Question about HP Vs17 17" LCD Flat Panel Monitor
Not working. I got this vs17 from a friend, and when i plug it in and stuff, all it does, is the blue power button at the bottom just flashes constantly and the screen is black. Any solutions?
  • Anonymous Oct 05, 2008
    pwm i c nomber not found
  • 876 Answers
Did you install the software for the monitor? If you do not have the disc, You can download the driver here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=447382&lc=en&cc=us&dlc=en&submit.y=7&submit.x=8&lang=en&cc=us
If you have any further problems,let me know. Thank You for using Fix ya!
Posted on Aug 23, 2008
  • 2 more comments
  • Gayle Ashbach
    Gayle Ashbach Aug 24, 2008
    Try downloading the driver using a differentmonitor, this way: ( Please print this out and follow it exactly.)
    When you have located the correct driver for your machine,
    http://h10025.www1.hp.com/ewfrf/wc/softw...
    Be sure you choose the correct driver of those offered.
    Please do a clean download and install as follows:
    Turn off all your running programs including your virus control
    (look in the lower right corner and click on each little icon there and turn off everything you can)
    Place a new CD in your copying drive
    Now download the driver and SAVE it to that drive. (you will get a window-just highlight the copying drive your CD is in and be sure that it appears in the top bar) then click save.
    After it has finished, reattach you new monitor and turn it on.
    Place your new CD in your CD-rom drive. Go to My computer> open that drive and double click on the exe file you just downloaded to install. Installation should begin immediately. Follow all instuctions.
    Restart your computer.
    I hope this works for you. I am going to do some more research on your monitor. Did it work fine for your friend?
    Please let me know the results of this installation and if it works for you please rate my solution higher. Thank You.
  • Gayle Ashbach
    I am going to give you information as I find it, without comment. If something works, please let me know immediately.
    Your monitor uses only one cable:
    VGA cable: Standard VGA 15-pin cable.
  • Gayle Ashbach
    You can go to this address to download the manual for your monitor:
    http://h10025.www1.hp.com/ewfrf/wc/manua...
    It has all connection instructions for both the VS model and the F model . Be sure to follow instructions for your VS model.
    It is in PDF format, so if you do not have the current version of adobe acrobat reader you need to download and install it as well.
    www.adobe.com/acrobat
  • Gayle Ashbach
    Here is a troubleshooting page for your monitor:
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    If you do not find an answer with all of these helps, you can also go to www.hp.com/support and start an online chat with an HP technician. It is one of the options under support.
    Good luck to you. I hope that you are able to get this monitor connected and running.
Nintendo DSi bottom screen flashes then dies
You almost certainly have one or more blown capacitors on the board (probably just one). You will need to open it up, find the blown capacitor (convex top, instead of flat), and replace it. If you are unsure about doing soldering work on a board, get a friend who does this kind of thing. It's not expensive.
Nov 27, 2014 | Nintendo DSi Matte Blue Console
Our monitor on/off button is not working well. sometimes it won't turn on, other times the blue halo flashes on and off. is there a simple solution or is it just failing?
Check all connections.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 10, 2014 | eMachines Computers & Internet
My minkaAire/Delano11 will not turn on. The green light is now blue. What does this mean
OKAY I HAVE A POSSIBLE SOLUTION! THERE SHOULD BE A GREEN LIGHT AT THE TOP OF THE REMOTE AND A BLUE LIGHT AT THE BOTTOM. YOU NEED TO TURN OFF THE BOTTOM SWITCH, WHERE THE BLUE LIGHT IS, FOR 5 SECONDS THEN BACK ON. THEN HOLD THE CENTER STOP BUTTON FOR 5 SECONDS AS WELL. THIS WILL ALLOW FAN AND REMOTE TO RESYNCHRONIZE, IF BLUE AND GREEN LIGHTS BLINK TWICE THEN U HAVE SUCCESSFULLY RESET BOTH FAN AND REMOTE. IF THIS DOESN'T WORK CALL MINKA AIRE TECH SUPPORT 1-800-221-7977. GOOD LUCK!
Nov 19, 2013 | Minka Aire Ceiling Fan
HP vs17 (PK657AA) problem: the image is displayed for 3 seconds
first try entering VGA mode in the startup menu. u can get the startup menu by pressing the F8 key immediately after the POST screen. if the screen stabilizes try changing the resolution to 1024 by 768 which should work in normal mode. if that doesnt work then the monitors internal bulbs may be burnt. an electrician may fix this problem for you.
Nov 18, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Hello, I have a problem with my eee 100H5 netbook. I was using it connected to the power outlet, when it randomly shut off. It cannot be restarted and is unresponsive to the power cord, meaning that the...
Unplug the computer and take out the battery.
Hold the power button for ten seconds.
Leave the battery out and plug in the power cord.
Press the power button.
If the computer turns on, put the battery and everything should now work.
This has solved every "laptop not turning on problem" for me and my friends.
sublimedjg
Jun 23, 2011 | ASUS Eee PC 1000HE Netbook
I have a HP vs17 LCD monitor 17" I relaced the screen and don't remember how the wires go to the back lights. They are the pink and blue wires on the side of the power board. Can you help?
Pink and Blue wires should be for the lamp assemblies, you should have four connectors for the lamps, each pair will be plug into the socket top set and bottom set.
See example here:
http://s807.photobucket.com/albums/yy352/budm/HP%20L1740/?action=view&current=DSCF1597.jpg
Post pictures if you are not sure.
Mar 23, 2011 | HP vs17
If i turn my computer off for whatever reason, when i try to turn it back on, the monitor remains black, the blue power light flashes and the monitor emits this horrible hissing sound. I can eventually get...
Try this, no guarantees but it may need to be reset. Make sure PC is turned off. Disconnect the monitor from the PC and unplug it from the wall. Hold in the Power button for at least sixty seconds, then replug it in PC and wall. If it is reset it should start normally. If not it needs further diagnosis.
Jun 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Damn Blinking!
You can buy a used monitor about $50.00 in the US. or You should take the monitor to an authorized repairman. IT IS NOT recommended to fiddle by banging a defective unit WHICH has HIGH voltage running through it.
Jul 26, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Black screen, flashing blue power light
Chek the RAM of your system. Clean the slot and re-fix the ram. If the problem not solved replace the Ram
Jun 17, 2009 | HP Vs17 17" LCD Flat Panel Monitor
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
211 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
