Question about VisionMan VisionVault 4TB Smart NAS Appliance - Gigabit LAN, Hardware RAID 0, 5, Span, 128MB DDR, 4x (SSTE-2NAS30)
Nas SCM400 not working
Can not get into the system to set it up it is plug in and hase 2x400gig wd hard dives in it type in the \\SCM400 for the web base program but get nothing
  • 2 more comments
  • misonet Oct 01, 2008
    There is no default IP adr in the manual. I have contacted Visionman and I am waiting for support to get back to me on this issue, along with the power button does not shut off the unit, nor is the reset working.
  • kdixon3 Oct 03, 2008
    I also have the same problem with the SCM 400. reset button does nothing. hard drive lights dont illuminate at all. the device doesn't seem to go out to get a IP address from my home router (I checked the DHCP clients table from the router admin). Cant connect to it via \\scm400. The drive I have in it is freshly formatted via my PC. I have a single drive in it only.
    ... not sure what to do...
    Kevin.
  • Anonymous Nov 14, 2008
    where is the reset button because the manual says its on the back but i don't see it there. also i was able to connect and set a new admin password then for no reason it disconnected me and i haven't been able to get back on.
  • jwil50n Feb 25, 2009
    Cannot reset unit with reset switch. Unit has a fixed IP address at 192.168.1.2 however I can telnet to port 80 or get any response out of it. Power button does not turn the unit off. I have 4 1TB SATA unformatted drives in this unit. Biggest problem is not being able to reset the unit so that it can get an IP address on my LAN Subnet. I sent my first unit back for replacement assuming that it was defective. However, the second unit has the same problem.
The reason that it goes into recovery mode is because RAID5 is not striping so it has to rebuild the drives to be compatible with RAID5. I used 1TB drives and the 'recovery' took about 16 hours. It would be faster on smaller drives.
This is not a fault in the design, it is how RAID5 works.
Posted on Jan 06, 2009
You must use RAID SATA Drives which are generally twice the cost of regular SATA Drive. I used a couple of WD SATA RAID 1TB Drives ($158.00 each. Apparently when the drives are first inserted (minimun of 2 drives) the onboard firmware formats them for approximately 20 minutes then writes the bootstrap to the drives after which everything works as stipulated in the documentation.
Posted on Mar 12, 2009
Take a look at the front panel indicators, and make sure the network and power lights are steadily illuminated (lower right and lower left). Then check to see that all four drive lights are green and on. If all is well, then try your browser again. The storage unit and the computer you are using must be on the same network for this to work. If the DNS on your network is particularly slow, then you may have to resort to checking the DHCP records on your server or router. Find the IP address that was assigned to the storage unit and type that in the browser instead.
If this still doesn't work, you will need to remove the disks from the unit, erase them on another system, and then re-insert them and power the unit on. This will re-initialize the unit but, of course, this will destroy all the data on the unit.
Posted on Sep 02, 2009
  • jpreston Sep 02, 2009
    clouddd,
    If you are using Malaysian built WD drives, try using Seagate or Hitachi disks. Not every desktop hard drive is built to run in a RAID configuration. The WD's seem particularly unstable, and will fail as you describe after hours of re-syncing.
  • 3 Answers
You cannot use the FQDN name ... you need to typ in http://xx.xx.xx.xx where xx.xx.xx.xx is the default IP adres the device has (you can find this in the manual !)
Posted on Aug 29, 2008
The reason why you can't log into the device is because you MUST put BLANK drives in it. Here is what I did:
1. insterted 4 250GB BLANK initialized drives I freshly formatted and deleted all partitions on them using windows disk management
2. installed all 4 drives into the SCM400
3. Connect the device to a router that is giving out DHCP addresses in the range 192.168.1.x
4. Plug the power cord into the device
5. Turn the device on with the power button onthe front
6. Press and hold the reset button located on the back of the scm400 NAS located near the top of the ethernet port on the top right corner (looking at it from the back) it looks like a little hole with a white button inside
7. The lights for all the harddrives whould startrapidly flashing soon as well as the HD activity light below the 4 seperate HD activity lights on the front.
8. Wait 15 - 20 MINUTES!(for 4x250GB drives) while the scm400 device formats (I assume 0's the 4 HD's) into a stripe configuration and installs the linux software onto the striped volume it creates. LINUX is not runing from a chip it has to install it's self onto the HD.
9. After you have done this you should be able to type \\scm400 into your internet explorer and folders will come up. Go into the Configuration Folder if I remember correctly and click on the index file.
10. This will bring up a login screen type in Login: admin Password: admin
11. It will ask you to change the password do so to something you want it to be.
12. Now you have it working in stripped configuration mode
13. Now that you have a stripped congiguration most will want RAID 5 you will have to modify it to raid 5 or whatever you want it to be.
14. I have unsuccsefully converted the stripped configuration to a RAID 5. It keeps going into recovery mode which starts repairing th 4xHDs in a RAID 5 configuration.
Why the hell is it doing this?
After it recovers this take about 240 minutes the RAID 5 Volume FAILS!
I have jsut recieved a 2nd unit replacement from visionman which took 1 1/2 months to recieve and I am curently having the same thing happen. It is in recovery mode right now. If it fails this time on the new unit I will try using 3 HDs from a fresh restart. What a waste of money and time
THIS UNIT IS A PIECE OF ****!!!. DO NOT BUY
Posted on Nov 14, 2008
Unable to download the Seagate Central NAS 1D driver on my Windows Vista desktop....help?
