Question about Pentax *ist DS Digital Camera
USB HOOKUP FOR PENTAX *ist DS
I just got a Pentax *ist DS. I installed the pentax browser and lab software. I followed the instr. for the camera transfer settings but no luck. With the camera hooked up and turned on I do not see any additional drives in my computer. I went to the control panel and used ADD HARDWARE, it recognized it as an *ist DS camera but said that there was an error - "driver needs updating". I tried the update button but it did not find anything. I went to Dell for driver updates but I do not recoginize what to get- would it be a USB driver or what? Pentax says drivers are only needed for Win 98. My USB seems to be OK since my HP scanner uses it without a problem. I had a game pad /controller plugged in to that USB port previously and it seemed to work. I have emailed Pentax cust. support but have not had a reply yet. Any Ideas ?
    Master:
  • 542 Answers
Re: USB HOOKUP FOR PENTAX *ist DS
Try the 98 drivers if it fails, but I see a disturbing note at dpreview that read " USB 2.0 Hi-Speed ". Could it be not USB 1.1 compatible? A few things to clear up: - The update driver is little more than a demo. Do not put much faith in that. Update drivers the old fashioned way. - http://www.usbman.com notes MANY USB issues. It does NOT matter some other USB device works. That derails many from finding their cure. - A card reader is not a bad thing. With that out of the way, unplug the camera, uninstall its software, boot safe mode and remove the Pentax driver if you find it in Device Manager. Boot back up and follow the instructions one more time. Most of the time this issue occurs because: a. The camera was plugged in before the camera software was installed (read the manual.) b. The drivers are not for this OS (read the manual.) c. It must state Windows ME (read the manuals/stickers/etc.) d. The USB port is broken. Try another port. e. The supplied software was not tested on Windows ME. Try a new download from Pentax. In closing if it doesn't work and they don't offer support, pack it up and return it as defective.
Posted on Aug 30, 2005
    Master:
  • 542 Answers
You might try unplugging the other USB devices. If you have several devices that are drawing power from the USB, it can cause a problem. If you are using a USB hub, it should be a powered hub. Here is a link to a site that has a USB troubleshooter: http://www.usbman.com/
0 characters
3 Points
What is the largest capacity SD card that I can use with a Pentax IST ds camera?
The camera uses SD memory cards. SD cards max out at 2GB. SDHC cards run from 4GB up, but they cannot be used in SD devices. SD cards can be used in SDHC devices.
The short answer is 2GB.
Jan 11, 2010 | Pentax *ist DS Digital Camera
I want to obtain a larger memory card (currently have a 1GB) but everyone we buy I have been unalbe to get them to format/ I have a pentax ist DS
You should be able to use 2GB SD cards. Cards larger than 2GB are actually SDHC cards and will not work with this camera.
Oct 13, 2009 | Pentax *ist DS Digital Camera
Firmware install on Pentax ist DS. Had Ver2.0 & everything worked fine. Simply wanted to upgrade to V2.02 to used SDHC cards. User Power AC and install ran approx 90 secs and displayed showed half way...
You need to go to the support section of the Pentax website and engage in a live chat with a service tech using your computer or even a phone conversation to resolve your problem.
Oct 10, 2009 | Pentax *ist DS Digital Camera
*IST DS autofocus
Try using another lens, if this solves the problem you have a lens problem. If not the camera is the problem.
Jul 03, 2009 | Pentax *ist D Digital Camera
Using Pentax lenses from 35 mm on the digital camera.....
I have old Lenses that I use; you must set your lens to manual, Switch left hand front of body. That should resolve the problem.
Jul 02, 2008 | Pentax *ist DS Digital Camera
Pentax ist DS aperture setting problems
If you want to use the aperture ring on the lens you must enable this in the Custom settings menu. jamknight, sounds like your camera may need a professional cleaning.
Feb 01, 2008 | Pentax *ist DS Digital Camera
Pentax *ist DS USB Cable
You need a Pentax USB cable I-USB17.
You can get it online from B&H photo or Adorama camera.
I would go with B&H photo personally.
Oct 26, 2007 | Pentax *ist DL Digital Camera
Need a 'User' or 'Operating Manual'.
Go to the following page and select category "cameras", sub category "Digital SLR" & you will find all the *istDS manuals for download: http://www.pentaximaging.com/customer_care/manuals_literature Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Pentax *ist DS Digital Camera
My Pentax *ist* ds doesn't power on half the time!
Check the battery contacts in the camera. Perhaps they are dirty and need a clean. Make sure you're not using Alkaline battereis and if you use rechargeables they are fully recharged and not getting too old to hold a full charge. Apart from that, without further information I can't help any more. BMW
Jun 29, 2006 | Pentax *ist DS Digital Camera
Pentax *ist DS Digital Camera Logo
59 people viewed this question
Top Pentax Digital Cameras Experts
halotheracer
halotheracer
Are you a Pentax Digital Camera Expert? Answer questions, earn points and help others
