an expert, well here I am. Please advise. You can reach me at obikabe52@yahoo.com. Thanks
  • 876 Answers
Please do a clean download and install in this manner:
Uninstall the old software by going to Start>Control Panel>install and uninstall>scroll down until you find your printer if it is still there and click on uninstall.
Turn off the machine and unplug it
Turn off all your running programs including your virus control
(look in the lower right corner and click on each little icon there and turn off everything you can)
Now download the driver and SAVE it to your desktop
Click on it to install and follow the directions carefully. When it is finished, if it has not told you to reconnect your printer, do so now.
Restart your computer.
Good Luck. Please let me know if this works and rate my solution. Thank You.
Posted on Aug 23, 2008
Canon LBP6000. Data transfer to the printer timed out, or a transfer error has occurred. Click [Resolve Error] to resume printing, or click [Cancel] after pausing the job, then try to print again.
Best to un-install the printer drivers, softwares related to this printer. Go to Canon.com and download the latest drivers and software. Connect the printer to the computer and let the computer recognise it and then install the drivers from your download. You can also check if there is any damage to the cable as this could also stop the communication between the computer and printer.
Dec 09, 2013 | Canon LBP6000 Laser Printer
Wont print from computer
This sounds like a communication problem. Try to uninstall the Lexmark driver and download an updated driver online: http://bit.ly/McHL54
If it doesn't help, check your security software (firewall) if all Lexmark applications are allowed. You can also try to update the firmware of your printer: http://bit.ly/ghfW8H
Aug 18, 2012 | Lexmark Interact S605 All-in-One Color...
Printer (z816) cannot communicate wih computer (WinXP) though it communicated with earlier computer, also XP, and though I installed printer software.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/vcsOlB. Select your operating system, download and execute the file.
Nov 01, 2011 | Lexmark Z816 InkJet Printer
I have a laptop that has vista OS and when I try to print using my Lexmark p3150 printer I get a "trouble communicating with the printer" warning. Is there a driver that will correct this? I...
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ieDcBl. Select your operating system, download and execute the file.
Sep 21, 2011 | Lexmark P3150 All-In-One InkJet Printer
I have a lexmark 3500-4500 printer.it,s not scan.how can i solve this problem? Download: eType1.com/f.php?FNmVjz
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/e8EeXn. Type your model number, select your operating system, download and execute the file.
Scan communication problems could also be due to firewall issues. Make sure to allow full access to all Lexmark software and printer communication processes in the program rules/permissions for your firewall.
Sep 13, 2011 | Lexmark X5470 All-In-One InkJet Printer
My printer which is an lexmark x4650 just stopped working. it says its not installed what do i do.
It could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/iofMNC. Select your operating system, download and execute the file.
Sep 05, 2011 | Lexmark X4650 InkJet Printer
I seem to have lost communication with my printer. It will not print. The ppwer button keeps flashing on and off. I have followed all of the troubleshooting guide suggestions. I have checked all cables,...
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 28, 2011 | Lexmark X1270 All-In-One InkJet Printer
"Communication Not Available" message is displayed
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
Print mode does not work pages come out blank
It could be the cartridges in the printer. Disconnect the printer from your computer. Open the printer cover and remove the cartridges. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges. Reconnect the printer into your computer. Try to print again.
If that doesn't help, try to clean the cartridge nozzles using the Lexmark software on your computer.
  1. Click Start > Programs or All Programs > Lexmark Z2400 Series
  2. Click Maintenance > Clean Cartridges.
  3. Click Print.
  4. Follow the instructions on the computer screen.
  5. If print quality has not improved, then wipe the cartridge nozzles using a slightly moistened soft cloth to clean it from possible dirt and clogs.
You can also reinstall the printer driver on your computer to repair any corrupted files necessary for printer communication and processes.
Jun 22, 2011 | Lexmark Z2490 Multifunctional InkJet...
Software drivers
A driver is a piece of software used by your computer to communicate with a particular peripheral, like your camera or scanner. If your driver isn't updated or properly installed, it may stop your camera from communicating with your PC. This could lead to an abundance of error messages. Drivers are regularly updated, and new versions can help fix problems and bring a significant improvement in performance. There are two main reasons to upgrade drivers. Incompatibility is the most frequent problem solved by a new driver release. And new drivers optimize the communication speed and task sharing between a processor and a peripheral. A new driver can increase performance as much as 50 percent. You can sign up to receive notifications of driver updates from HP.
Sep 08, 2005 | HP Photosmart 945 Digital Camera
HP Officejet 4215v All-in-One Printer Logo
22 people viewed this question
Ben Johnson