I think you mean hard drive. NAS devices aren't meant to be plugged into computers. They're meant for networks. NAS means "Network Attached Storage". There should be a disc that comes along with it to set it up. If you don't have one, you can connect to it through a web browser to set it up, thats usually how its done. If you look at the devices in your network, you should find its name, and then you can type in its name in a browser. As an example, if its name is seagate-nas, then you type "seagate-nas\" (without the quotes, and with the '\') into your browser and it should come up
Jan 12, 2015 | Seagate Central 3TB Personal Cloud Storage...
Iomega mdhd 360 n
The following may help:
You can either use the management software: Iomega Discovery Tool Home : Read First
or
Instructions to Direct Connect to NAS:
Unplug the NAS from the router
Unplug the pc from the router (if the pc is wireless, disable wireless)
Using Ethernet Cable, plug the NAS directly into the pc with no other devices attached.
Restart the NAS and wait for it to boot COMPLETELY 100%
The NAS will request an address from the PC which will be an APIPA address (this is a 169. address)
Open up your Start Menu and type in CMD in the search bar and select the CMD program.
Type in "arp -a" in the cmd prompt
The first time you use the arp -a in a cmd prompt, it gives you the 169.x.x.x address of "The PC"
You may have to arp -a twice to get the NAS address.
The second time you use the arp -a I will get another APIPA address in the 169.x.x.x address
Take the new address and use it in the web browser just like normal to access the device
Mar 22, 2014 | Computers & Internet
Wd nas drive red light on
The Smart is on verge of showing that the hard disk has plenty of bad sectors, and cannot be trusted for data.A data recovery expert is needed to get data first and If you can clone the patient hard disk to a new donor hard disk , then your NAS will be up and working.I hope there are no head reading issues.
Sep 07, 2017 | Western Digital Passport Computers &...
How to oppen my WD
You don't. That's the quickest way to guarantee they never work again.
Jan 04, 2014 | Western Digital WD HDD 500GB SATA 25"...
Can't find Verbatim SOHO NAS Desktop Hard Drive 500GB on the network with wndows 7
I do exactly as above, but cant access the NAS. I can reach it from an XP machine and from another win 7 machine, but not this win 7 machine. Whats the problem?
Dec 08, 2010 | Verbatim SOHO NAS Desktop Hard Drive ...
I try to connect DLINK dns 323 to WD TV by USB cable but it not work how can i solve this
The USB port on the D-Link DNS 323 NAS is for a printer only. It won't work with your WD TV. Your best bet would be to plug the WD TV into a PC that is connected to your network along with the D-Link DNS 323 NAS and serve your media files that way.
Sep 04, 2009 | D-Link Dns 323 2-Bay Network Storage...
I've bought the Sumvision SATA net-box NAS enclosure, installed hard drive as described, but I cannot see the web interface for setting up the device. Manual is in very bad english and suggest allocating...
There's a discussion about some problems relating to this enclosure at http://forums.ebuyer.com/showthread.php?t=24636 and you may be able to get some help from the contributors there.
Jun 27, 2009 | Computers & Internet
Cant able to access the 1tb network storage
Consider a few things that may solve the problem:
1. this is how I always like to test; shut down the NAS drive for a minute and reboot; once rebooted see if it is accessible
2. need to know the ip address of the NAS drive and make sure that ip is not blocked by your system firewall (e.g. add that ip into trusted address on the firewall program; or temporarily disable any anti-virus or firewall and see if you can access, and if you can then it is the issue of firewall),
3.unless you have customized the settings, open my computer and on the addressbar type type the ip address if you know (if it is WD Mybook World then you can also try typing \\mybookworld on the address bar); in this case also try it by temporarily disabling any anti-virus or firewall program
4. one way you can figure out the ip for your nas drive is through the router's homepage; since I don't know your router type I can't give you specific steps; but try to get onto the router's main page and see the client's list or DHCP Client's List or something similar where you should see an ip also assigned to the NAS drive which is connected to the same router.
Post the feedback what happens... we'll see... good luck !!!
Jan 09, 2009 | Western Digital My Book World Edition 1TB...
Write and read spead slow; only 10MB/s
This has been a commonly reported concern. Here are a few links that may provide a solution to this problem:
Additionally, some Vista users report better file transfer rates using WinRAR & Teracopy.
For maximum file transfer, also check all elements in your network, i.e. switches & routers, etc. For discussion of max speeds cf. here
Please consult this article from Microsoft to take steps to improve your system's performance with Vista, by clicking here
For troubleshooting performance issues, please see these articles and the links within them: TroubleshootVistaPerformance and Troubleshoot Vista Startup and Vista Diagnostics
Finally, you may wish to consult this General Setup&Maintenance guide.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Dec 24, 2008 | VisionMan VisionVault 4TB Smart NAS...
VisionMan VisionVault 4TB Smart NAS Appliance - Gigabit LAN, Hardware RAID 0, 5, Span, 128MB DDR, 4x (SSTE-2NAS30) Logo
1,349 people viewed this question
Top VisionMan Computers & Internet Experts
David Payne
David Payne
Are you a VisionMan Computer and Internet Expert? Answer questions, earn points and help others
