Question about HP PhotoSmart 7960 InkJet Printer
INK Cartridge error
The printer is saying photo cartridge error for hp58 I then bought a new refurbished cartridge and it is saying the same thing. any advice?
  • 876 Answers
Take a l;ook at the slot where the cartridge goes. Does it have any dried ink or ink blobs. If so you can turn off the machine and unplug it and clean the slots with0a little rubbing alc0hol on a Qtip. At the same time, make sure that there ae no bent or broken wire holders and that the cartridge seats well. Also look at the cartridge itself. Is it leaking?
When you have finished this try turning off and unplugging your printer for several minutes and see if it will reset itself.
I hope this works for you, If not be sure to get back to us. Thank you for using Fix ya. i would appreciate a rating for this solution.
Posted on Aug 23, 2008
It says I have no black ink but it's a new cartridge
I have an MG2560 which did the same thing twice. The first time, there was still a bit of tape on the electronic connections on the ink cartridge. Once I cleaned this off, it worked fine. The second time, no matter what I did, the error message kept saying no black ink. I took the cartridge back to the shop and got another one. I fitted it and the printer worked perfectly.
Oct 03, 2015 | Canon USA PIXMA MG2220 Photo All-In-One...
I have inserted a new black ink cartridge (34) and get an error message 'left cartridge missing, insert black or colour photo cartridge' have peeled label off and reinserted several times but still...
Make sure you are inserting a genuine Lexmark cartridge. Try to insert a different known working cartridge, maybe your old black cartridge, to determine if your new cartridge is faulty. If inserting your old black cartridge gives you a message saying "very low ink" or something to that effect, then most probably there's something wrong with the new black cartridge. Have it replaced with a new one from the store where you bought it from. You may also contact Lexmark Technical Support Center for assistance.
Aug 12, 2011 | Lexmark X8350 All-In-One InkJet Printer
I have the Dell AIO 926 and i have an Error Message. Error 1203 Consult User's Guide I cannot print, what do i do?
error 1203's error name is print head short which indicates a short circuit in the print head has occurred. solution to this problem is to disconnect and then reconnect the printer power cable. Reinstall the ink cartridges.For more information, see Replacing Ink Cartridges.
  • Turn on your printer.
  • Lift the printer unit, and then position the scanner support between the tabs to hold it open.
  • The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  • Press down on the ink cartridge lever to raise each ink cartridge lid.
    Remove the old ink cartridges.
  • Store the cartridges in an air-tight container, such as the storage unit you received with your photo cartridge, or dispose of them properly.
  • If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
    NOTE: The following illustration shows a black cartridge and a color cartridge (used for normal printing). For photo printing, use a photo cartridge and a color cartridge.
    Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.
    Snap each lid closed.
    Hold the printer unit up, push the scanner support back to unlock it, and then lower the printer unit until it is completely closed.
  • Jun 05, 2011 | Office Equipment & Supplies
    My lexmark z611 only prints blank pages with nothing on them, i bought a brand new ink cartridge that is black ink for it and it says it is low on ink for some odd reason but when i print things in color...
    Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
    May 15, 2011 | Lexmark Z611 InkJet Photo Printer
    I just installed a new CL41 Color ink cartridge into my Canon Pixma mp210, and it does not recognize it. It keeps saying the printer is empty, or displaying Error Code E5. ANother thing is when I go to see...
    maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
    Sep 10, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    Printer is not working new ink
    Cartridge World stores have a 100% satisfaction guarantee; they will repair, replace, or refund any cartridge you find unsatisfactory. You need to go to the store you purchased this cartridge from and request a new one.
    Sep 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
    Giant blobs of ink on every photo...
    If you aren't currently, use the cartridge that the printer's manual says is for photos. Photo paper requires a different kind of ink.
    Jun 26, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
    Error u071 I have a pixma ip6700D when I changed the ink cartridge I got the error message UO71 that says I have more than one cartridge of the same color, which I don't.  I have reseated the cartridge,...
    Call Canon Tech Support @ 1 800 828 4040
    This error is caused by a malfunction of the cartridge chip.
    Canon will replace the cartridge(s) at no cost under warranty.
    Jan 12, 2009 | Canon Pixma iP6600D InkJet Photo Printer
    Not recognizing cartridge
    myprinter tells me"noblack ink," they are both b it is brand new cartridge why?this is the second black ink cartridge i have bought it says the same thing.i always buy "BROTHER"
    Oct 27, 2008 | Brother MFC 420CN All-In-One InkJet...
    Lexmark P315 InkJet Photo Printer Ink Cartridge Problem
    Hi, I know this might sound really bad but have you made sure that you have taken ALL the little bits of plastic and covers that are sometimes on the new cartidges?
    Also are you using the exact same cartridge as before?
    Another thing you could do to bypass the problem is to have your one refilled. That will at least fix the problem for the immediate.
    Does your printer have some software where you can run a clean print head and do an align and other stuff. If so you could try those too.
    Lets us know.
    Oct 25, 2007 | Lexmark P315 InkJet Photo Printer
    HP PhotoSmart 7960 InkJet Printer Logo
    126 people viewed this question
    Ben Johnson
